Originally Posted By: old1
OK, just spotted this thread. I have been a pro OPE mechanic for 40+years, and as you may know many of those engines use foam filters. I have always used mineral spirits to clean the filters, then wring out as dry as possible, even wrapping in a rag, and squeeze more.
then DIP the whole filter in a container of oil (most any oil) and saturate it. Then squeeze it out as dry as you can, and re-install. If not throughly saturated, it could still let some dust in. I have seen ones that the owner did, and just squirted some oil from an oil can around on it, and after running the engine in dirty conditions, you could see exactly where the dirt went through the filter everywhere the oil wasn't. Foam filters do a great job, but ONLY if properly oiled.
I smear chain saw bar oil on the outside of the filter like jam on a slice of bread, then I work it in. The oil is very tacky and not too much gets by it.
