Interior "quick detailer"
by Redright9. 03/25/19 08:21 AM
Seafoam For Last 100 Miles Before Oil Change ?
by ChrisD46. 03/25/19 07:56 AM
WIX 57151XP factory filled with synthetic oil
by Donald. 03/25/19 06:58 AM
BMW Buying Guide: Every Model, Explained
by wemay. 03/25/19 05:43 AM
Double Din Android Auto Advice
by JeffKeryk. 03/24/19 11:25 PM
VW mk5 a/c intermittently works
by ram_man. 03/24/19 11:01 PM
DIY alignment done right?
by tookien. 03/24/19 10:03 PM
Cell phone privacy question
by loneryder. 03/24/19 10:00 PM
Ride quality between 45 and 35 sidewall
by bowlofturtle. 03/24/19 09:23 PM
FRAM TG 7317 - 12K miles opened
by crazy_raccoon. 03/24/19 09:01 PM
2014-2017 Toyota Corolla CVT Quiet Recall
by StevieC. 03/24/19 08:11 PM
Finally Found Factory Ammo my 308 Bolt Gun Likes
by Fastzntn. 03/24/19 08:10 PM
Umarex Glock 19 Co2
by Sonic. 03/24/19 07:57 PM
I put in 2 1/2 qts, damage?
by JLawrence08648. 03/24/19 07:21 PM
How to dispose / recycle Li-Ion batteries?
by 92saturnsl2. 03/24/19 06:16 PM
New member of the (automotive) family!
by addyguy. 03/24/19 06:04 PM
sonusfaber, Rollo, Drifted, Jcar516, gregjr7
67614 Registered Users
81 registered members (beanoil, avi1777, ARCOgraphite, Bailes1992, BeerCan, Berny, 8 invisible), 1,649 guests, and 59 spiders.
Topics286,387
Posts4,907,333
Members67,614
Most Online2,967
Mar 10th, 2019
1999 Malibu No Start but Cranks #4636665
01/16/18 01:36 PM
01/16/18 01:36 PM
Earth
Scienceman Offline OP
Earth
Hello everyone! I am looking to this community for some help. I have a 1999 Chevy Malibu (2.4L) with a crank but no start issue. I know in order for the car to start, it must have fuel delivery and spark. I can hear the fuel pump prime when I turn the key, and the fuel pressure gauge reads 31 PSI when I hook it up. As far as spark, I saw on Scotty Kilmer's YouTube channel a quick method to test that: hook a new spark plug to a spark plug wire and connect power to it. I used my cell phone to record it and saw a tiny spark occurring periodically. I'm trying to save money and not have it towed...can somebody show me what's next?
I do not know of any other issues with the car. It has been well maintained. The only recent service it had was a brake job and new tires from a local shop.
Edit: The battery was purchased around March 2015. I'll put it on trickle charge - cold out - but I think it is ok.
Re: 1999 Malibu No Start but Cranks [Re: Scienceman] #4636682
01/16/18 01:52 PM
01/16/18 01:52 PM
Michigan
slug_bug Offline
slug_bug  Offline
Michigan
Can you check for an OBD code? Might help diagnosis.
2016 Miata 2.0l (15k)
2013 Fusion 2.5l(91k)
2013 Focus(64K)
2010 Linc MKX 3.5l(96k)
2007 Dodge Caravan 3.8l(186k)
2003 Merc. Mountaineer 4.6l(121k)
Re: 1999 Malibu No Start but Cranks [Re: Scienceman] #4636688
01/16/18 01:57 PM
01/16/18 01:57 PM
Earth
Earth
I was hoping someone could think of something obvious before I had to break that thing out. When I plug it in it shows nothing. Any tricks I don't know for a code to appear or am I that unlucky?
EDIT: P0300
Re: 1999 Malibu No Start but Cranks [Re: Scienceman] #4636695
01/16/18 01:59 PM
01/16/18 01:59 PM
Michigan
Greggy_D Offline
Greggy_D  Offline
Michigan
Is there a fuel cutoff switch that might have tripped?
Greggy D.
Re: 1999 Malibu No Start but Cranks [Re: Scienceman] #4636699
01/16/18 02:02 PM
01/16/18 02:02 PM
Earth
Earth
You mean by a bump or minor accident?
Re: 1999 Malibu No Start but Cranks [Re: Scienceman] #4636701
01/16/18 02:03 PM
01/16/18 02:03 PM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
Spark or fuel.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: 1999 Malibu No Start but Cranks [Re: Scienceman] #4636706
01/16/18 02:07 PM
01/16/18 02:07 PM
Earth
Earth
Some more info on the car: It has 263, 085 miles with original everything. Plugs and wires where changed roughly 35,000 miles ago.
Re: 1999 Malibu No Start but Cranks [Re: Scienceman] #4636744
01/16/18 02:36 PM
01/16/18 02:36 PM
Phoenix, AZ
Nick1994 Offline
Nick1994  Offline
Phoenix, AZ
When you checked for spark, did you ground the spark plug on some steel on the engine?
2015 Hyundai Sonata 2.4L 92k STP Synthetic HM 10w30 & Wix
2000 Toyota Camry 2.2L 233k Mobil Super HM 10w40 & Fram Ultra
1996 Jeep Cherokee 4.0L 148k Mobil 1 HM 10w40 & Fram Ultra
Re: 1999 Malibu No Start but Cranks [Re: Scienceman] #4636746
01/16/18 02:39 PM
01/16/18 02:39 PM
Earth
Earth
Hi Nick, yes I did. Any help is appreciated. I guess the car is so old I might just need to look for a new/used car with less than 260K!
Re: 1999 Malibu No Start but Cranks [Re: Scienceman] #4636751
01/16/18 02:42 PM
01/16/18 02:42 PM
Guilford, CT
exranger06 Offline
exranger06  Offline
Guilford, CT
Even though you have fuel pressure at the rail, it's possible the fuel injectors are not firing and therefore you don't have any fuel. You can use a test light to back-probe the wires at the injectors to see if you have power and a signal from the ECM.
2006 Ford Ranger Sport
1992 Honda Accord EX
2013 Toyota Sienna XLE AWD
1994 Ford Bronco XLT (project)
2011 Cadillac Escalade ESV (wife's)
Re: 1999 Malibu No Start but Cranks [Re: Scienceman] #4636762
01/16/18 02:54 PM
01/16/18 02:54 PM
Illinois
carguy996 Offline
carguy996  Offline
Illinois
I had a similar issue with a 2001 Grand Am years ago. Ended up being the PASSKey ignition having random issues. Try leaving the key in the "on" position for 10 minutes, this will reset the PASSKey system and the vehicle might just start. My symptom was a flashing "security" light on the dash when the key was in the "on" position. After 10+ minutes, I believe the light either goes out, or stays steady, at that point it should start.
2018 Nissan Rogue Platinum AWD w/ ProPilot
2014 Honda Odyssey Touring Elite 3.5
2013 Chrysler 200 Convertible 3.6
Re: 1999 Malibu No Start but Cranks [Re: carguy996] #4636771
01/16/18 03:01 PM
01/16/18 03:01 PM
Baltimore, Maryland, USA
zzyzzx Offline
zzyzzx  Offline
+1 for the above comment!
Re: 1999 Malibu No Start but Cranks [Re: carguy996] #4636779
01/16/18 03:09 PM
01/16/18 03:09 PM
Earth
Earth
THIS! THANK YOU!!!!!!!!!!!!!!!
I owe you so much. Left it on for ~10 mins after I read this and it worked. Weird though, my security light never flashed. Will it do it again or is this permanent?
Re: 1999 Malibu No Start but Cranks [Re: Scienceman] #4636784
01/16/18 03:11 PM
01/16/18 03:11 PM
Illinois
javacontour Offline
javacontour  Offline
Illinois
Nevermind....
network down, IP packets delivered via UPS -BOFH
Re: 1999 Malibu No Start but Cranks [Re: Scienceman] #4636794
01/16/18 03:17 PM
01/16/18 03:17 PM
Illinois
carguy996 Offline
carguy996  Offline
Illinois
Mine did it maybe 2-3 times total, just happened at complete random times.
