Sunrise, Sunset
by csandste. 09/24/18 02:39 AM
Adding fuel filter- Generator built with no filter
by rubberchicken. 09/23/18 09:57 PM
Clutch Engaging too low
by Spetz. 09/23/18 09:41 PM
SMA - Krown previously, Fluid Film Application
by StevieC. 09/23/18 09:21 PM
First Paint Correction
by RayCJ. 09/23/18 08:33 PM
2011 Dodge Caliber
by dogememe. 09/23/18 07:48 PM
Mixing transmission fluids - partial change
by spk2000. 09/23/18 07:31 PM
Counterfeit MANN filter???
by IllinoisSparky. 09/23/18 06:54 PM
The smell of an oil: VME adds?
by fdcg27. 09/23/18 06:48 PM
Classic road brake pads
by buck91. 09/23/18 06:18 PM
Air up your vehicle's tires
by Papa Bear. 09/23/18 06:07 PM
A cool litttle Fall foliage site
by Papa Bear. 09/23/18 06:02 PM
Suggestion: "Likes"
by SnowDrifter. 09/23/18 05:36 PM
Condensation in headlights?
by irv. 09/23/18 05:06 PM
Nissan VQ V-6 Engines
by Al. 09/23/18 04:57 PM
List of dexos licensed oils?
by k1xv. 09/23/18 04:24 PM
Lilshady, SevenDu, sigpro, RayCJ, yellow97tt6spd
66055 Registered Users
22 registered members (4WD, biggusblockus, agh13tz, Astro14, Ablebody, 5 invisible), 740 guests, and 41 spiders.
Topics290,921
Posts4,852,538
Members66,055
Most Online3,590
Jan 24th, 2017
2013 Impala Rear Suspension Help #4637821
01/17/18 04:00 PM
01/17/18 04:00 PM
Clarence NY
jims5600 Offline OP
jims5600  Offline OP
Clarence NY
Hi All, A good friend of mine has a 13 impala. His wife now needs to use a wheelchair. He had a
hitch setup installed on this car. When he looks the wheel chair up to the hitch,the rear end
dips low. How low Iam unsure. He is in S.Carolina and Iam in Buffalo Ny.
I can't see where there is a device to make the rear struts "stronger". I would think a
replacement loaded strut would have the same condition.
Any Ideas?
Thanks
Re: 2013 Impala Rear Suspension Help [Re: jims5600] #4637823
01/17/18 04:03 PM
01/17/18 04:03 PM
Central Virginia
Silverado12 Offline
Silverado12  Offline
Central Virginia
If the shock isn't inside the spring an airbag setup would make sense. They are relatively easy to install.
12 Chevy Silverado ext. cab LS, 2WD 4.3 auto
18 Mustang GT 5.0 auto
07 Harley Dyna Street Bob 96 c.i. 6 sp.
00 Mustang GT auto
Re: 2013 Impala Rear Suspension Help [Re: jims5600] #4637824
01/17/18 04:05 PM
01/17/18 04:05 PM
WI
HoosierJeeper Offline
WI
x2. You might be able to get shocks for a Police Impala and those would likely be stiffer but still might not cut it. Sorry to hear about his wife, best wishes to them.
15 Jeep KL Limited V6: Formula Shell 5W20
07 LR3 SE V8: Maxlife 5W30
05 Jeep KJ Limited: PHM 5W30
96 Jeep XJ Country: STP HM 5W30 (winter)
Re: 2013 Impala Rear Suspension Help [Re: jims5600] #4637835
01/17/18 04:23 PM
01/17/18 04:23 PM
Canada
i_hate_autofraud Offline
Canada
is the wheelchair electric?
A manual chair does not weigh enough to drop the rear end.
Re: 2013 Impala Rear Suspension Help [Re: Silverado12] #4637871
01/17/18 05:06 PM
01/17/18 05:06 PM
Oshawa, Ontario Canada
JC1 Offline
JC1  Offline
+1 Google "air lift 1000" and see if they make airbags for that vehicle.
2015 Grand Caravan SXT Plus 5w-20 PPPP/Fram Ultra Filter
1997 Honda Civic CX 5w-30 Shell Conventional/Fram Ultra Filter
Re: 2013 Impala Rear Suspension Help [Re: jims5600] #4637920
01/17/18 05:58 PM
01/17/18 05:58 PM
Texas
GMBoy Offline
GMBoy  Offline
Texas
GM has a mobility program that operates thru the dealer network. He should try the dealer and see what GM may have to help.
Re: 2013 Impala Rear Suspension Help [Re: jims5600] #4637931
01/17/18 06:07 PM
01/17/18 06:07 PM
Clarence NY
jims5600 Offline OP
jims5600  Offline OP
Clarence NY
Yes,it is a electric wheel chair. The strut does go thru the spring. I will google air bags,never
thought of that.
Thanks to all for your help.
Re: 2013 Impala Rear Suspension Help [Re: jims5600] #4638112
01/17/18 08:18 PM
01/17/18 08:18 PM
Canada
Canada
thought of that.
How much does it weigh?
