Planes fly over white house after speech
by 1978elcamino - 07/04/20 10:16 PM
Code reader advice
by 53' Stude - 07/04/20 10:05 PM
People driving less / motor oil prices?
by 1978elcamino - 07/04/20 10:02 PM
Fireworks and dogs
by 555 - 07/04/20 07:52 PM
Cannot unscrew oil filter housing cap - BMW E46
by 97tbird - 07/04/20 07:21 PM
Are u a big fireworks person?
by ZZman - 07/04/20 06:53 PM
Honda Accord MAP sensor question
by Kira - 07/04/20 06:28 PM
Hy-Gard Shelf Life (Opened Bottle)
by viscous - 07/04/20 06:10 PM
Want to bet on my luck? (atf to "save" transmission)
by Snoman002 - 07/04/20 06:10 PM
Too Much Zinc = Corrosion?
by viscous - 07/04/20 06:00 PM
New vehicles with a 4 speed transmission?
by MrHorspwer - 07/04/20 04:57 PM
Inability to Choose
by Gene K - 07/04/20 01:53 PM
65 200 6 mustang running kinda hot
by old1 - 07/04/20 01:30 PM
Neo-protec GT em
by dervdave - 07/04/20 01:19 PM
Mannol 9929 Ester additive
by dervdave - 07/04/20 01:14 PM
2015 Corolla with 7k miles has “soft brakes”
by NHBFAN - 07/04/20 12:30 PM
Put Bilsteins on the Silverado
by bdcardinal - 07/04/20 12:19 PM
SilentC, paolo9fla, SunnyB, Mullady76, Axia2
71848 Registered Users
64 registered members (2009Caraman, Barwich, ammolab, 53' Stude, 911Don, Antigen, 2 invisible), 1,037 guests, and 24 spiders.
Topics307,436
Posts5,311,012
Members71,848
Wax Rings on Toilets, how long do they last? #4635954 01/15/18 06:00 PM
5
5AcresAndAFool Offline OP
5
I have replaced a number of wax rings over the years that have failed in places I have lived or for family or friends and I was wondering if anyone preemptively replaces them? I would think that if a toilet is setting on a firm surface such as concrete and it is seated perfectly, that they would never go bad.
As we know there is rarely a perfect situation though. There is always usually some unnoticed minute movement somewhere when getting up and down off the toilet, over time this "wears" the wax ring or the wax ring simply hardens to the point it is no longer effective.
I installed the toilet I am concerned about 9 years ago and have no issues. The floors in my house are nowhere near the most solid and sometimes when you sit down on the toilet or walk in the right spot on the floor you get a pop or creak, so there obviously is some movement, even if you cant feel it or see it. (I am not talking about a toilet that rocks or a spongy floor, just your typical creaks and pops of an older house)
I am wondering if I should pull the toilet and put a new wax seal down. I really dont want to wait until it becomes an issue and rots the floor out. There is a gap in the caulk behind the toilet to see if any water were to run out, but in my experience a wax ring failure usually starts so small and goes on for so long it is a long time until you discover the damage.
So what is the general lifespan of wax rings in your experiences? I always use Harveys IIRC, and I get the ones with the funnel built in. I have never had one I have replaced fail, but this is the longest I have ever had one in service that I replaced.
10,15,20 years? Research I have seen says on a heavily used toilet that 5 to 10 years could be expected, but in some cases they last indefinitely.I think the one on the toilet in our basement is 40 years old and original, but I have no way of knowing, but that toilet sits on concrete and rarely gets used.
The other thing is that I have seen wax-less seals in the home improvement stores recently. Has anyone ever used one of these? Are they better? Worse? indifferent? I would think they would hold up better to any movement, but who knows.
My thought is just to change it, its easy enough, and cheap enough. If I do change it I am toying with the idea of a wax-less, but might go with what has always worked for me.
Re: Wax Rings on Toilets, how long do they last? [Re: 5AcresAndAFool] #4635958 01/15/18 06:04 PM
demarpaint Offline
I've got two of them going on 20 years here. In fact in 35 years of home ownership I never had to replace one. I've owned houses with toilets and wax seals a lot older than 20 years.
God Bless Our Troops
Re: Wax Rings on Toilets, how long do they last? [Re: 5AcresAndAFool] #4635962 01/15/18 06:06 PM
supton Offline
Can you look up from the basement?
I look up periodically at mine, family of four, and it's been 13 years now without touching. No idea how long it has been untouched. All PVC, new tile floor on a decent substructure, so maybe that matters.
Edit: now furnace parts, those seem to go often. Expansion tank and the valves that let air out. 5-7 years on those parts it seems.
2011 Toyota Camry, base, 2.5L/6MT, 206k
2010 Toyota Tundra DC, 4.6L/6AT, 160k
2003 CRV, 2.4L/4AT, 161k
1999 Toyota Camry LE, 2.2L/4AT, 225k
Re: Wax Rings on Toilets, how long do they last? [Re: 5AcresAndAFool] #4635964 01/15/18 06:07 PM
T
totegoat Offline
T
Usually last until the toilet needs replacing.
Re: Wax Rings on Toilets, how long do they last? [Re: supton] #4635965 01/15/18 06:08 PM
5
5
No, I left that important detail out... Its on the second floor. I put in retrofit can light a few years ago and seen up in there, but I dont remember if I could see the drain pipe, I thought I could but not sure.
The pipes are 40yo PVC. Toilet sits on the floor nicely.
Re: Wax Rings on Toilets, how long do they last? [Re: 5AcresAndAFool] #4635973 01/15/18 06:16 PM
PimTac Offline
The only time Ive replaced the wax ring is when I pulled the toilet. Generally they last a lifetime.
2017 Mazda CX5
Mobil 1 Annual Protection 0w20
Roki OEM filter.
Re: Wax Rings on Toilets, how long do they last? [Re: 5AcresAndAFool] #4635984 01/15/18 06:25 PM
W
Wheel Offline
W
I just pulled up our 2 johns to install new flooring. They were put down in 1985, both were good. Both my parents have ones older than that that are good still. I think it depends on how much movement there is between the john and the plumbing. I'd love to know why exactly they fail.
2009 Subaru Legacy (N/A)
Quaker State Ultimate Durability and NAPA filter
Re: Wax Rings on Toilets, how long do they last? [Re: 5AcresAndAFool] #4635986 01/15/18 06:27 PM
Bud Offline
I had to pull one of my toilets about three years ago and went with a waxless ring. Much prefer it over a wax ring.
2016 Honda Pilot EX-L with NAVI.....Mobil 1 0w20 AFE and Honda OEM Filter
Re: Wax Rings on Toilets, how long do they last? [Re: 5AcresAndAFool] #4635987 01/15/18 06:31 PM
P
Panzerman Offline
P
I am remodeling the bathrooms now. The one toilet is over 40 years old. No leaks ever.
I always assumed they last a lifetime.
2006 Dodge Ram 2500 Hemi 4x4
2016 Dodge Challenger Scat Pack
Re: Wax Rings on Toilets, how long do they last? [Re: 5AcresAndAFool] #4635989 01/15/18 06:31 PM
JohnnyJohnson Online Content
Online Content
Just about totally dependent on how well (level) they are installed. I've had the last form ten minutes to a lifetime.
2004 Corolla 140560
Out: Pennzoil Platinum HM 5W-20 ST 4386
In: Valvoline Synpower Full Synthetic 5W-30 Purolator PureONE
2006 Duramax 77117
Out: T6 5W-40 XG9100 73909
In: Rotella Dino PH9100 11-3-19
Re: Wax Rings on Toilets, how long do they last? [Re: 5AcresAndAFool] #4636000 01/15/18 06:47 PM
W
wha232 Offline
W
I just saw a "this old House" episode where they used a foam/rubber ring.
Re: Wax Rings on Toilets, how long do they last? [Re: wha232] #4636005 01/15/18 06:52 PM
J
JLawrence08648 Offline
J
I saw the same episode! Never knew they existed. My local plumbing supply says plumbers never ask for them. I use the wax rings with the black funnel. Wax rings also come in two thicknesses. Without removal or movement, they last forever.
2019 Hyundai Santa Fe SEL Plus, 2.4
1992 Acura Vigor GS, 2.5
Re: Wax Rings on Toilets, how long do they last? [Re: JLawrence08648] #4636020 01/15/18 07:09 PM
clinebarger Offline
Bingo! The toilet has the be secured to the floor!!! Though my brother weighs over 350# & is constantly having wax ring issues because of the stress he puts on the base, He has problems with a lot of things because his weight.
2001 Chevy Camaro L92/4L80E
Re: Wax Rings on Toilets, how long do they last? [Re: 5AcresAndAFool] #4636035 01/15/18 07:17 PM
E
ecotourist Offline
E
It might also depend on the installation. In my recent renovations I had a toilet pulled for replacement. There were 3 stacked wax rings under it and it had leaked at some time in the past leaving a bit of rot. The plumber said he'd never seen 3 seals used before. After repairing the floor and raising the flange, we decided we'd better check the others.
A second toilet had 2 stacked seals but had not leaked. Another flange to raise.
The third toilet (on the second floor) had only one seal and hadn't leaked.
When you renovate you always have a few surprises. Usually expensive ones. But I think these wax seals are good now!
I've only ever had one other seal leak. That was in my last house when it was about 10 years old. It presented as discoloration of the lino around the toilet. I pulled out the toilet in anticipation of putting in ceramic tiles and found it pretty damp under there. I let it dry for several days and again did a bit of plywood repair.
2000 BMW 528i 5MT M Sport
2007 Honda Accord EX-L 4Door V6 6MT
Re: Wax Rings on Toilets, how long do they last? [Re: 5AcresAndAFool] #4636045 01/15/18 07:33 PM
PimTac Offline
Im wondering if the rubber seals are made for certain circumstances like very overweight people or commercial use? The toilet wont move if its bolted down correctly. That starts with the flange being installed correctly too. I saw one installation where the flange was nailed into the plywood subfloor. Ten years later it leaked and I helped this friend fix it.
Also, builders who use chipboard in bathrooms dont care about the future. Any water that hits it weakens the stuff and the toilet starts to wiggle thus another leak. Ive seen that as well.
2017 Mazda CX5
Roki OEM filter.
