paying Premiun for the name(infiniti/nissan
by 2008wrx. 12/12/18 11:25 AM
POE oil (R-410a)
by WyrTwister. 12/12/18 09:44 AM
Any Volvo Owners, need some help!
by LazyDog. 12/12/18 09:34 AM
NOACK & Sheer
by WyrTwister. 12/12/18 09:34 AM
Rotary help. 2010 series 2 RX8
by TinyVoices. 12/12/18 08:32 AM
Can you mathematically estimate top speed?
by KCJeep. 12/12/18 08:06 AM
2019 GM 6.2 AFM
by XL1200RFan. 12/12/18 07:32 AM
Dodge Challenger R/T Tips and Tricks?
by LoneRanger. 12/12/18 06:02 AM
MIL vehicle suggestion $8000
by madRiver. 12/12/18 06:00 AM
Toyota 2TR-FE 2.7 questions
by Doublehaul. 12/12/18 12:32 AM
Anybody used Eurolub?
by FordCapriDriver. 12/12/18 12:18 AM
Micro-Green Cut Open
by David1. 12/11/18 11:45 PM
Witch way does this valve work?
by Dylan1303. 12/11/18 11:42 PM
Santa came early..
by leoblack9. 12/11/18 11:22 PM
dropped a zip tie in my prius trans
by eljefino. 12/11/18 09:54 PM
2 Cello's - Some talented fellows right here.
by StevieC. 12/11/18 09:49 PM
Something different for sure - Punjabi Celtic
by StevieC. 12/11/18 09:40 PM
Honda eu200i hiccuping @ low idle - fixed
by Jmoney7269. 12/11/18 09:34 PM
Geardaddies, tedonom, 01ws666, ariefnrst, tcoffin014
66658 Registered Users
117 registered members (4WD, 2008wrx, 69GTX, aba4430, ammolab, 28oz, 13 invisible), 1,833 guests, and 39 spiders.
Topics294,976
Posts4,925,267
Members66,658
Most Online2,553
Oct 27th, 2018
Drywall Cracks #4638227
01/17/18 09:05 PM
01/17/18 09:05 PM
MIchigan
Warstud Offline OP
Warstud  Offline OP
MIchigan
I just noticed I've got a couple hairline cracks in my drywall where I repaired it a few years back and I also have one in the garage above the entry door that seems to get worse in the winter. Same with my hardwood floors. Is this a result of low humidity?
Re: Drywall Cracks [Re: Warstud] #4638251
01/17/18 09:29 PM
01/17/18 09:29 PM
NJ
JLawrence08648 Offline
NJ
Settling. Are your walls plaster and you spackled on top? Did you use paper or mesh tape? Premix Compound?
Re: Drywall Cracks [Re: Warstud] #4638261
01/17/18 09:46 PM
01/17/18 09:46 PM
MIchigan
Warstud Offline OP
Warstud  Offline OP
MIchigan
I cut out the crack and filled with Premixed Joint Compound and used mesh tape.
Re: Drywall Cracks [Re: Warstud] #4638263
01/17/18 09:49 PM
01/17/18 09:49 PM
Long Island,nassau county NY
nickaluch Offline
nickaluch  Offline
It's from dry winter heat in your house.
2007 G6 beater.2012 E450 box truck. 2018 Chevy Traverse.2017 E450 box truck.2017 Chevy 3500 extend cargo van.
Re: Drywall Cracks [Re: Warstud] #4638266
01/17/18 09:57 PM
01/17/18 09:57 PM
VW Fanboy Island
maxdustington Offline
VW Fanboy Island
Ditch the premix and get some real mud. We have a product called sheetrock 90 which is used in initial plaster coats on drywall because it does not shrink. If you have to repair the same area again, you should try non shrinking plaster.
03 Jetta AWP/09A 205k kms
Edge 0W40 + Mann 719/30
Re: Drywall Cracks [Re: Warstud] #4638310
01/17/18 10:47 PM
01/17/18 10:47 PM
california
slowrench Offline
slowrench  Offline
california
Water can cause ground to swell some, in the winter time.This can make doors stick,cracks appear,even raise a floor,depending on type of soil and where the house was built.
Re: Drywall Cracks [Re: Warstud] #4638339
01/17/18 11:36 PM
01/17/18 11:36 PM
Where the wind comes sweepin'
Reddy45 Offline
Reddy45  Offline
Yup I have seen a few nail pops due to the icy blast that keeps revisiting us. The news said this has been a record year for gas consumption so it's definitely the coldest it has been in a while.
When spring rolls around, get out that spackle and paint!
Re: Drywall Cracks [Re: Warstud] #4638370
01/18/18 01:13 AM
01/18/18 01:13 AM
Texas
FZ1 Offline
FZ1  Offline
Texas
Probably just shifting. Ground is drying and contracting vs. seasons when you water.
Re: Drywall Cracks [Re: Warstud] #4638374
01/18/18 01:32 AM
01/18/18 01:32 AM
British Columbia, Canada
ecotourist Offline
ecotourist  Offline
Can you tell if there has been settling? If there has been, (in theory) you can re-level it using the adjustable teleposts which have been fairly normal construction on the Canadian prairies for decades. I don't know how common they are elsewhere. I have a fairly large pipe wrench which I've only used once, for adjusting a "loose" tele-post. I only had to adjust it once.
It isn't easy to tell if there's been settling, but it should be relatively easy, if you have an unfinished basement, using a laser level.
Say you have a beam that runs from one side of the house to the other. You'd check the ends to see if they're level, and then check at various points along the beam. The problem is you don't know how level it was in the first place. About all you can do is assume it was originally level at the ends and the adjustment points and work from there. I assume there'd be more potential for drift if a beam only runs across part of a span, say from a basement wall and ending at a post.
This process might be beyond the skills of the average homeowner and you might need help from an engineer or someone in the construction business.
If you do adjust tele-posts, go very slowly, making only part of a turn every few days, or you could end up with worse cracking, or at least that's what I've been told. And it goes without saying, be sure you're adjusting it in the right direction!
One of our houses had dry wall cracking in the winter. The cracks would close up again come spring. I never figured out what that was about.
2000 BMW 528i 5MT
2007 Honda Accord EX-L 4Door V6 6MT
Re: Drywall Cracks [Re: Warstud] #4638379
01/18/18 01:37 AM
01/18/18 01:37 AM
Texas
FZ1 Offline
FZ1  Offline
Texas
It's just seasonal shifting. Best not to jack with engineers and foundation people.
Re: Drywall Cracks [Re: Warstud] #4638477
01/18/18 07:48 AM
01/18/18 07:48 AM
MI
doitmyself Offline
doitmyself  Offline
MI
I, too, would say that its from seasonal changes due to humidity changes, temperature influences, etc.. There might be a small installation "flaw" in the wall: compound problem, lack of fasteners, stud framing problem. It's likely to reappear year after year unless you can correct the root cause.
The only topping type, somewhat permanent repair I found is to use a fiberglass tape topped by a flexible top coat. It used to be available as permanent crack repair kits, but I have not seen them lately. I found it very difficult to use because the product is difficult to level and feather edge. It doesn't sand down very well. It took a lot of skill to make a repair that didn't show through the paint. I used the kit, then topped it with some very thin conventional topping for final feathering. This final coat was applied more as a glazing type operation to just fill, level, and feather the repair area.
Here's the one I used:
Re: Drywall Cracks [Re: Warstud] #4638514
01/18/18 08:16 AM
01/18/18 08:16 AM
San Antonio, TX
E150GT Offline
E150GT  Offline
San Antonio, TX
I just spent $2,500 to have over 50 cracks repaired due to my house settling.
1984 Mercedes-Benz 300SD - 100k
1995 F150 XL 4.9 reg cab 5MT - 251k 5w30
2016 Mazda6 Touring 6MT - 57k 10w30
2006 Buick Lucerne CXL 3.8 31k 5w30
Re: Drywall Cracks [Re: Warstud] #4638533
01/18/18 08:36 AM
01/18/18 08:36 AM
North TEXAS
oldoak2000 Offline
oldoak2000  Offline
North TEXAS
foundation aside, wood (frame of house) shrinks when dry, swells when humid. Especially a problem on big/long houses.
Drywall compound cannot handle any movement at all, as you've noticed.
I've had great luck using a specific elastomeric coating to deal with seasonal movement like this :
specifically BlackJack Ultra-Roof 1000 - https://www.lowes.com/pd/BLACK-JACK-3-6-...arranty/3013308
This stuff goes on like real thick latex paint. read the specs - it can expand and contract 350% without cracking !! On ceilings - it matched the pure-white pretty good with no paint touch-up needed. On walls it accepts latex paint well to color match the patch, and the latex overcoat flexes pretty well with it for a few years till it gets brittle. For really big gaps (that constantly move) I simply fill the gap with some latex foam first (it too can handle movement better than drywall compound or spackle) then elastomeric coating over it - sometimes a few coats if gap is big.
Re: Drywall Cracks [Re: Warstud] #4638546
01/18/18 08:51 AM
01/18/18 08:51 AM
Baltimore, Maryland, USA
zzyzzx Offline
zzyzzx  Offline
I've tried many things that are supposed to fix this, but the cracks keep coming back. I now live with the cracks.
Re: Drywall Cracks [Re: FZ1] #4638662
01/18/18 10:48 AM
01/18/18 10:48 AM
ecotourist Offline
ecotourist  Offline
You're probably right. You could do more harm than good.
There has been at least some seasonal cracking in every house I've owned, some more than others. It seems if you repair these minor cracks enough times the cracking eventually stops. Or maybe you just stop seeing them.
2000 BMW 528i 5MT
