White or milky cloud in engine oil when cold
by OilUzer. 01/20/19 02:08 AM
Karma Kruiser!
by ekpolk. 01/20/19 01:36 AM
2018 Mazda 3 SkyActive 2.0
by wolf_06. 01/20/19 12:41 AM
Kendall nitro 70
by Bullwinkle007. 01/19/19 11:11 PM
Dexron HP
by Snagglefoot. 01/19/19 11:11 PM
Ruger American 22 Mag
by TiredTrucker. 01/19/19 11:06 PM
Prestone Dex Cool vs Carquest Dexcool
by A_User55555. 01/19/19 11:05 PM
FRAM end cap differences EG and TG vs XG
by wemay. 01/19/19 09:25 PM
Valvoline modern Engine
by Pinoak. 01/19/19 09:02 PM
30 Vintage Photos
by StevieC. 01/19/19 08:23 PM
Low mileage, when to change oil?
by Metfanant. 01/19/19 08:05 PM
Filter with bypass when OEM has built-in bypass
by rubberchicken. 01/19/19 07:43 PM
Barrett Jackson 2019 Pics
by Nick1994. 01/19/19 05:41 PM
What do y'all do with old car parts?
by qdeezie. 01/19/19 05:11 PM
Diagnosing catalytic converters.
by Tlhfirelion. 01/19/19 04:20 PM
Oil recommendations for GM Vortec 8100
by Dudemanmaximus. 01/19/19 04:14 PM
Leaf Spring Questions- Lots of Questions
by George7941. 01/19/19 04:02 PM
Am I being out of line?
by Chris142. 01/19/19 04:00 PM
dougway, Jetsfan421, Fordman420, 72sbc, ejmiller
66982 Registered Users
31 registered members (billt460, claluja, c502cid, Cornershop, carlprop, 4 invisible), 840 guests, and 30 spiders.
Topics296,866
Posts4,960,380
Members66,982
Most Online2,688
Jan 19th, 2019
2015 Honda pilot #4636496
01/16/18 09:42 AM
01/16/18 09:42 AM
Louisiana
millerbl00 Offline OP
Louisiana
Got a 2015 Honda pilot and it pulls right. Tried different tires and the shop I bought it cant correct it. Says is a torque pull. They want to try to shim one motor mount to change the geometry. I trust them been going to them for 25 years and they do frame alignments. No wrecks on this that we can see.
Any one else with a pilot that does this? I drove 4 of them and they all do it. Its a CPO think I should fight the dealership?
thanks
Re: 2015 Honda pilot [Re: millerbl00] #4636517
01/16/18 09:53 AM
01/16/18 09:53 AM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
Pulls right when?
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: 2015 Honda pilot [Re: millerbl00] #4636523
01/16/18 10:01 AM
01/16/18 10:01 AM
Ontario, Canada
mightymousetech Offline
Ontario, Canada
Are you just driving in the right hand lane on the highway? Could be just pull from the crown of the road.
Mighty Mouse Tech
BMW Tech, Former Acura Tech
2010 Civic Si Castrol 0W40, Redline MTL
2013 BMW 135i M Sport Edition Castrol 0W40, Redline MTL
Re: 2015 Honda pilot [Re: millerbl00] #4636524
01/16/18 10:01 AM
01/16/18 10:01 AM
Occupied Virginia
Bottom_Feeder Offline
Occupied Virginia
On the same roads I assume?
Re: 2015 Honda pilot [Re: millerbl00] #4636538
01/16/18 10:18 AM
01/16/18 10:18 AM
Senoia, GA
thooks Offline
thooks  Offline
Senoia, GA
How far are you from Baton Rouge?
If you are within 100 miles, I'd seriously consider going to BR and taking it to AGCO
www.agcoauto.com
Re: 2015 Honda pilot [Re: millerbl00] #4636543
01/16/18 10:22 AM
01/16/18 10:22 AM
Louisiana
Louisiana
Pulls right all the time. yes, this is AGCO saying this
Re: 2015 Honda pilot [Re: millerbl00] #4636560
01/16/18 10:39 AM
01/16/18 10:39 AM
The Northeast
mclasser Offline
mclasser  Offline
The Northeast
My '13 doesn't pull right, except when following the road crown.
I've heard of bad engine mounts causing a pull. Don't know your mileage but VCM is known to prematurely damage the active mount on these trucks. Your shop should closely look at that mount, if they haven't done so already.
2018 Hyundai Elantra VE
2013 Honda Pilot EX-L 4WD
2002 Honda Accord EX-L
Re: 2015 Honda pilot [Re: millerbl00] #4636596
01/16/18 11:12 AM
01/16/18 11:12 AM
N.H, U.S.A.
ARCOgraphite Offline
N.H, U.S.A.
Doe it pull right in neutral?
Make sure rear toe is correct and minimal. Also no total toe-in on the front. You shouldn't see torque steer at low torque cruising. The diff should power the unloaded left front tire following a crown you would think.
2019 VW Jetta S,6M OCI#0 62mi-Castrol Edge Prof VW508+OE Filter; '17 Subaru Crosstrek CVT OC#5 37K mi-SOA/Idemitsu 0w20 + SOA Filter
Re: 2015 Honda pilot [Re: mclasser] #4636602
01/16/18 11:17 AM
01/16/18 11:17 AM
Ontario, Canada
Ontario, Canada
Active mounts are front and rear, should not have any affect except a vibration when VCM is engaged.
Mighty Mouse Tech
Re: 2015 Honda pilot [Re: millerbl00] #4636605
01/16/18 11:21 AM
01/16/18 11:21 AM
Louisiana
Louisiana
Thanks everyone. Bring to dealer.yes does it in neutral.
Re: 2015 Honda pilot [Re: millerbl00] #4636643
01/16/18 12:07 PM
01/16/18 12:07 PM
East Tennessee
Starman2112 Offline
Starman2112  Offline
East Tennessee
Id trust AGCO over the dealer any day of the week.
2018 Toyota Tacoma SR5 / Mobil 1 AFE 0W-20 / OEM filter
2010 Toyota Camry LE / Mobil 1 AFE 0W-20 / OEM filter
1998 Nissan Frontier XE / Castrol GTX HM 5W-30 / M1 filter
Re: 2015 Honda pilot [Re: millerbl00] #4636773
01/16/18 02:04 PM
01/16/18 02:04 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Check the right front brake for sticking either at the piston or pins.
Re: 2015 Honda pilot [Re: millerbl00] #4636904
01/16/18 03:52 PM
01/16/18 03:52 PM
Louisiana
Louisiana
Yes AGCO is the best been going to them 30 years but it has a warranty. Thanks for thinking about brakes. I have them check that
Re: 2015 Honda pilot [Re: millerbl00] #4639658
01/19/18 08:09 AM
01/19/18 08:09 AM
Louisiana
Louisiana
Got it fixed at dealer. The castor is not adjustable. Tech said normally when caster is out they check for frame or strut damage. Turns out it was the strut. Replaced and all good. may be the strut was slightly bent??
thanks
Re: 2015 Honda pilot [Re: mightymousetech] #4639665
01/19/18 08:21 AM
01/19/18 08:21 AM
Ca.
UncleDave Offline
UncleDave  Offline
Ca.
Unless the mount is wasted and then you'll feel it all the time.
UD
Uncle Dave
Cat 3126/2 MB3500/Titan/RX400H/17 Ridgeline
700HP V10/ 725HP BBC/ Raptor 700/ KFX450/ YZ250/Onan 8K/ Cat3011C
