Basement Framing
MD
I'm in the middle of a basement framing project. I've got some semi-skilled guys on the job and am in a bit of a quandary about the quality and speed of their work. I know many of the basics of framing and have been advising on some things, but I don't know how far I want to go with criticizing their work. For example, they just finished framing for pre-hung closet doors. I was looking at the header this morning and realized that the whole thing is relying on construction screws to mitigate any potential sagging. There are no jack studs and there is only one 2x4 spanning the 5' opening for the header which is screwed to the king studs. Cripple studs are screwed into the header board and are anchored into a joist above.
I wouldn't have built the opening this way; I would have designed it to be under compression, but it's non-load bearing, so it may suffice as it is. If it were put together with nails, I don't think I'd let it go. I've never framed with screws, so I don't know if my concerns are a result of incomplete knowledge.
Any opinions?
I have always been surprised at the lack of respect for their own output by people who claim to be in trades.
It's not load bearing so it may be OK for the foreseeable future. But not good for the long term.
As mentioned, the header isn't supporting anything in this application. It's more to provide a place to attach the door frame and drywall.
Perfectly acceptable and typical of what you'll find in any finished basement.
2 screws per stud atleast? I guess for a closet it would be fine, not for a people door though. Screws hold alot better but for a door that could get slammed the extra wood is a good idea.
I messed up some framing to cover the vent pipe at our knee wall that I put together with screws and it was quite tough to dismantle with a framing hammer...
Originally Posted By: emmett442
As mentioned, the header isn't supporting anything in this application. It's more to provide a place to attach the door frame and drywall. Perfectly acceptable and typical of what you'll find in any finished basement.
Correct.
Your basement was already 100% structurally sound before any finish work began, remember?
They aren't adding "load bearing structure".
There's no need for it; it's already been done before the project began.
If these are off the street hires your contractor is bringing in then calling them framers is an insult to the real framers in this world.
Workers who cut out joists entirely to fit plumbing through or to make room don’t care about structural integrity ten years down the line. It’s a real shame.
Thanks for the replies. I was looking at it again. I guess it'll be okay. It's one of those cases where I know just enough to get me into trouble. I recognize that there isn't any real load here, but I thought the way it was framed there could be a little sagging long-term, which could affect the door frame.
It will be okay, but it is not up to my standards. I like 2x4 framing with studs 8" on center, triple headers, quadruple corners, secured with 3" screws and additional metal strapping and corner braces.
Do you have any bears in the family? or sumo wrestlers? earth-movers?
Once the drywall is attached, it'll be all tied together anyway. Yes, I know, drywall isn't a real framing material - but for the loads in question (which is simply the weight of the drywall you'll be attaching to your framing), it's plenty sufficient. Think about it : if you'd stand a 4x8 sheet of drywall vertical, and support it only on each bottom corner, the span between the corners would never sag. Vertically hanging drywall is plenty rigid to support itself. Extra framing not required.
Again, your wall framing is merely a square and flat surface to screw your drywall and utilities to. Nothing more. It bears no load. But, if it bothers you, "fix" it.
The only time you really have to worry about structure and sag is the ceiling (drywall is weak in this dimension) and traditional doorways that can rack/shake from a operating door, especially when "slammed". Even then, not much is required. a doubled up 2.4 works fine.
I am not a carpenter just a diy and handyman. I'm afraid it will bow in the middle. I'd go with at least a 2x6 if not a 2x8. If it bows then what will you do? At the very least sister on another 2x4. With the weight of the above studs, sheetrock, tape, spackle, paint, that's a lot of weight. And check square by putting a 4' level in the middle, on the end studs, and a square in the corners.
Originally Posted By: JC1
8" on center? Do you own a lumber company? Usual framing is 16" or 24" on center.
Relax.
It was a joke. Who uses 3" screws?
Relax.
Okay, the 3" was a joke. I think 2-1/2" was the biggest size that came in the huge bucket.
Relax.
For framing with 2 by's 3" would be the minimum you would use.
Relax.
No worries.
I've used some 3 inch screws for some doubling up of studs. Strong enough to do chin ups off the top plate.
Relax.
No worries.
Hope I didn't come out wrong.
I thought you use 3" screws for "toughing" up an entry door mounting hardware and doubling up the frame against kicks...
