Catch Can on the Caravan (250km)
by StevieC. 01/20/19 01:21 PM
B164 Bypass dissection.
by Purpfox. 01/20/19 12:02 PM
Pics - 2005 Highlander 3.3L 158k miles
by dkryan. 01/20/19 11:21 AM
Chinese nuclear momentum
by OVERKILL. 01/20/19 10:35 AM
Winter finally arrived
by StevieC. 01/20/19 10:27 AM
Octane rating of UL94 avgas
by Altydoc. 01/20/19 09:55 AM
Any bowlers out there?
by 53' Stude. 01/20/19 08:10 AM
Future of subcompact cars?
by Char Baby. 01/20/19 07:15 AM
Are u a roller coaster fan?
by ZZman. 01/20/19 07:03 AM
DUST - a couple of short Sci Fi films
by Shannow. 01/20/19 05:46 AM
5W30 Synthetic Oils With HTHS of 3.5 ?
by ChrisD46. 01/20/19 04:02 AM
White or milky cloud in engine oil when cold
by OilUzer. 01/20/19 02:08 AM
Karma Kruiser!
by ekpolk. 01/20/19 01:36 AM
2018 Mazda 3 SkyActive 2.0
by wolf_06. 01/20/19 12:41 AM
Kendall nitro 70
by Bullwinkle007. 01/19/19 11:11 PM
Dexron HP
by Snagglefoot. 01/19/19 11:11 PM
Rob_from_Madison, SubieSTI, ebersvc, junk1020, fairparts99
66987 Registered Users
101 registered members (94astro, 02z, 97K15004WD, 16 invisible), 2,291 guests, and 37 spiders.
Topics296,880
Posts4,960,760
Members66,987
Most Online2,688
Jan 19th, 2019
Tire loses air then stops? #4638100
01/17/18 07:10 PM
01/17/18 07:10 PM
Houston, Texas
motor_oil_madman Offline OP
Houston, Texas
I was putting my trailer away for the day and as I walked by it i could hear and see air bubbling out. I expected to have a flat in the morning, but it wasn't really flat. I added air to it, but a couple weeks later it hasn't lost much air. What gives?
Trailer tires pick up nails all the time and I have a 1 nail in a spot they won't repair it, so I'm afraid they will force me to buy a new Tire after they find the nail. Not sure if they can. They are like little brad nails that aren't obvious. That particular tire has atleast 2 nails in it.
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
Re: Tire loses air then stops? [Re: motor_oil_madman] #4638106
01/17/18 07:15 PM
01/17/18 07:15 PM
KS
FordBroncoVWJeta Offline
KS
Sometimes tires leak to a certain point then stop. Sometimes 10-15psi just isn't enough pressure to leak anymore. Depending on the hole and if the foreign object is still blocking the hole.
2017 Volkswagen Jetta 1.4T - 2015 Honda CRV 2.4 - 2012 Volkswagen Jetta 2.0 - 2001 Pontiac Sunfire 2.2
Re: Tire loses air then stops? [Re: motor_oil_madman] #4638174
01/17/18 08:04 PM
01/17/18 08:04 PM
USA
AITG Offline
AITG  Offline
USA
Years ago I had a fleet car (Chev. Cavalier) that would have a tire go flat at random times. We never found a leak so we would pump up the tire and check the air pressure daily. It never went down a pound until days later when it would again be flat. Out of other ideas, we inflated the tire without moving the car. The steel wheel had a weld that would leak air if the weld was on the bottom of the wheel when the car was parked.
A new wheel solved the problem.
The answer to 80% of BITOG questions: Read the book, follow directions.
Changing oil is not maintenance. Maintenance is the science of inspecting equipment to find and fix things before they break.
Re: Tire loses air then stops? [Re: motor_oil_madman] #4638278
01/17/18 10:14 PM
01/17/18 10:14 PM
Columbus Nebraska
old1 Offline
old1  Offline
Columbus Nebraska
If you are afraid that the nail is a place that they won't repair it, just put some of that "slime" or whatever they call it in it. It should easily fix a small leak.
2017 Nissan Frontier 4.0 5w30
1965 Mustang 200 c/4 10w30 QS defy
1964 Ford Ranchero 302 c/4 15/40 Delo
1929 ford model A No filters, and 15/40 oil
Re: Tire loses air then stops? [Re: motor_oil_madman] #4638280
01/17/18 10:15 PM
01/17/18 10:15 PM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
Stick a plug in it. It's safer than a nap and won't leak.
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: Tire loses air then stops? [Re: motor_oil_madman] #4638406
01/18/18 04:49 AM
01/18/18 04:49 AM
N.Ohio
Lubener Offline
Lubener  Offline
N.Ohio
A self regulating tire!
The "thinking" man's friend.
Re: Tire loses air then stops? [Re: motor_oil_madman] #4639053
01/18/18 05:39 PM
01/18/18 05:39 PM
ME
eljefino Offline
eljefino  Offline
ME
Air bubbling out... of where?
Sometimes the beads get corrosion in there but if you air them up they magically fix themselves.
