Signal Oil Company radio advertising
by 21Rouge. 09/21/18 04:07 AM
Anyone "Wim Hof"ing ?
by Shannow. 09/21/18 02:35 AM
New R1250GS and R1250RT
by 02SE. 09/21/18 12:55 AM
Inside Break Booster & Master Cylinder
by StevieC. 09/20/18 11:22 PM
Inside an Alternator
by StevieC. 09/20/18 11:18 PM
What vehicles are you using Maxlife ATF in?
by BlakeB. 09/20/18 11:10 PM
How a Power Steering Rack Works (Electronic)
by StevieC. 09/20/18 11:00 PM
How a Power Steering Rack Works (Hydraulic)
by StevieC. 09/20/18 10:58 PM
silly wiper problem
by bowlofturtle. 09/20/18 10:33 PM
Canadian Tire Shell Rotella T-6 in Pails
by Snagglefoot. 09/20/18 10:04 PM
Best diesel fuel for cold weather?
by Dickm. 09/20/18 10:03 PM
Type 1 Diabetics - New Research
by StevieC. 09/20/18 10:00 PM
Tire Sizing and Options
by NewEnglander. 09/20/18 09:59 PM
2013 Scion FR-S | Transmission Fluid Questions
by nicknak. 09/20/18 09:47 PM
Meguiar's Liquid Cleaner Wax $5 WalMart, Amazon
by The_Cams. 09/20/18 08:42 PM
Winter oil recommendation
by Neptune. 09/20/18 08:27 PM
M1 0W-40
by CT8. 09/20/18 07:37 PM
What controls timing on my 08 Honda?
by Roland. 09/20/18 07:23 PM
Direct_Rejection, donatom, Sylent_Snyper, Ajizzle, nicknak
66033 Registered Users
22 registered members (Duke, emod, Ablebody, Drosselmier, BlakeB, 4 invisible), 724 guests, and 35 spiders.
Topics290,746
Posts4,849,463
Members66,033
Most Online3,590
Jan 24th, 2017
Page 1 of 3 1 2 3
Floor jack pads? #4637138
01/16/18 08:47 PM
01/16/18 08:47 PM
Oshawa, Ont. Canada
irv Offline OP
irv  Offline OP
Oshawa, Ont. Canada
Has anyone ever used these? I just noticed them and found some on E-Bay/Amazon but want some personal opinions first.
I think this/these would be great when doing winter tire/wheel swaps on my wife's Impala. Would certainly save getting the jack out of the trunk and cranking very slowly with a ratchet smacking my knuckles and hand on the driveway!
A huge time saver, imo.
2017 Chevy Impala 3.6 L.
2013 Ram 5.7 L Hemi Bighorn QC 4x4
2008 Chevy Malibu 2.4 L Ecotec
Pennzoil Platinum and/or Pennzoil Ultra Platinum for all 3.
Re: Floor jack pads? [Re: irv] #4637146
01/16/18 08:56 PM
01/16/18 08:56 PM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
Would depend on the car.
I've usually been able to find something solid to locate a bottle jack onto. I never use the supplied jack or jacking points, since on the sort of cars I have, the latter are likely to be unsafe.
Similarly, I've never jacked up directly under the sill flange, but if you did, I'd think something like that would be a requirement.
Re: Floor jack pads? [Re: irv] #4637152
01/16/18 09:02 PM
01/16/18 09:02 PM
MTL, CANADA
Rolla07 Offline
Rolla07  Offline
MTL, CANADA
Or.. you can buy a hockey puck for next to nothing and make your own notch in it. smile
2007 Corolla Red Pearl 155k miles
PP 0w20 & ST 4967
Re: Floor jack pads? [Re: Rolla07] #4637161
01/16/18 09:12 PM
01/16/18 09:12 PM
Oshawa, Ont. Canada
irv Offline OP
irv  Offline OP
Oshawa, Ont. Canada
Good idea but I don't think a hockey puck would be thick enough and I'd also like something with a bit bigger diameter to fill up the floor jack cup a little more.
Might just see for myself though as lord knows I have a ton of them kicking around! crazy
Re: Floor jack pads? [Re: irv] #4637163
01/16/18 09:15 PM
01/16/18 09:15 PM
NY
TurboTravis Offline
TurboTravis  Offline
NY
Are you referring to the entire jack, or just the pad? I have to ask..because..if you own a good floor jack, why are you using the factory scissor jack for anything but emergency situations?! Perhaps I am lost on this one.
Re: Floor jack pads? [Re: irv] #4637165
01/16/18 09:17 PM
01/16/18 09:17 PM
VA
maverickfhs Offline
maverickfhs  Offline
VA
Maybe I am being slow... but can't a thick piece of wood be used with a jack?
2006 Civic EX 202K/AT
2006 Acura TSX 180K/AT
Re: Floor jack pads? [Re: irv] #4637182
01/16/18 09:29 PM
01/16/18 09:29 PM
WI
HoosierJeeper Offline
WI
I use a thick piece of wood for my Cherokee and it doesn't damage that seam at all. I also use pads on the jackstands, got them at Harbor Freight.
15 Jeep KL Limited V6: Formula Shell 5W20
07 LR3 SE V8: Maxlife 5W30
05 Jeep KJ Limited: PHM 5W30
96 Jeep XJ Country: STP HM 5W30 (winter)
Re: Floor jack pads? [Re: TurboTravis] #4637185
01/16/18 09:33 PM
01/16/18 09:33 PM
Oshawa, Ont. Canada
irv Offline OP
irv  Offline OP
Oshawa, Ont. Canada
Just the pad.
On these cars, there is just a thin extra strong piece of metal (jack point) that hangs down slightly at all 4 tire spots. Just using a regular jack, with the cup design of it would hit the body as the cup is too deep to only make contact with these spots. That is why these pucks with the slit are required if you want to use a floor jack.
A piece of wood is something I never thought of and would likely work as well, provided I get a thick enough and strong enough piece.
Here is a pic I found of one in use I believe. Note the jacking point and why my jack, with a cup type lift spot would not work.
Re: Floor jack pads? [Re: HoosierJeeper] #4637189
01/16/18 09:37 PM
01/16/18 09:37 PM
Oshawa, Ont. Canada
irv Offline OP
irv  Offline OP
Oshawa, Ont. Canada
I also didn't know these existed? Going to have to look into those as well. Thanks cheers
For everyone else, this is the first car I have owned that only has these jacking points, all the other cars I've owned, a floor jack wasn't a problem as there were many places to use it.
I appreciate the help. Cheers2
Re: Floor jack pads? [Re: Rolla07] #4637209
01/16/18 10:03 PM
01/16/18 10:03 PM
South Carolina
eyeofthetiger Offline
South Carolina
I bet you can get a 12 pack of hockey pucks at any corner store up there in Canada. They aren't so easy to come by around these parts. I generally use a scrap piece of wood.
2017 Ford Fiesta 1.0T - Valvoline SynPower 5W-20, Motorcraft FL910S
1988 GMC K1500 4.3/700R4 - Supertech 15W-40, Fram TG3980
1986 Ford Ranger 2.0 - uhh
Re: Floor jack pads? [Re: irv] #4637239
01/16/18 10:31 PM
01/16/18 10:31 PM
Everywhere
AndyinAL Offline
AndyinAL  Offline
Everywhere
General unsolicited advice - please use common sense when using wood and floor jacks. When aligned with the grain, the rocker pinch weld can become a wood splitter. An instant 1" drop could damage the rocker panel - or worse - your body.
Re: Floor jack pads? [Re: irv] #4637246
01/16/18 10:38 PM
01/16/18 10:38 PM
California
oldmaninsc Offline
oldmaninsc  Offline
California
Yes, I've used those pads on my Impala, the Grand Marquis and the Camry. They work very well. There are different sizes you can get. Haven't tried them on the F-150. I agree with the post above - I'd be somewhat nervous about using a block of blood.
I used to use a 4X4 block on top of a floor jack for the Aerostar and sometimes the block of wood would make noises that made me rather nervous. The problem with the Aerostar was the floor jack I had at the time wouldn't go high enough to get the vehicle far enough off the ground, so after a while I decide it was safer to temporarily put some wood planks UNDER the jack, and next time I was out - bought a bigger, better jack.
2017 Chevrolet Traverse
2013 Chevrolet Impala LT
2005 Toyota Camry LE
2004 Mercury Grand Marquis LS, 1998 Ford F-150 XLT
Re: Floor jack pads? [Re: irv] #4637256
01/16/18 10:52 PM
01/16/18 10:52 PM
St. Louis
MONKEYMAN Offline
MONKEYMAN  Offline
St. Louis
I have a couple from Ebay. Looked like a hockey puck. They were a very hard rubber. Groove not deep enough so needed to make it deeper. I then bolted them to the jacks. I basically copied the design of the of the jack that came with the car. It keeps the load in the center of the jack pad and does not bend the metal on the car.
Truth alone triumphs, not untruth.
2017 Elantra SE
Re: Floor jack pads? [Re: AndyinAL] #4637269
01/16/18 11:09 PM
01/16/18 11:09 PM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
the welded seam that the jack point is tacked to was sufficient to allow 1 1/4 x 2" x 24" pads between the jack and the both sides of the seam. Thats a pretty big pad. I use odd pieces of wood, blocks and bricks to support my cars. Please do not use such crude materials unless you can cut a 15 degree heel wedge out of a white oak billet. I learned about cribbing, blocking, and shoring working in a ship yard. The job down scaled easily to supporting houses etc whilst replacing rotted out structural stuff. Carz iz nothin. grin2
Thick oil is better grin2
Re: Floor jack pads? [Re: irv] #4637270
01/16/18 11:09 PM
01/16/18 11:09 PM
NY
TurboTravis Offline
TurboTravis  Offline
NY
Just the pad.
Why not jack it from the front or back?
Page 1 of 3 1 2 3
