Nissan VQ V-6 Engines
by Al. 09/23/18 04:57 PM
List of dexos licensed oils?
by k1xv. 09/23/18 04:24 PM
High flow oil pump? Thinner oil?
by SnowDrifter. 09/23/18 04:06 PM
Is Tiger back?
by gman2304. 09/23/18 03:51 PM
Castrol Edge Pro OE LLIV FE 0W20 for VW508
by BrandonT. 09/23/18 03:33 PM
Value of 90's stereo equipment
by wrcsixeight. 09/23/18 03:28 PM
Wisdom of BITOG'ers wanted- 19 Avalon Hybrid oil
by scion_xb. 09/23/18 02:36 PM
w116 300sd Mercedes Diesel HPR fuel
by Gito. 09/23/18 02:14 PM
Power Stop Wheel Bearing/Hubs?
by oilpsi2high. 09/23/18 01:37 PM
Dump the 30k ATF in the 17 Kia?
by 3Aone. 09/23/18 01:31 PM
Miata Aisin 6 speed question
by 10ecfarmer. 09/23/18 12:36 PM
Shortest time you owned a car?
by Corollaman. 09/23/18 12:21 PM
Winter tires pinned for studs, but without studs
by Corollaman. 09/23/18 12:12 PM
03 Accord V6 "needs" iridium plugs?
by columnshift. 09/23/18 11:40 AM
03 Accord V6 'brake' light on after brake work...
by columnshift. 09/23/18 11:29 AM
Why does Redline Motor oil quiet lifter noise
by Onetor. 09/23/18 11:11 AM
2017 Hyundai Tucson burning oil (Help!)
by carviewsonic. 09/23/18 11:09 AM
Never waxed ???
by SilverGt. 09/23/18 10:55 AM
The_Money_Light, DALTRON0659, skippermatt, HondaTech250, SandCruzer
66047 Registered Users
92 registered members (Al, BigCahuna, BlakeB, 55hambone, alchargo, 53' Stude, 9 invisible), 1,787 guests, and 41 spiders.
Topics290,899
Posts4,852,122
Members66,047
Most Online3,590
Jan 24th, 2017
After market equivalent to GM superlube #4636286
01/16/18 02:38 AM
01/16/18 02:38 AM
SE British Columbia, Canada
Snagglefoot Offline OP
The GM owners manuals recommend GM superlube for door hinges etc. What are the after market equivalents. Is this a lithium based grease?
SF
If you want the job done right......do it yourself.
Re: After market equivalent to GM superlube [Re: Snagglefoot] #4636298
01/16/18 04:25 AM
01/16/18 04:25 AM
San Antonio, TX
das_peikko Offline
das_peikko  Offline
San Antonio, TX
Superlube is already an aftermarket brand. GM don't own it. And Superlube is a silicone based grease.
Re: After market equivalent to GM superlube [Re: Snagglefoot] #4636324
01/16/18 07:01 AM
01/16/18 07:01 AM
Orlando, FL
Mr Nice Offline
Mr Nice  Offline
Orlando, FL
Superlube can be found on Amazon.
Re: After market equivalent to GM superlube [Re: Snagglefoot] #4636365
01/16/18 08:11 AM
01/16/18 08:11 AM
The product Iím thinking of is called GM Superlube, product 12346421 and lubricates with PTFE. I Ďm assuming itís a rebranded Superlube product. Superlube is a brand name that has a whole range of products. Iíll look for one with PTFE in it. Thanks for the input.
SF
Re: After market equivalent to GM superlube [Re: Snagglefoot] #4636369
01/16/18 08:17 AM
01/16/18 08:17 AM
Yep, found it. Comes in various versions , spray, tube, cartridge. The commonality is that they seem to have a component called Syncolon PTFE. Iím assuming GMís is a spray can.
SF
Re: After market equivalent to GM superlube [Re: Snagglefoot] #4636371
01/16/18 08:19 AM
01/16/18 08:19 AM
The best know PTFE is Teflon which is actually a brand name. This is Teflon lubricant. Dah. And yes, it uses a silicon base as das-peikko mentioned.
SF
Re: After market equivalent to GM superlube [Re: Snagglefoot] #4636395
01/16/18 08:48 AM
01/16/18 08:48 AM
MI
doitmyself Offline
doitmyself  Offline
MI
While the GM product search shows that it recommends use on door weatherstripping, the Super Lube site says their product is NOT compatible with EPDM rubber, a common type found on vehicles. I'm talking about the synthetic lube, not the silicone lube.
Re: After market equivalent to GM superlube [Re: Snagglefoot] #4636412
01/16/18 09:09 AM
01/16/18 09:09 AM
Yes, it seems there is a synthetic oil based lube with Teflon from Superlube and I'm thinking there is also a silicone based lube with Teflon from Superlube. I'll check it out more.
Re: After market equivalent to GM superlube [Re: Snagglefoot] #4636428
01/16/18 09:32 AM
01/16/18 09:32 AM
Checked out the Superlube website and there is indeed products that are synthetic oil with PTFE and products that are silicone with PTFE. Superlube is a brand name with a ton of different lubricants.
Re: After market equivalent to GM superlube [Re: Snagglefoot] #4636458
01/16/18 09:59 AM
01/16/18 09:59 AM
northern NY
Driz Offline
Driz  Offline
northern NY
If youíre puttin it on a GM, particularly a truck itís not so much what you put on but making sure that you keep them oiled VERY WELL. They will still wear out in short order anyway no matter what you do. Big thing is getting the new bushings installed ASAP as soon as you see door sag or it will egg out the hinges mounting hole then you are never going to keep it right. Only welding the pin in place after that. Itís a disturbingly simple process that for some reason everyone avoids, why I donít know.🤦‍♂️ Keep those puppies well oiled or else!
Re: After market equivalent to GM superlube [Re: Snagglefoot] #4638272
01/17/18 11:07 PM
01/17/18 11:07 PM
Here is the AC Delco Super Lube product. Itís part umber 10953474 in Canada and 12346241 in the USA. It cost about $9.00 U.S..
Re: After market equivalent to GM superlube [Re: Snagglefoot] #4638277
01/17/18 11:14 PM
01/17/18 11:14 PM
The components are Polyalphaolefin, White Mineral oil, Antioxidant, Fumed Silicon, Polytetrafluoroethylene (PTFE) better known as Teflon, Polyglycol and Propietary Additives. Says right on the can this is a Superlube Product with Syncolon (PTFE] in it. Keep In mind Superlube makes a whole line of products.
SF
Re: After market equivalent to GM superlube [Re: Snagglefoot] #4638282
01/17/18 11:16 PM
01/17/18 11:16 PM
This is the product GM wants you to use to lubicate the hood and door hinges, liftgate hinge, hinges on folding seats and the fuel door. GM says you can put it on weatherstripping to cure squeaks.
SF
Re: After market equivalent to GM superlube [Re: das_peikko] #4638288
01/17/18 11:19 PM
01/17/18 11:19 PM
Superlube is a brand name and has a whole range of products. The silicone based lubricant is just one.
Re: After market equivalent to GM superlube [Re: Snagglefoot] #4641161
01/20/18 05:56 PM
01/20/18 05:56 PM
I tried out the GM Superlube on the hinges of my trunk. When I hit the fob the trunk would pop then move up 6 inches.I would raise it and hear a bit of a squeak. I used the product on the hinges. It comes out as a clear fluid and the carrier quickly evaporates. Got a bit on my hand and it dried leaving a very slippery "teflon" layer. Anyway, now when I hit the fob the trunk pops opens fully to the max with no squeak. Great stuff.
SF
