Supertech VS Redline - Project Farm
by StevieC. 03/18/19 03:01 PM
How to fix swollen deckwood
by RazorsEdge. 03/18/19 01:52 PM
Which is more important: Oil or Filter?
by RDY4WAR. 03/18/19 01:45 PM
Dishonest car dealership?
by aquariuscsm. 03/18/19 01:21 PM
Phillips 66 Shield Choice $1.99 @ Orscheln
by Pat in Speedway. 03/18/19 12:41 PM
Barely there back seats
by y_p_w. 03/18/19 11:47 AM
should i be afraid of the DCT ?
by WhyMe. 03/18/19 11:28 AM
Friction modifiers
by Truckedup. 03/18/19 10:57 AM
Sometimes, choices are made for you!
by addyguy. 03/18/19 10:30 AM
I Hope This Amuses You Guys Like It Did Me
by NYEngineer. 03/18/19 10:27 AM
New Exmark Lazer Z / Oil ?
by johnD2. 03/18/19 10:13 AM
First welder recommendation
by Astro14. 03/18/19 09:55 AM
Amsoil Burning
by ridgerunner. 03/18/19 09:38 AM
2007 Sonata Pinging + DTCs
by F24Sonata. 03/18/19 09:31 AM
Nissan Maxima 2009 synthetic oil choices
by mahanddeem. 03/18/19 09:23 AM
Best coated rotors
by JMHC. 03/18/19 09:11 AM
Brake Bleeder Question
by maverickfhs. 03/18/19 08:57 AM
Ring alarm system, any good?
by Redright9. 03/18/19 08:18 AM
Indyfordfan, toplscuda, swrve, TomRx, Ozdave
67548 Registered Users
118 registered members (ad_infinitum, AandPDan, 1978elcamino, ABerns, 2015_PSD, 16 invisible), 2,388 guests, and 65 spiders.
Topics286,019
Posts4,900,954
Members67,548
Most Online2,967
Mar 10th, 2019
Worried about battery after mishaps. Thoughts? #4637724
01/17/18 02:04 PM
01/17/18 02:04 PM
PA
d00df00d Offline OP
d00df00d  Offline OP
PA
I'll leave out the backstory, and the excuses. Battery in question is an Optima Yellow Top, which I wish I hadn't bought anyway, but whatever. Here's what I did:
1. Ran it ~60 miles with a weak negative terminal connection. It was bad enough that the car wouldn't crank at all, though it started with a jump and seemed to run okay.
2. Accidentally shorted the battery for a few seconds, and saw sparks from the (evidently poorly connected) negative terminal.
After all this, the battery tested at 614 cranking amps; spec is 640. With the connection fixed, the car cranks more or less as it did before (hard to tell with changing temps).
How likely is it that I've hurt the battery? Should my portable jumpstarter be a permanent fixture in the car until I ditch this battery, or should I not worry until I notice other bad signs?
2008 BMW M3 Sedan 6MT
Re: Worried about battery after mishaps. Thoughts? [Re: d00df00d] #4637738
01/17/18 02:25 PM
01/17/18 02:25 PM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
It's fine. It may need to be trickle charged overnight is all.
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: Worried about battery after mishaps. Thoughts? [Re: d00df00d] #4637744
01/17/18 02:30 PM
01/17/18 02:30 PM
midwest
muddawgs Offline
muddawgs  Offline
midwest
I've gone through 2 red tops that decided to self discharge right around 20 months or so. If you google you'll see pages of people saying the same/similar on both the red and yellow tops. the consensus is that they are not as good when they were made in the USA. Your situation is a bad terminal and a quick short which should not hurt the battery at all. It sounds like it's still healthy at this point but I would continue to monitor or check several times a year.
Re: Worried about battery after mishaps. Thoughts? [Re: d00df00d] #4637745
01/17/18 02:31 PM
01/17/18 02:31 PM
Chicago, IL
EdwardC Offline
EdwardC  Offline
Chicago, IL
I'd agree, I don't think there's too much damage. Trickle charge to top off and I don't think it will skip a beat.
Full discharges and prolonged time at low charge are much harder on the battery.
Re: Worried about battery after mishaps. Thoughts? [Re: d00df00d] #4637766
01/17/18 02:54 PM
01/17/18 02:54 PM
Pittsburgh,PA U.S.A.
JimPghPA Offline
JimPghPA  Offline
At 614 CCA verses rated 640 CCA that battery still has 95.9375 percent of its rated CCA, and it might even test greater than 640 CCA if it was freshly charged and in warmer weather. A 4.0625 percent drop from rated is nothing to worry about. When it is something like 30 percent less than rated CCA then start to get concerned.
What is the CCA rating that the vehicle calls for if it is available?
Boy will I be happy when ALL vehicles on public roads are autonomous.
JimPghPa
Re: Worried about battery after mishaps. Thoughts? [Re: d00df00d] #4637804
01/17/18 03:35 PM
01/17/18 03:35 PM
New Jersey
JHZR2 Offline
Global Moderator
JHZR2  Offline
Global Moderator
New Jersey
What did you short it with? Yes it matters... Resistance of the short determines heating determines how much cure t the battery actually sourced.
Batteries can be shorted, especially for a short time. It's not good for them.
The bad negative connection bothers me. It could affect the battery's ability to serve like a filter for the ugly six-pulse rectification to DC. A key role of the battery is to be a filter. No filtering, the capacitors in your electronics need to serve as a filter, which is really bad for them, and, there can also be some big spikes. Hopefully nothing was damaged.
I'd charge it up and keep going
Re: Worried about battery after mishaps. Thoughts? [Re: d00df00d] #4637827
01/17/18 04:11 PM
01/17/18 04:11 PM
America
Alfred_B Online content
Alfred_B  Online Content
America
Don't worry about the battery -- if any damage was done, you will need to replace it whether you worry about it or not. i.e. worrying about something doesn't change anything, except the state of your well being.
Carrying a portable jump starter, and a tire inflator, is a good practice regardless.
Re: Worried about battery after mishaps. Thoughts? [Re: d00df00d] #4637837
01/17/18 04:23 PM
01/17/18 04:23 PM
South Florida
bubbatime Offline
bubbatime  Offline
South Florida
Its fine. Make sure its properly installed and motor on.
17 Chrysler Pacifica Edge Syn 5W30
13 Yamaha XT250 Valv MC 10W40
10 Acura TSX 2.4 SuperTech Syn 5W20
06 GMC Sierra SuperTech 10W30
Re: Worried about battery after mishaps. Thoughts? [Re: JimPghPA] #4637941
01/17/18 06:16 PM
01/17/18 06:16 PM
PA
d00df00d Offline OP
d00df00d  Offline OP
PA
Not sure, but I think it's right around 640.
Re: Worried about battery after mishaps. Thoughts? [Re: JHZR2] #4637961
01/17/18 06:27 PM
01/17/18 06:27 PM
PA
d00df00d Offline OP
d00df00d  Offline OP
PA
The jumper cables.
Yikes. Fingers crossed!
Also, this is making me want to go back to the OE battery. Who knows if this Yellow Top is working the same as the OE battery would in the respects you describe here...
Re: Worried about battery after mishaps. Thoughts? [Re: Alfred_B] #4637963
01/17/18 06:28 PM
01/17/18 06:28 PM
PA
d00df00d Offline OP
d00df00d  Offline OP
PA
Sure. I'm not so much worrying about the battery failing per se; it's more that I want to decide what level of precaution to take.
Re: Worried about battery after mishaps. Thoughts? [Re: d00df00d] #4638067
01/17/18 07:51 PM
01/17/18 07:51 PM
ME
eljefino Online content
eljefino  Online Content
ME
The jumper cables.
This is actually "good" in that the cables probably didn't make that high current a connection. Did the outside of the alligator cables just brush the posts and throw a few sparks? Do they have burn marks where you started to melt their metal?
Re: Worried about battery after mishaps. Thoughts? [Re: eljefino] #4638111
01/17/18 08:18 PM
01/17/18 08:18 PM
PA
d00df00d Offline OP
d00df00d  Offline OP
PA
The jumper cables.
With one end's clips on the battery connectors, the other end's clips were in metal-to-metal contact and got weakly but noticeably stuck to each other. Not sure for how long but it was at least 3 seconds. There were sparks coming from between the post and the connector on the battery's negative terminal.
