Advice on spark plugs for 90,000 mile Accord
by Chris B.. 12/13/18 11:24 PM
Elec star kit for predator engine...
by SmokeyBear. 12/13/18 11:07 PM
Mecredes Bosch vs Ngk sparks plug
by Rohan. 12/13/18 09:48 PM
Wife problem?
by penguin. 12/13/18 08:04 PM
2008 Chevy Malibu 3.6L V6
by lordcheeto. 12/13/18 07:36 PM
power company merged and I got the shaft
by motor_oil_madman. 12/13/18 07:19 PM
Space heater burnt smell
by BossMoss. 12/13/18 07:13 PM
Shell Helix Ultra Maserati 10W-60
by wemay. 12/13/18 06:53 PM
Cox Modem Info???
by Gebo. 12/13/18 06:39 PM
How are these Road Force values?
by mclasser. 12/13/18 05:19 PM
Finally broke down a bought a trailer
by BeerCan. 12/13/18 04:25 PM
What oil for '19 Subaru WRX?
by TKNY. 12/13/18 04:12 PM
Splitting wedges
by buck91. 12/13/18 04:00 PM
Avoiding rust in the rust belt states?
by Chris B.. 12/13/18 03:00 PM
Ericbrooks, Japanese, lordcheeto, WondrousBread, slickoo9
66672 Registered Users
20 registered members (ABCarr, BLND1, 4WD, Ctreasure, Ag76, 4 invisible), 896 guests, and 43 spiders.
Topics295,047
Posts4,926,743
Members66,672
Most Online2,553
Oct 27th, 2018
Electronics savvy, please comment.... #4638465
01/18/18 07:37 AM
01/18/18 07:37 AM
los angeles
daves66nova Offline OP
los angeles
I have an MSD box, which is an ignition box for a vehicle. This transistor seems to intermittently spark a little around the edge when engine is running. I can see it at night when I block the light around the box. Now, Is this due to that piece not being grounded properly with the screws holding it down tight enough , or would it be something else? It has 2 and only one does this and it does get a little warmer than the other one that doesn't spark. I don't know anything about electronics to troubleshoot. Thanks!! Also, has anyone here ever repaired MSD boxes?
THIS SPACE FOR RENT, PLEASE PM ME.
Re: Electronics savvy, please comment.... [Re: daves66nova] #4638517
01/18/18 08:17 AM
01/18/18 08:17 AM
New England
Virtus_Probi Offline
New England
Can you see the markings on the problem transistor so we can figure out what node the tab is connected to?
I don't deal an awful lot with discrete power xtors, but I looked a random bipolar family in a TO220 package and the tab was the collector whether the device was a PNP or NPN. The collector is unlikely to be ground for an NPN, but it's quite possible for a PNP. You could also have a FET that might have totally different connections, really would be good to get the part ID if possible.
2014 Forester XT, 90000 miles
Last Change;
M1 5W30 d1G2
Tokyo Roki 15208AA170 filter
Re: Electronics savvy, please comment.... [Re: daves66nova] #4638518
01/18/18 08:17 AM
01/18/18 08:17 AM
North TEXAS
oldoak2000 Offline
oldoak2000  Offline
North TEXAS
Insofar as electronics, Careful, the case of the transistor is 'part' of the circuit, and should not be 'grounded' to anything that it isn't already connected to. Its normal for them to get warm during operation. 'Grounding' it may cause it to short-out and overload, thereby burning it out.
I'm not a 'msd' expert, but it shouldn't be sparking around the transistor; however, the transistor itself only switches LOW voltages (under a hundred volts) - probably energizing/switching (on/off) the 'bat' side of a coil (much like points would on a classic engine). If there is sparking, it's being leaked from somewhere else in the circuit on the HV side, or maybe even bad spark-plug wires or plugs with too much gap (worn).
Re: Electronics savvy, please comment.... [Re: daves66nova] #4638551
01/18/18 08:53 AM
01/18/18 08:53 AM
N.H, U.S.A.
ARCOgraphite Offline
N.H, U.S.A.
Regular iggy coils resonate so they are "multiple spark" also.
This on a high comp race engine? If not get rid of it.
____________________
If yoyu wish to ftry to fix it:
You make be getting leak back from the high tension side. Check for cracks and bad secondary lead.
Open the unit and look for traces on the boards if its not potted.
OTW most power transistors should have thermal compound or film
under the semiconductor switch. It get dried up. Maybe remove and re compound.
2014 Nissan Rogue S CVT, OC#10 47272mi-QSUD10W30+5w20 Toughguard Filter; '17 Subaru Crosstrek CVT OC#2 ?? mi-SOA/Idemitsu 0w20 + SOA Filter
Re: Electronics savvy, please comment.... [Re: daves66nova] #4638567
01/18/18 09:07 AM
01/18/18 09:07 AM
los angeles
los angeles
I hope this pic downloaded.
Yes it did. The area where it sparks is at the lower left edge of the transistor. The car just a 22R Toyota engine, daily driver.
Re: Electronics savvy, please comment.... [Re: daves66nova] #4638635
01/18/18 10:10 AM
01/18/18 10:10 AM
Idaho
CT8 Offline
CT8  Offline
Idaho
Contact MSD.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Electronics savvy, please comment.... [Re: daves66nova] #4638667
01/18/18 10:55 AM
01/18/18 10:55 AM
New England
New England
That is a power PNP and the case is the collector, so it is possible the case is tied to ground.
Is there a screw head sheared off in the upper right or is that just a different type of component holding the case down?
If it's sparking near the screw, I can't see any harm in trying to tighten the screw to see if that helps (keep yourself isolated JIC).
Last Change;
M1 5W30 d1G2
Re: Electronics savvy, please comment.... [Re: CT8] #4638671
01/18/18 10:57 AM
01/18/18 10:57 AM
los angeles
los angeles
Originally Posted By: CT8
Contact MSD.
Their tech support and online forum is WORTHLESS.
Re: Electronics savvy, please comment.... [Re: Virtus_Probi] #4638676
01/18/18 11:03 AM
01/18/18 11:03 AM
los angeles
los angeles
Missing screw there. I installed one recently.
Re: Electronics savvy, please comment.... [Re: daves66nova] #4638689
01/18/18 11:16 AM
01/18/18 11:16 AM
N.H, U.S.A.
N.H, U.S.A.
was the switch previously blind riveted to the case/heatsink? Maybe your screw went too deep and is near a B+ trace underneath.
I'm sorry, overall but Looks like junk from a distance.
I would Remove it, go back to stock, but use IR plugs if single coil ignition.
Re: Electronics savvy, please comment.... [Re: daves66nova] #4638695
01/18/18 11:19 AM
01/18/18 11:19 AM
CA
user52165 Offline
user52165  Offline
CA
MSD = May Self Destuct
I've seen so many problems with MSD. How do they even still survive as a business?
What possible reason for this box on this engine??
Re: Electronics savvy, please comment.... [Re: ARCOgraphite] #4638697
01/18/18 11:23 AM
01/18/18 11:23 AM
los angeles
los angeles
I believe it previously had screws on each end. Im running the box. Does run better, smoother with it.
Re: Electronics savvy, please comment.... [Re: user52165] #4638722
01/18/18 11:57 AM
01/18/18 11:57 AM
los angeles
los angeles
Easier starting hot or cold, smoother running, possible mpg gain, spare box just laying around, easy to install,etc,etc
Re: Electronics savvy, please comment.... [Re: ARCOgraphite] #4638723
01/18/18 11:59 AM
01/18/18 11:59 AM
los angeles
los angeles
It works is what counts, not "looks"
Re: Electronics savvy, please comment.... [Re: daves66nova] #4638735
01/18/18 12:12 PM
01/18/18 12:12 PM
New England
New England
Is it possible that one of the wires crossing over the lower left edge of the xtor is missing insulation on the bottom?
Last Change;
M1 5W30 d1G2
