Any news on what happened to this plane?
by Exhaustgases
6 minutes 20 seconds ago
E4OD fluid ?
by Exhaustgases
18 minutes 57 seconds ago
Update password ?
by meadows
Yesterday at 11:59 PM
Delayed Sleep Phase Disorder
by Reddy45
Yesterday at 11:56 PM
Nissan DLR put 0w20 in car that specs 5w30. worry?
by CrAlt
Yesterday at 10:40 PM
revive Nicd battery
by Donald
Yesterday at 10:27 PM
Need help finding an apartment for friend
by RazorsEdge
Yesterday at 10:07 PM
ceratec with redline 5w30?
by 08z06
Yesterday at 09:53 PM
does your COMCAST modem have weak wifi??
by edwardh1
Yesterday at 09:50 PM
I hate stuck thermostats
by jakewells
Yesterday at 09:49 PM
Mag1 75w90
by SavagePatch
Yesterday at 09:32 PM
Old batteries at HD
by bbhero
Yesterday at 09:27 PM
Buying a CPO Toyota - still get inspected?
by Parlay_Slow
Yesterday at 09:08 PM
Water Pump Paper Gasket With RTV? Longevity?
by nobb
Yesterday at 08:22 PM
Who makes Briggs & Stratton oil?
by spk2000
Yesterday at 08:13 PM
Shure stylus replacement
by aquariuscsm
Yesterday at 07:54 PM
Any 'crazy UCL overdose' fans out there?
by addyguy
Yesterday at 07:11 PM
Source for Castrol Edge Supercar 5w50 oil?
by Rainier42
Yesterday at 06:50 PM
Cherry vs orange hand cleaner
by JHZR2
Yesterday at 06:27 PM
Why buy low mileage tires?
by HowAboutThis
Yesterday at 05:49 PM
mostdecent, T1TN, Piper58, dunlop0078, Truth_Syrup
65258 Registered Users
19 registered (bismic1, CleverUserName, AMC, Exhaustgases, dishdude, ctechbob, 2 invisible), 720 Guests and 39 Spiders online.
65258 Members
67 Forums
285504 Topics
Page 1 of 2 1 2 >
#4635953 - 01/15/18 04:56 PM Honda Type 2.0 ATF?
digitalSniperX1 Offline
Loc: FL
Did a search in here and to my surprise, I found nothing. Or just maybe the search tool is a bit behind the times.
I searched the web a bit too.
So sorry in advance if this topic has been discussed, but what info have yall collected on this new ATF recommended for Honda 10-speed transmissions?
And thanks in advance for any useful information.
'18 Honda Accord 2.0t-Mobil 1-EP 0w20
'18 Toyota Highlander-Mobil 1-EP 0w20
'12 Honda NC700X T6
'14 Kawasaki ZX-14R Yamalube 15w50
#4636063 - 01/15/18 06:46 PM Re: Honda Type 2.0 ATF? [Re: digitalSniperX1]
slacktide_bitog Offline
Loc: USA
The bottle says shake well before using, which doesn't often appear on bottles of motor oil and ATF. The bottle looks like a WPP bottle crzy
However, you should probably still use the Type 2.0 during the warranty. When does Honda recommend the first ATF change be done? Because by the time you'll actually need to change it, a cheaper aftermarket solution should exist, and/or the aftermarket ATF's will be updated to include Type 2.0
Is that 10-speed a DCT? I saw this page from Acura mentioning a DCT that uses the 2.0
If it's a DCT, you can probably use AMalie's DCT fluid, which is by far the least expensive DCTF and sold by the case of 12.
#4636096 - 01/15/18 07:16 PM Re: Honda Type 2.0 ATF? [Re: digitalSniperX1]
Loc: FL
Exactly what I was thinking. Use the Honda fluid through warranty. In a year or two, another company will have a compatible fluid. What Im going to do with the DW-1 stash I have is TBD.
'12 Honda NC700X T6
#4636121 - 01/15/18 07:36 PM Re: Honda Type 2.0 ATF? [Re: digitalSniperX1]
Loc: USA
Do you have any friends with an older Honda automatic? You can use it on any older Honda automatic that called for DW1, Z1, or Dexron. Supposedly, you can't use it in your Highlander or any other non-Honda automatic because it has too much Zinc
#4636127 - 01/15/18 07:44 PM Re: Honda Type 2.0 ATF? [Re: digitalSniperX1]
Loc: FL
Yeh I thought about that but none of the Honda owner fiends would get their hands dirty changing out transmission fluid, haha.
'12 Honda NC700X T6
#4636163 - 01/15/18 08:25 PM Re: Honda Type 2.0 ATF? [Re: slacktide_bitog]
Loc: FL
Sorry in my haste I did not answer your question. This is not a dual clutch design. It has several planetary gear modules. Having same said that, irrespective of the transmission architecture, this transmission operates superbly. Nearly imperceptible shifts while simultaneously shifting very quickly. Honestly, its amazing. In comparison the Highlander 8spd transmission while certainly not bad, is not in the same league as the 10spd in the Accord.
'12 Honda NC700X T6
#4636256 - 01/15/18 11:19 PM Re: Honda Type 2.0 ATF? [Re: digitalSniperX1]
Marco620 Offline
Loc: Deplorable Kansan,HK fan!
I think this stuff is pretty expensive per qt but its still cheaper than a transmission. Now I remember back when BMW had the 8spd tranny. Can't wait to hear about this new 10spd Accord. How exciting
2015 Civic 162k mi.0w20 Redline/Archoil,HPS SRI,Yokohama/Moog links Borla Exhaust/Vibrant Resonator/Tein Suspension
Go Nashville Predators!
#4636932 - 01/16/18 04:18 PM Re: Honda Type 2.0 ATF? [Re: digitalSniperX1]
mightymousetech Offline
Loc: Ontario, Canada
Type 2.0? I thought that was for the DCT only. I thought the newer 9 and 10 (made by ZF) speed all used Type 3.1?
Edited by mightymousetech (01/16/18 04:27 PM)
Mighty Mouse Tech
Acura Tech
2010 Civic Si Castrol 0W40, Redline MTL
2013 BMW 135i M Sport Edition Castrol 0W40, Redline MTL
#4636956 - 01/16/18 04:45 PM Re: Honda Type 2.0 ATF? [Re: digitalSniperX1]
Loc: USA
I believe ATF is tied to the MM, so just change it when the computer tells you to. Most modern ATF intervals are fairly long, so you don't need to stock up on it now. Simply wait until the applicable code shows up on your MM smile
#4637440 - 01/17/18 07:33 AM Re: Honda Type 2.0 ATF? [Re: slacktide_bitog]
Good recommendation. It is quite an expensive service on the ZF boxes. The 3.1 fluid is almost $40/L, then you also have to replace the 3 fill/drain/level plugs at $15 each. It is also more complicated than just drain and fill. Here at Acura, it is around a $500 service, takes us about 2 hours.
Edited by mightymousetech (01/17/18 07:38 AM)
Mighty Mouse Tech
Acura Tech
#4637689 - 01/17/18 12:26 PM Re: Honda Type 2.0 ATF? [Re: mightymousetech]
gogozy Offline
Loc: GTA, Ontario, Canada
wasn't there a study that reveal the most transmission's wear occurred before 8000 miles? the Honda 9AT is made ZF, 10AT is a Honda in house. 7 and 8 speed is DCT.
#4637901 - 01/17/18 04:39 PM Re: Honda Type 2.0 ATF? [Re: gogozy]
The new 10 speed is in house? Good to know. The ZF 9 speed are a PITA. Looks like we are getting the 10 speed in the new RDX, will see what is what then I guess.
Mighty Mouse Tech
Acura Tech
#4637988 - 01/17/18 05:47 PM Re: Honda Type 2.0 ATF? [Re: mightymousetech]
PandaBear Offline
Loc: Silicon Valley
$15 each plug? It can't be reused with a new washer?
"You keep asking questions PandaBear and you'll end up a vegetarian like my wife" - Camu Mahubah
#4638268 - 01/17/18 10:00 PM Re: Honda Type 2.0 ATF? [Re: PandaBear]
The Critic Offline
Loc: CA
Very common on Euro cars- new plugs are required. The plugs have a one time use sealant on them.
2011 Toyota Prius - 168k - ServicePro Dexos 0W-20
2007 Honda Accord 2.4 - 128K - Idemitsu 5W-20
#4638508 - 01/18/18 08:11 AM Re: Honda Type 2.0 ATF? [Re: PandaBear]
They use the same kind of plugs as a BMW. Single use. Do not use a washer.
They look like this.
Mighty Mouse Tech
Acura Tech
Page 1 of 2 1 2 >
