VW Passat R36 504 00/ 507 00 oil
by antik. 03/23/19 04:43 AM
Oil for 2015 Ford Explorer
by oilnut12. 03/23/19 12:48 AM
Blains farm and fleet citgo syn
by BTLew81. 03/22/19 10:48 PM
2003 Duramax 208, XXX miles Rotella T4
by TurboJW. 03/22/19 08:11 PM
Turn signals on the freeway?
by das_peikko. 03/22/19 08:05 PM
Running Boards Restored
by kstanf150. 03/22/19 07:38 PM
QSUD at Canadian Tire
by Snagglefoot. 03/22/19 07:29 PM
Camry vs Accord vs ???
by Joe1. 03/22/19 07:26 PM
Fire up
by Matagonka. 03/22/19 07:16 PM
Mobil-1 AFE Discounted at Sam's Club
by ekpolk. 03/22/19 06:20 PM
Test drove a Tesla Model 3
by y_p_w. 03/22/19 05:54 PM
Did i make a mistake? Hilux 3.0 d4dhello
by Anton93. 03/22/19 05:52 PM
WM Valvoline Full Syn Modern Eng Clearance
by Spartanfool. 03/22/19 04:22 PM
Need Moly basic training
by Bill_W. 03/22/19 04:03 PM
P0420 code goes away in warmer weather
by 2010Civic. 03/22/19 03:54 PM
Customer declined new belt
by Chris142. 03/22/19 03:13 PM
How to deep clean back of wheels?
by qdeezie. 03/22/19 02:51 PM
RK oil sale T4 15w40
by 1978elcamino. 03/22/19 01:57 PM
duradick, Harold1031, Skendread, NGK, Thomas1
67589 Registered Users
30 registered members (4WD, A1O, antik, billt460, bfleeman, ctechbob, 4 invisible), 497 guests, and 57 spiders.
Topics286,267
Posts4,905,521
Members67,589
Most Online2,967
Mar 10th, 2019
Page 1 of 3 1 2 3
Does wrapping pipes do any good? #4636142
01/15/18 09:05 PM
01/15/18 09:05 PM
Houston, Texas
motor_oil_madman Offline OP
Houston, Texas
I've never understood this. Keeping it out of the wind isn't going to keep it warmer. This goes back to that engineering 101 thing where wind chill wont cool something cooler than ambient air temp.
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
Re: Does wrapping pipes do any good? [Re: motor_oil_madman] #4636146
01/15/18 09:11 PM
01/15/18 09:11 PM
Leamington, ON, Canada ..... r...
Papa Bear Offline
Papa Bear  Offline
Does putting on a blanket on a cool evening keep you warm?
2016 Dodge GC Deep Cherry 5W-30 Dino
2013 SYM Wolf Classic 150 T4 15W-40
2009 V-Star 250 Black Cherry 20W-50 Dino
https://www.hogsforhospice.com/
Friend of Bill W. since '89
Re: Does wrapping pipes do any good? [Re: motor_oil_madman] #4636147
01/15/18 09:11 PM
01/15/18 09:11 PM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
Works here where it does not get that cold. Mid 20s or so. Once into the teens they freeze anyway.
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: Does wrapping pipes do any good? [Re: motor_oil_madman] #4636148
01/15/18 09:12 PM
01/15/18 09:12 PM
Houston, Texas
Houston, Texas
Yes but I'm a human. A pipe isn't going to create it's own heat.
Re: Does wrapping pipes do any good? [Re: motor_oil_madman] #4636154
01/15/18 09:19 PM
01/15/18 09:19 PM
Maryland
walterjay Offline
walterjay  Offline
Maryland
Just remember that if the pipe freezes with insulation on it, the icey pipe is insulated and will take longer to thaw. Pipe insulation may slow down freezing but just try to keep the area above 32. And seal areas where wind can get in.
Re: Does wrapping pipes do any good? [Re: motor_oil_madman] #4636156
01/15/18 09:21 PM
01/15/18 09:21 PM
New England
madRiver Offline
madRiver  Offline
New England
Wrapping pipes is typically done for insulation from freezing or in my basement helps with heat loss,
I wil flip the question back, does insulation in your home help?
Re: Does wrapping pipes do any good? [Re: motor_oil_madman] #4636157
01/15/18 09:21 PM
01/15/18 09:21 PM
Illinois
mrsilv04 Offline
mrsilv04  Offline
Illinois
I was required to cover the exposed plumbing in my garage, by the local building inspector. Apparently there's something to it.
2004 Silverado - on its 3rd Jasper engine in less than one year.
Re: Does wrapping pipes do any good? [Re: motor_oil_madman] #4636158
01/15/18 09:22 PM
01/15/18 09:22 PM
Ruidoso, NM USA
ammolab Offline
ammolab  Offline
Ruidoso, NM USA
The pipe and its contents are connected to warmer areas: the ground, your house, the water heater etc. the insulation keeps the heat loss down within the pipe from these areas and yes, can prevent freezing.
2009 Honda CR-V
2011 BMW R1200R
2005 Kaw Ninja 250
1994 Jeep Wrangler 2.5L
2016 Chevy SS Sport Sedan
Re: Does wrapping pipes do any good? [Re: motor_oil_madman] #4636160
01/15/18 09:23 PM
01/15/18 09:23 PM
Illinois
tig1 Offline
tig1  Offline
Illinois
If you have a problem with freezing pipes, then wrap the pipe with heat tape and then cover that with pipe insulation. That will protect the pipe down to below zero.
2007 Ford Fusion 239,000 miles
M1 0-20 EP
2017 Ford Fusion 67K
M1 0-20 EP
M1 ATF and Valvoline LV
M1 10-30 in all OPE
MC filters
Re: Does wrapping pipes do any good? [Re: motor_oil_madman] #4636165
01/15/18 09:26 PM
01/15/18 09:26 PM
US-WA
Dyusik Offline
Dyusik  Offline
US-WA
Wind chill refers to loss of heat over time, not final temperature. So, yes, insulation will lower the chilling factor, wind or not.
95 Cherokee 190K DELO 10W30, XG8
07 IS250 106K STP syn HM 10w30, FULL
04 YZF-R1 19K DELO 15w40, XG7317
99 HD XL1200S 21K VR1 20w50, NG1515
14 RX450h 40k Idemitsu 0w20, 57047
Re: Does wrapping pipes do any good? [Re: madRiver] #4636192
01/15/18 10:05 PM
01/15/18 10:05 PM
Lima, Ohio, USA
earlyre Online sleepy
earlyre  Online Sleepy
Lima, Ohio, USA
yes, before we wrapped the hot waterlines in the basement, it would take what felt like minutes to get hot water to the kitchen sink, or the master bath(opposite ends of the house, heater in the middle)
now, it can still take 30 seconds, but... it's much... faster....
Mine:
13 Ford C-MAX hybrid: MC 5w20, & FL910s (in theory)
Re: Does wrapping pipes do any good? [Re: motor_oil_madman] #4636198
01/15/18 10:13 PM
01/15/18 10:13 PM
South Carolina
eyeofthetiger Offline
South Carolina
I love my insulated pipes. I just did all of them two weeks ago.
2017 Ford Fiesta 1.0T - Valvoline SynPower 5W-20, Motorcraft FL910S
1988 GMC K1500 4.3/700R4 - Supertech 15W-40, Fram TG3980
1986 Ford Ranger 2.0 - uhh
Re: Does wrapping pipes do any good? [Re: tig1] #4636199
01/15/18 10:13 PM
01/15/18 10:13 PM
Katy, Republic of Texas
blupupher Offline
blupupher  Offline
It is a "problem" here once every 2-3 years.
Houston will be below freezing for almost 36 hours starting tomorrow morning, which is a long time here.
Most homes here have water service coming up out of the ground and entering the house on the outside of the house.
There is usually a 2-3 foot section of pipe that has no insulation at all, just a bare metal pipe.
Insulating the pipe allows the pipe to hold the heat within it better, increasing the amount of time it takes it to freeze.
Same reason some leave a faucet dripping, keeps "warmer" water flowing through the pipe, reducing the chance of freezing.
Me personally, I have foam insulation around outside exposed pipes for most cold nights, then when it is really cold (like the next 2 days) I take a shop light (an old school incandescent, not LED) and hang it from the spigot, wrap a towel around it, and cover it with a box. Temp stays in the mid 50's in there (have a remote thermometer I stuck in it last time) even in the mid 20's.
When I was a kid, my dad would turn the water off then drain all the pipes that run in the attic.
Re: Does wrapping pipes do any good? [Re: blupupher] #4636206
01/15/18 10:20 PM
01/15/18 10:20 PM
Illinois
tig1 Offline
tig1  Offline
Illinois
I know someone that protects their incoming water line in their 32 ft camper they live in year round here in Illinois. The heat tape-pipe insulation deal works great for them. We have had several nights this winter well below 0 F with no problems with pipe freeze up.
Re: Does wrapping pipes do any good? [Re: motor_oil_madman] #4636214
01/15/18 10:37 PM
01/15/18 10:37 PM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
If for example its a baseboard heating pipe going through an unheated crawl space, then wrapping the pipe will prevent heat loss and the hot water will arrive hotter at the baseboard.
2015 Ford F250 w/Powerstroke
Page 1 of 3 1 2 3
