Put my wife's dog down yesterday
by Stelth. 12/18/18 05:04 PM
ATF Filter oem vs aftermarket any differences?
by 97prizm. 12/18/18 03:50 PM
Depth-Fiberglass Filter Media.
by Al. 12/18/18 03:43 PM
O2 sensor B1S1 no voltage??
by David1. 12/18/18 03:43 PM
Brilliant payback for package thieves
by SirTanon. 12/18/18 01:22 PM
Calling all Ford Owners
by dogememe. 12/18/18 01:01 PM
2003 Ford CVPI, 86kmi, 6kmi on Edge HM Ti 5W30
by Colt45ws. 12/18/18 12:35 PM
2017 Kia Sportage recall notice
by SlavaB. 12/18/18 12:26 PM
My VW Service Experience
by Delta. 12/18/18 11:36 AM
Nissan high idle, P0507
by LeakySeals. 12/18/18 11:23 AM
Should i go for even thinner fluid ?
by NICAT. 12/18/18 11:06 AM
Viscosity question
by dbierman. 12/18/18 10:50 AM
48 hours and a used car
by Imp4. 12/18/18 09:32 AM
Test driving PHEV w no battery charge
by RichardS. 12/18/18 09:02 AM
2005 Ford PSD with hard shifts when cold?
by racin4ds. 12/18/18 08:08 AM
18% off Ravenol + EVERYTHING @ Blauparts.com
by CleverUserName. 12/18/18 07:48 AM
Mattress shopping .....
by dblshock. 12/18/18 04:57 AM
MuhThugga, wxo, dbierman, keyblade, leeal
66716 Registered Users
87 registered members (andyd, 01rangerxl, 28oz, AndyB, 14Accent, 11 invisible), 1,958 guests, and 44 spiders.
Topics295,227
Posts4,930,540
Members66,716
Most Online2,553
Oct 27th, 2018
Frame Rust Removal #4638293
01/17/18 10:24 PM
01/17/18 10:24 PM
California
mbacfp Offline OP
mbacfp  Offline OP
California
My 2003 Dodge Durango has some frame rust...was an out of CA car before I bought it. Does anyone recommend a product and procedure for removing? Do I sand the surface and apply some paint. I appreciate any advice.
2014 F-550 PSD..........M1 Delvac ESP 5w-40 + OEM
2018 Dodge Charger SRT Hellcat
2012 Toyota Sienna LTD 3.5L V6
2003 Dodge Durango R/T 4x4 5.9L V8
Re: Frame Rust Removal [Re: mbacfp] #4638298
01/17/18 10:28 PM
01/17/18 10:28 PM
socal
barkingspider Offline
socal
POR-15, that’s what I would use on the frame
06 Cadillac Escalade Ext
17 Cadillac ATS (wife)
05 Toyota Camry (daughter)
11 GMC Canyon off-road (daily)
Re: Frame Rust Removal [Re: mbacfp] #4638302
01/17/18 10:34 PM
01/17/18 10:34 PM
SE British Columbia, Canada
Snagglefoot Offline
Snagglefoot  Offline
Eastwood chassis paint but you have to realize it’s not hard to find “Fails” on any of these products on You Tube.
SF
If you want the job done right......do it yourself.
Re: Frame Rust Removal [Re: mbacfp] #4638308
01/17/18 10:42 PM
01/17/18 10:42 PM
San Antonio, TX
das_peikko Offline
das_peikko  Offline
San Antonio, TX
It all depends on whether the rust is accessible or not -- you didn't mention that.
Re: Frame Rust Removal [Re: mbacfp] #4638320
01/17/18 10:57 PM
01/17/18 10:57 PM
WI
HoosierJeeper Offline
WI
Pics? if it's surface rust, I'd remove it and then use a self etching primer and then paint.
15 Jeep KL Limited V6: Formula Shell 5W20
07 LR3 SE V8: Maxlife 5W30
05 Jeep KJ Limited: PHM 5W30
96 Jeep XJ Country: STP HM 5W30 (winter)
Re: Frame Rust Removal [Re: mbacfp] #4638341
01/17/18 11:36 PM
01/17/18 11:36 PM
NJ, USA
davison0976 Offline
davison0976  Offline
NJ, USA
You can use a mild acid based solution like Naval Jelly to remove rust then a paint of your choice, but I would recommend an engine enamel paint. It withstands heat, oil, grease and in my case looks the same 4 years later as the day I spayed it on.
Re: Frame Rust Removal [Re: mbacfp] #4638365
01/18/18 12:52 AM
01/18/18 12:52 AM
WI
WI
That looks new! Did you have to re-balance the driveshaft?
Re: Frame Rust Removal [Re: mbacfp] #4638381
01/18/18 01:55 AM
01/18/18 01:55 AM
california
slowrench Offline
slowrench  Offline
california
I like linseed oil for rust.The slow drying time lets it penetrate and get under the rust.I also keep a jug of used battery acid ,to brush on first, if rust is real bad.
Re: Frame Rust Removal [Re: mbacfp] #4638466
01/18/18 07:39 AM
01/18/18 07:39 AM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
Sunflower oil and aluminium
https://bobistheoilguy.com/forums/ubbthreads.php/topics/3864753/Coke_Can_for_Brake_Drums#Post3864753
Linseed oil would set quicker, which isn't critical in this application but might be in some circumstances.
(Putting sulphuric acid on your car sounds dodgy}
Re: Frame Rust Removal [Re: mbacfp] #4638683
01/18/18 11:11 AM
01/18/18 11:11 AM
Waco, TX
Linctex Online content
Linctex  Online Content
Waco, TX
If you have ANY bubbling paint anywhere, you have to "break the bubble" and use a power washer to get all the corrosive salts out.
Re: Frame Rust Removal [Re: HoosierJeeper] #4639247
01/18/18 08:17 PM
01/18/18 08:17 PM
NJ, USA
davison0976 Offline
davison0976  Offline
NJ, USA
No, not at all. Jeep was only a few months old when I did that. The surface rust wasn't thik. And even if it was, I figure if you are removing about the same volume of material all around it should stay balanced.
As someone I believe had mentioned, I like using lithium grease on subframe of my other household vehicle which is a sedan. It's not practical to try to remove rust on some hard to reach surfaces. But spreading a thin layer of lithium grease does wonders. The key is to do it when rust is dry, so that no moisture gets locked up.
