Decent MP3 player
by Ed_T
06/24/18 07:08 PM
Letgo
by Donald
06/24/18 06:52 PM
Tire buying advice
by supton
06/24/18 06:23 PM
Two versions of M1 5w30 ESP now?
by Patman
06/24/18 06:21 PM
No older cars in New York State?
by Oldtom
06/24/18 06:19 PM
2009 Taurus strut mount noise
by terry274
06/24/18 04:38 PM
A3/B3 vs A3/B4, big difference or irrelevant?
by FordCapriDriver
06/24/18 03:36 PM
2003 Honda power steering problem
by hogpops
06/24/18 03:29 PM
Public Service Announcement: Flush Your HW Heater
by gathermewool
06/24/18 03:25 PM
Fellow 2AZ-FE toyota owners: what oil are you usin
by car51
06/24/18 03:21 PM
Castrol 0W40 vs 5W40??
by Realfine69
06/24/18 03:02 PM
Paint impurities on a new car
by Quattro Pete
06/24/18 02:49 PM
2014 Ram wheel FIT on a 2005 Ram?
by SumpChump
06/24/18 02:41 PM
Do people buy from telemarketers?
by Chris142
06/24/18 02:06 PM
TGMO 0W20, 8100km/5mo, 2013 Lexus GS350AWD 118K KM
by David_Corbett
06/24/18 01:54 PM
Sonoma Raceway
by Warstud
06/24/18 01:51 PM
Zipcode error
by aquariuscsm
06/24/18 01:36 PM
NHRA drag racing Racing question??
by daddi
06/24/18 01:33 PM
Milesyn 5w30 5 gal pails $50.94 w/prime
by Samrsnow
06/24/18 01:20 PM
Removing Broken Bathtub Drain
by Warstud
06/24/18 01:15 PM
crrider, EdDmax, 2018matto, Lancruza, IanSampson
65312 Registered Users
102 registered (55hambone, Berny, aquariuscsm, A310, 69Torino, 2015_PSD, 8 invisible), 1613 Guests and 41 Spiders online.
65312 Members
67 Forums
285932 Topics
#4635995 - 01/15/18 05:40 PM 3.0 Ranger Timing Cover Gasket
mobilaltima Offline
Loc: Golden Meadow, LA
Well, the infamous coolant leak that the 3.0 Vulcan is known for has gotten worse on my Ranger, it leaks a good bit now every time the truck is shut off and sits for a while. Including all new gaskets required, crank seal, water pump etc, I have $80 invested so far, versus $700 that a local shop wanted to charge. My dad and I will tackle it as soon as the weather gets warmer, we've had a pretty cold winter which is rare down here.
I do have a few questions. Ive heard that there are two bolts, I think behind the power steering pump that need to come off that are very hard to get to....anyone know if I'm referring to the correct bolts and if theres an easy way to access them? Also, two bolts from the oil pan go into the timing cover, I've heard that tearing the pan gasket is almost inevitable, but most people use silicone around that area and that stops any oil leaks....anything I can do to prevent it from tearing? Is the fan clockwise or counterclockwise to loosen? also what is the torque spec for the crank pulley bolt? Thankfully, I have a friend who has a truck with an air compressor, so i'll be able to zip off the crank bolt, but trying to torque it on installation i'm wondering if theres a special tool to hold it steady. I also know to use thread sealer on the timing cover and water pump bolts, as they protrude into water jackets. Anything I'm missing here guys? My dad and I would like to finish it in a day.
2006 2500 Dodge 5.9 Cummins Mobil Delvac 15W40, Fleetguard Stratapore 90k miles
Early '99 F250 ECLB 7.3 Stroker, 223k miles
#4636071 - 01/15/18 06:52 PM Re: 3.0 Ranger Timing Cover Gasket [Re: mobilaltima]
01rangerxl Offline
Loc: Birmingham, AL
The pan gasket can supposedly be changed by loosening the pan with the engine in place, haven't done that repair myself.
The fan clutch is reverse thread, so go clockwise to loosen. You'll need to loosen the A/C compressor, not sure what else. I haven't had to deal with the timing cover yet, just the water pump.
2002 Ford Ranger XLT | 3.0 V6 / 5-Speed Automatic / 2WD | 211K miles
1994 Ford Ranger STX | 4.0 V6 / 5-Speed Manual / 4X4 | 198K miles
#4636088 - 01/15/18 07:12 PM Re: 3.0 Ranger Timing Cover Gasket [Re: mobilaltima]
04SE Offline
Loc: IL
Did this nightmare on my 2004 Taurus (hence my screen name) in 2010 or 2011. I fixed the coolant leak but had a small oil leak afterwards. I never could get that pan to seal 100% again. My timing cover was pitted all to heck. I had to get a new cover as well.
The pan gasket was hard molded plastic with rubber on my car, sure don't remember it being possible to tear (best I can remember).
I had to press a new gasket into the new timing cover for the crank to pass through.
We didn't torque the pulley, just impacted it off with puller and impacted it on with it's own bolt. I think it was keyed, I just can't remember.
Has your oil pump drive/distributor shaft gone out yet? That was a blast too.
On my car the pan would not clear the oil pump. I pulled the pump and then it wouldn't clear the exhaust.
Life's little problems can be solved with a shovel and silence.
#4636109 - 01/15/18 07:27 PM Re: 3.0 Ranger Timing Cover Gasket [Re: mobilaltima]
mobilaltima Offline
I had my cousin change the cam synchronizer (oil pump drive) when I bought the truck 28k miles ago at 132k. I'll have it changed again at 200k for peace of mind.
#4636202 - 01/15/18 09:17 PM Re: 3.0 Ranger Timing Cover Gasket [Re: mobilaltima]
Inspecktor Online   content
Loc: Twin Cities MN USA
Mine was rear ended,bending frame. It still drives, but am running it until major repair sends it to junkyard. So when my cover started to leak, I used some GM pellets which stopped the leak. It's been over a year and 11,000 miles since with no recurrence yet.
2001 Ranger 3.0 151,000 mi
2006 Dakota 4.7 153,000 mi
1986 GL1200A 72,000 mi
2001 Buick LeSabre Limited 291,000 mi
#4636367 - 01/16/18 07:13 AM Re: 3.0 Ranger Timing Cover Gasket [Re: mobilaltima]
rshaw125 Offline
Loc: Raleigh ,NC CSA
Did my Taurus several years ago. The rear head gasket likes to leak on these as well. The timing cover is aluminum and will have some pitting. RTV black yields a permanent repair.
2012 Porsche Carrera S
2016 Ford Edge 2.0
2002 Taurus Vulcan SOLD
2006 Explorer SOLD
#4636418 - 01/16/18 08:19 AM Re: 3.0 Ranger Timing Cover Gasket [Re: mobilaltima]
MasterSolenoid Offline
Loc: One Step Beyond
You have my sympathy.
My 2002 Ranger developed the leak:
1) June 2011 / had fixed at Dealer ($900).
I tried to repair it myself but was just too much work for only myself.
2) May 2016 / had fixed at Indy Mech ($800)
Jan 2018 / leaking again
At 16 yo and 146,000 miles, I will junk before anymore high cost repairs.
Last Week I put in Bars - Stop Leak (TABLETS) ,,,,,, So Far So Good.
I'm not a fan of 'additives' but if leak comes back, I may try another (more aggressive) additive and then call it quits.
The Bars - Stop Leak TABLETS seemed harmless.
Do some research, you may want to use them until you do the permanent repair.
Good luck.
