Offset
by jcartwright99. 04/18/19 04:07 PM
Honda Camera Design...FAIL
by Sayjac. 04/18/19 04:02 PM
rotella t4 vs delo
by 1978elcamino. 04/18/19 03:50 PM
Champion Oil Filters any Good?
by spk2000. 04/18/19 03:46 PM
Opinions on the best hidden dash cam?
by FordBroncoVWJeta. 04/18/19 03:28 PM
Maxlife Synthetic or PPHM 10w30
by 53' Stude. 04/18/19 03:27 PM
PYB 10w30 question
by 1978elcamino. 04/18/19 03:16 PM
Misbehaving Mechanic Caught On Dash Cam
by BlueOvalFitter. 04/18/19 02:38 PM
What oil for my newly acquired Samurai
by ad244. 04/18/19 02:37 PM
Check your Oil (SMA YouTube Video)
by javacontour. 04/18/19 02:37 PM
Wearing Hiking Shoes Full-Time
by oilpsi2high. 04/18/19 01:56 PM
Apply brakes, steering wheel shakes
by grampi. 04/18/19 01:35 PM
F150 Exhaust whistle
by Redright9. 04/18/19 01:20 PM
Boy, what a marketing win!
by SubieRubyRoo. 04/18/19 12:06 PM
auto shipping question for a friend
by earlyre. 04/18/19 11:02 AM
O Reilly motor oil
by porvdub. 04/18/19 10:59 AM
GM & JEEP O/S OIL FILTERS
by adrenalin89. 04/18/19 10:56 AM
Kenzitoz, White12Boss302, terryj, Hadryk, djcavein
67844 Registered Users
123 registered members (28oz, 1978elcamino, ad244, 53' Stude, 2dogs, 2003f7, 11 invisible), 2,138 guests, and 24 spiders.
Topics287,707
Posts4,932,663
Members67,844
Most Online2,967
Mar 10th, 2019
Engine knock #4635906
01/15/18 04:55 PM
01/15/18 04:55 PM
Caribbean
Nissan101 Offline OP
Caribbean
Good day,
At idle there is no knocking, at high rpms there are none,
But say 4500 rpm there is a "knocking sound",
You all think engine the engine is bad, or am i lucky and its one of the pulley bearing?
And the knocking noise can only be heard for the split second as I let my food of the throttle.
Please tell me it could be a pulley. :-(
ONly recently this engine was installed and now this.
Oil was changed recently with a store brand 20w50.
I used valvoline maxlife before.
Nissan N16 -10w30
Nissan S13 -20w50
Royal Purple HPS smile
Re: Engine knock [Re: Nissan101] #4635920
01/15/18 05:08 PM
01/15/18 05:08 PM
DFW
JustN89 Offline
JustN89  Offline
DFW
I believe you posted something earier about this, and there was a recommendation given that you change out the store brand oil with a brand you've successfully used before. Valvoline Maxlife or the Royal Purple in your signature would be fine. Use a filter that you've used before as well. That will either solve your problem or we can remove those variables from the equation and start looking at other possibilities.
Re: Engine knock [Re: Nissan101] #4635921
01/15/18 05:09 PM
01/15/18 05:09 PM
Lyndhurst NJ
Audios Online content
Audios  Online Content
Lyndhurst NJ
Sometimes theres a loud rattling noise from worn spring tension belt tensioners in between shifts, as you let off the gas, but its hard to say without hearing it.
2002 VW Golf TDI-Mobil 1 5/40 TDT
2007 Mercedes GL320 CDI- M1 0/30 ESP
2005 BMW M3 BMW Twin Power 10/60
2003 BMW M5-Fuchs 5/40
1998 BMW M3/4/5 Fuchs 5/40
Re: Engine knock [Re: JustN89] #4635922
01/15/18 05:10 PM
01/15/18 05:10 PM
Caribbean
Caribbean
Yes i posted before,
I will change out the oil and filter tomorrow. Hopefully this fixes it.
This is my main daily now as the other car got sold, and i have to pay for University. So money tight :-(
Nissan N16 -10w30
Nissan S13 -20w50
Re: Engine knock [Re: Nissan101] #4635923
01/15/18 05:13 PM
01/15/18 05:13 PM
Caribbean
Caribbean
But question for mechanically incline people
If my engine had a mechanical failure, wouldn't it be knocking 24/7?
and my car has full power and no smoke.
Nissan N16 -10w30
Nissan S13 -20w50
Re: Engine knock [Re: Nissan101] #4635938
01/15/18 05:38 PM
01/15/18 05:38 PM
Ruidoso, NM USA
ammolab Offline
ammolab  Offline
Ruidoso, NM USA
"Letting off the throttle" knock does not sound like serious internal engine problems. Maybe a vibration from a pulley, bad engine or transmission mount, loose exhaust component etc.
2009 Honda CR-V
2011 BMW R1200R
2005 Kaw Ninja 250
1994 Jeep Wrangler 2.5L
2016 Chevy SS Sport Sedan
Re: Engine knock [Re: Nissan101] #4635940
01/15/18 05:44 PM
01/15/18 05:44 PM
Cincinnati, OH, USA
bullwinkle Offline
bullwinkle  Offline
Cincinnati, OH, USA
What happens if you hold the throttle steady, in neutral, at a fairly high RPM (3500-4000)-do you hear any knocking then? Is it better when cold (just warmed up) & only loud when the oil is hot? Usually when I have had loose/worn rod bearings they're a LOT worse with hot oil. If it has a bad rod bearing(s), 20W50 may not be thick enough!
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: Engine knock [Re: Nissan101] #4635948
01/15/18 05:52 PM
01/15/18 05:52 PM
NY
demarpaint Offline
demarpaint  Offline
NY
It could be a lot of things, tough to diagnose w/o seeing and hearing it. I had a noise in an old Ford van once, it sounded just a like an engine knock. I disconnected all the fan belts and ran the engine briefly and there was no knock. Then one accessory pulley at a time starting with the water pump I moved the pulleys from side to side to check for play and spun them to check for odd noises. I found the air pump was knocking. Years later I had the same noise in my 88 E-150, it was the air pump again. It could be an accessory or damper pulley in your case.
God Bless Our Troops
Re: Engine knock [Re: demarpaint] #4635975
01/15/18 06:20 PM
01/15/18 06:20 PM
Caribbean
Caribbean
At max rpm (6200) no knocking,
only at the point of letting go of the throttle.
Nissan N16 -10w30
Nissan S13 -20w50
Re: Engine knock [Re: Nissan101] #4635978
01/15/18 06:20 PM
01/15/18 06:20 PM
Caribbean
Caribbean
Does not make a difference, it is the same when hot and cold
Nissan N16 -10w30
Nissan S13 -20w50
Re: Engine knock [Re: Nissan101] #4636089
01/15/18 08:13 PM
01/15/18 08:13 PM
Fairfax, VA
TinyVoices Offline
TinyVoices  Offline
Fairfax, VA
What motor in your s13? KA?
2010 Mazda RX8 Sport - 37k miles - ????
2006 Toyota Matrix XR AWD (Wife) - 130k miles - Valvoline Max Life 5w30
Re: Engine knock [Re: Nissan101] #4636193
01/15/18 10:05 PM
01/15/18 10:05 PM
Texas (south)
FermeLaPorte Offline
Texas (south)
Take it to a mechanic, don't lose time asking strangers on the internet
Always Mobil 1
2014 1.6L Nissan Versa Sedan, 5 spd, 5k OCI.
2011 3.5L Chevrolet Impala, Automatic, 5k OCI.
Re: Engine knock [Re: Nissan101] #4636259
01/16/18 12:26 AM
01/16/18 12:26 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
It is a broken piston skirt.
Re: Engine knock [Re: Linctex] #4636334
01/16/18 07:19 AM
01/16/18 07:19 AM
northern NY
Driz Offline
Driz  Offline
northern NY
You can get a decent mechanics stethoscope at Autozone for $8 and a really good one amazon foe $20. Get one , itíll open up a whole new world for you. Forget that long extension [censored] too. Once you have one you will use it again.
That will normally let you zero right in on where the noise is coming from by the process of elimination. As always while working on a running engine to tuck in long hair and long floppy clothes especially sleeves. Remember that fan comes on when it decides to so stay outa there always. Good luck
Re: Engine knock [Re: Nissan101] #4636336
01/16/18 07:24 AM
01/16/18 07:24 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
I cant even venture a guess but I would start by having someone operate the throttle while I listened under the hood to at least determine if it was an internal engine noise or external.
As you just put the engine in it could be a host of things from an exhaust hitting something, engine mount damage or a mounting bracket.
