The real culprit about 18k
by Ablebody. 09/20/18 06:04 PM
How not to drain a pool.
by StevieC. 09/20/18 05:50 PM
Tranny fluid in Old Ferguson Tractor ?
by Rudy1999 250. 09/20/18 03:39 PM
New (old) car inbound
by BeerCan. 09/20/18 02:42 PM
Ford AWD PTU fluid always black
by Raven. 09/20/18 02:34 PM
PC not charging
by sleepery. 09/20/18 01:53 PM
Can alternators make noise?
by Benzadmiral. 09/20/18 01:21 PM
Pr 1970 Superbirds For sale - Barn Find
by user52165. 09/20/18 12:32 PM
Fram Ultra Air Filters
by StevieC. 09/20/18 12:20 PM
Change oil filter or not. Very low miles
by Martin10. 09/20/18 11:37 AM
Toslink optical audio cable (plastic) experience
by ffhdriver. 09/20/18 11:30 AM
A woman I work with wants an affair with me!
by Drew99GT. 09/20/18 11:08 AM
ACEA A5/B5 REQUIREMENTS
by Kjmack. 09/20/18 10:56 AM
Carolina Reaper hot peppers
by gman2304. 09/20/18 09:54 AM
New Fram air filter?
by irv. 09/20/18 09:15 AM
Any golf cart experts?
by HawkeyeScott. 09/20/18 09:15 AM
EU Subaru 2.5 FB engine oil
by IMPALA08. 09/20/18 08:16 AM
FarmerDude, Bman90, Alday714, Joephoto, tlelectric
66021 Registered Users
113 registered members (2015_PSD, ABomb369, Ablebody, 4WD, 53' Stude, 9 invisible), 1,659 guests, and 53 spiders.
Topics290,728
Posts4,849,216
Members66,021
Most Online3,590
Jan 24th, 2017
2000 Buick Century odometer display died #4637869
01/17/18 05:01 PM
01/17/18 05:01 PM
Buffalo, New York
JimmyJohns Offline OP
Buffalo, New York
The display on the instrument cluster that shows the gear selector and the odometer died.
From what I heard, this is very common. I was wondering if anyone can point me in the right direction as to how to repair the cluster. Theres someone local who does it for about $150, but if I can, I want to save some money and do it myself.
From what I have found, it seems that there are 4 resistors that eventually go bad or get corroded, and the fix is soldering on 4 new 150 amp resistors. Sound about right?
I have plenty of tools and a soldering iron, so equipment I don't think is an isssue
If the resistors are the issue, what resistors should I grab?
Re: 2000 Buick Century odometer display died [Re: JimmyJohns] #4637878
01/17/18 05:15 PM
01/17/18 05:15 PM
Ohio
beast3300 Offline
beast3300  Offline
Ohio
1/2 watt, 150 ohm resistors are what you need. I used to get them at Radio Shack but they don't exist anymore. Amazon has them now. I don't think brand is important.
'03 Regal GS L67: PPUP 5w30/FU3980
'99 Grand Prix L36: R.I.P.
'07 LaCrosse L26: QS HM 5w30/TG3387A
ASE L1 MT
Re: 2000 Buick Century odometer display died [Re: JimmyJohns] #4637883
01/17/18 05:18 PM
01/17/18 05:18 PM
Buffalo, New York
Buffalo, New York
Pretty straight forward or no? The most soldering experience I have is mechanical keys on a keyboard, and splicing a few wires together. I have a soldering iron, solder, and a little suction thing to suck up melted solder.
Re: 2000 Buick Century odometer display died [Re: JimmyJohns] #4637886
01/17/18 05:22 PM
01/17/18 05:22 PM
Ohio
beast3300 Offline
beast3300  Offline
Ohio
Yes. It's very easy. The existing ones (if there are any attached) are black with very little solder on each end. Usually touching them they will fall off.
The resistor ends are too long. I found that if you bend a little "L" that it will help you hold them in place to apply solder. After they are installed then you can simply cut off the excess. The aftermarket resistors are slightly longer as well but you don't have to have them perfect like the factory ones. As long as each end is solder the resistor can be slightly below or above the original locations on the board.
ASE L1 MT
Re: 2000 Buick Century odometer display died [Re: JimmyJohns] #4638060
01/17/18 07:46 PM
01/17/18 07:46 PM
ME
eljefino Online content
eljefino  Online Content
ME
I fixed mine by soldering in one new resistor. As said, they fall off when you look at them wrong.
