Micro-Ninja Oil
Fleming Island, FL
Greetings fellow motorcycling tribologists!
I have a 2017 Kawasaki Ninja 300 commute bike now (need to update my sig), and am a bit confused about the oil to use. Pertinent background, this is a water cooled parallel twin, bucket shim tappets, with a common sump between engine, gear box, and wet clutch. The clutch is a "slipper clutch" design. I imagine this little motor shears oil very quickly. Let me elaborate on my confusion...
The owners manual calls for "...4-stroke oils with API SG, SH, SJ, SL, SM and JASO MA, MA1, MA2 rating
"Viscosity: SAE10W-40"
A few pages later, it says:
"Although 10W-40 engine oil is the recommended oil for most conditions, the oil viscosity may need to be changed to accommodate atmospheric conditions in your riding area."
There is a graphic that provides additional information. 10W40 is good from -10C to 40C (14F to 104F). Now, I have no desire to operate my motorcycle in sub-freezing conditions, but we do, occasionally, get ambient temperatures above 104F here in tropical North Florida. This corresponds to the recommendation for 20W50 oil.
So what's my confusion? Probably just the marketing aspect - most companies call this "V-Twin Oil."
So, is there something in these "V-Twin Oils" that make them unsuitable for the micro-Ninja? They operate typically at much lower RPM, and don't have slipper clutches. Or is it just the marketing wanks trying to steer un- or under-informed owners (no disrespect intended) to the correct oil? If there is something not obvious in the specifications printed on the bottle, what do I look for?
Thanks,
- Arved
The important classification is MAn where in is blank, 1 or 2 This is good for clutch. 10W40 good year round, in your area 20W50 also ok year round may be quieter or not.
Rod
Wow.... is this engine design so tolerant of inferior oils,
that the warranty will be met even when running API SG oil?
I don't think there is any regular available oil on the shelf that will hurt this bike, period.
Just use a good 15W-40 all year round.
I put 85,000 miles on Suzuki VZ800 Marauder using whatever cheap 15W-40 was on sale that week.
On a small displacement high-revving 250/300, you *might* be able to feel a difference in the way the engine responds between a 40 and 50 grade oil.
You don't have to worry about the 'W' number in Florida, unless you park your bike in a meat freezer.
Agreed with Linctex, you likely can't go wrong with a 15W-40 for overall availability/cost/performance. Rotella T4 will even meet JASO MA/MA2.
Thanks,
- Arved
It's unlikely a "V-Twin" marketed oil would be unsuitable for you. There are non-v-twin specific 20W-50 oils though and as others have said, you can find 15W-50 or 10W-50 oils pretty easily too to eliminate any atmospheric anomalies that might otherwise restrict your choices.
In general, a "V-Twin" oil should contain more anti-oxidants and higher TBN than a non-V-Twin oil because the typical V-Twin engine generally allows more blowby and contaminants from the combustion chamber. That isn't necessarily true since many companies just take their standard 20W-50 and call it "V-Twin" without any modification, but the good ones should be doing stuff like that. Either way, it doesn't make it unsuitable for a Ninja.
Actually SG i a pretty good oil, just has a zinc content too high for some catalytic converters. Superior for some applications (flat tappets) over SN
The MAn rating is most important, some SN oils have additives that replace zinc that may affect some clutches. Any oil with MA rating does not use those additives.
The 300 is a stout engine, so really some oil is better than no oil, and clean oil is better than old oil. You are not going to have a problem.
Rod
It's typical for modern Japanese bikes. The manual for my current bike says 'Recommended engine oil grade: API SG or higher, JASO MA'. Same for the last couple of Japanese bikes I've owned.
The bigget thing to look for is make sure the oil is NOT energy conserving oil.
Energy Conserving oil has friction modifiers that will ruin a wet clutch.
As said above, any HDEO xw-40 oil would do you good in Florida.
Truthfuly, even Supertech 15w-40 oil from Walmart would do you just fine.
If you don't want to "cheap out" (some just have issue using Supertech, I don't), you could look at other HDEO (Rotella, Delvac, Delo) in conventional or synthetic.
Well, it is expected to be -2C/+28F tonight. "North Florida" can sometimes be considered "South Georgia." However, the engine will not be run under those conditions. Viva la Miata!
I've been considering T4. Shell's website says "Shell ROTELLA® T4 Triple Protection shows significantly improved resistance to oil breakdown under high temperatures." I'm hoping this will allow me to stretch that 40C/104F limit on 40 weight oils to whatever we get. You'd think a water cooled motorcycle wouldn't be so critical of ambient temperatures!
Thanks to all who responded.
- Arved
There are a ton of wet clutch compatible MC oils out there. Just run one of them. Forget the V-Twin label nonsense. If it's an MC oil and wet clutch rated, just run it. Your bike wont care what the name of the oil is.
I've run Valvoline MC 20/50 in my KTM, and have had no issues with my wet clutch.
The water-cooled aspect does not affect the temperature at start-up which is the main reason why they recommend different grades for different temperatures.
Yeah I wondered about that on this forum last Summer: https://bobistheoilguy.com/forums/ubbthreads.php/topics/4453712/1
A few weeks later I had a tour planned on that bike, and the fact that I was using the recommended for all temperatures 10W30 and it was 43.5C ambient when I was about to depart (it reached 46.5C according to my bike on the first segment of the ride) was one of a few reason I switched bikes last minute (to my BMW boxer running 15W50). I could barely wrap my head around 10W30 protecting the gearbox at normal temperatures, and it didn't seem prudent to use in that heat.
As far as your bike, I'm in the xW50 camp if you expect to operate in that temperature range during the oil change interval. I've likely violated such recommendations in the past (having xW40 in a bike when it's 41C for example). But for me, until last Summer at least such temperatures were uncommon. And I'd never ridden in as hot conditions as on the start of that trip.
there are a few 10w40s that will live for very long (2k mi) in that motor and not turn into water.
finding them is not worth the effort.
srt 15w40 or supertech 15w40 is right there on the self at wallyworld for $14 a gallon and available at
any store you can ride to and most open 24hrs a day.
change it when your left foot thinks it is time and enjoy the ride.
and fyi, it was 12F here in cental texas yesterday. record for the day and coldest we've had in 7+ years.
back to 70 or 71 on saturday though!
Had to laugh a little at this comment, unless you ride a bike, you would have no idea what that means (and even some with a bike would not get it).
I wish I had bought some of the SRT oil back when it was on clearance last year (or was it the year before?). I had no need for it at the time, but would love some now that I have a bike.
My 250 has zero problems after 64000kms using only 10w40 with 6000km oci at temperatures from 0 to 45C.I have posted a uoa a week ago you can check.I had even participated to trackdays in the summer and still had the oil changed every 6000kms with lots of city driving etc. Mind that the 300 has a significantly larger oil capacity than the 250 so I wouldn't worry a bit.
