Good Purchase?
by FordBroncoVWJeta. 03/19/19 11:33 AM
not sure what spark plugs to buy now
by MrTruckDriver. 03/19/19 11:33 AM
Tires on a Lease Return
by clarkflower. 03/19/19 11:25 AM
Auto-Rx now available on Amazon
by LarryD. 03/19/19 11:14 AM
Best place to advertise used car for sale?
by Ed_Flecko. 03/19/19 10:51 AM
A little help with a 2010 Santa Fe
by nicholas. 03/19/19 10:50 AM
Lawn Mower Battery - What's Up with That?
by Astro_Guy. 03/19/19 10:34 AM
This makes me sick
by SLO_Town. 03/19/19 10:32 AM
Slanderous Fram Orange Can Review
by doitmyself. 03/19/19 08:39 AM
MRV of PP EURO 0W40 an anomaly?
by 21Rouge. 03/19/19 08:39 AM
The Beater is Even Uglier Now!
by Delta. 03/19/19 08:28 AM
Oil viscosities at 200 to 225 F
by Snagglefoot. 03/19/19 07:35 AM
What would you do...
by Bailes1992. 03/19/19 05:28 AM
'65 Mini.
by Silk. 03/19/19 02:08 AM
Our trash guy is getting on my nerves.
by Chris142. 03/19/19 01:20 AM
Ecogard trans filter
by pda1122. 03/19/19 12:11 AM
4.3 vortec issues
by mobilaltima. 03/18/19 09:17 PM
Recommendation for filter for Alfa Romeo 4C?
by phaphaphooey. 03/18/19 09:17 PM
tbann, LisaMC, chops, drsoils, Gbear
67554 Registered Users
105 registered members (77GrandPrix, AandPDan, AdditiveOCD, 28oz, 11 invisible), 2,144 guests, and 67 spiders.
Topics286,063
Posts4,901,778
Members67,554
Most Online2,967
Mar 10th, 2019
Mobil 1 5W-30 vs 0W-30 AFE #4635808
01/15/18 03:00 PM
01/15/18 03:00 PM
Tennessee, United States
ZraHamilton Offline OP
I am trying to determine which is better for cold winter start-ups.
The viscosity of the 5W-30 is actually 1 cSt thinner at 40C.
Mobil 1 5W-30 - @40C - 61.7 cSt
Mobil 1 AFE 0W-30 - @40C - 62.9 cSt
However, that is at 104F, and I would like to know how they compare at around 32F (0C).
Thanks to anyone who can help.
Re: Mobil 1 5W-30 vs 0W-30 AFE [Re: ZraHamilton] #4635814
01/15/18 03:05 PM
01/15/18 03:05 PM
'Stralia
Shannow Offline
Shannow  Offline
'Stralia
At 0C, there's literally absolutely nothing between those two oils.
Re: Mobil 1 5W-30 vs 0W-30 AFE [Re: ZraHamilton] #4635849
01/15/18 03:45 PM
01/15/18 03:45 PM
Would there be any difference at -18C?
Re: Mobil 1 5W-30 vs 0W-30 AFE [Re: ZraHamilton] #4635867
01/15/18 04:07 PM
01/15/18 04:07 PM
MTL, CANADA
Rolla07 Offline
Rolla07  Offline
MTL, CANADA
If your car recommends 5w30, I would just use the 0w30. Even if barely a difference between the two. Same price for the oil, and my experience has been that AFE always runs smoothly in my car. Either will work but I like to think the 0w will be easier on my engine during any cold starts. Even if no difference, what have i lost in ability vs using 5w30?
2007 Corolla Red Pearl 155k miles
PP 0w20 & ST 4967
Re: Mobil 1 5W-30 vs 0W-30 AFE [Re: ZraHamilton] #4635871
01/15/18 04:15 PM
01/15/18 04:15 PM
Thanks for the advice Rolla07. Most of my driving is 10 minute trips, so I want an oil that will heat up as quickly as possible.
Re: Mobil 1 5W-30 vs 0W-30 AFE [Re: ZraHamilton] #4635872
01/15/18 04:16 PM
01/15/18 04:16 PM
SC, USA
Bxnanaz Offline
Bxnanaz  Offline
SC, USA
I like 0Ws not only for cold starts but also the higher viscosity index.
Re: Mobil 1 5W-30 vs 0W-30 AFE [Re: ZraHamilton] #4635880
01/15/18 04:26 PM
01/15/18 04:26 PM
Agreed. I've also heard that Mobil 1's AFE oils have a high percentage of PAOs in them. This means that it could be achieving the higher viscosity index with little to no viscosity index improvers.
Re: Mobil 1 5W-30 vs 0W-30 AFE [Re: ZraHamilton] #4635889
01/15/18 04:33 PM
01/15/18 04:33 PM
SE British Columbia, Canada
Snagglefoot Offline
Snagglefoot  Offline
Here are is the definition under ASTM D5293 for cold cranking.
Cold Crank Viscosity
ASTM D5293- Test Method for Apparent Viscosity of Engine Oils Between -5 and -35 C Using the Cold Crank Simulator
This test method covers the laboratory determination of apparent viscosity of engine oils at temperatures between 5 and -35C and at high shear rates. The results are related to engine cranking characteristics of engine oil. A measured amount of sample is subjected to an extreme low temperature for 3 minutes. The rotor spins for 1 minute in the sample and the speed of the rotor is measured by keeping ohms resistance at zero. The speed-reading is used to determine the viscosity on a calibration curve.
The cold cranking simulator (CCS), ASTM D5293, correlates with engine cranking speed at low temperatures.
Cold cranking viscosity simulates the viscosity of an oil in crankshaft bearings during cold temperature start up.
Cold cranking viscosity limits, determined by the CCS, are defined in the SAE J300 Standard, as shown below:
Low temperature viscosity (mPa s) Max (CCS) Temps are degrees C.
0W 6200 @ -35
5W 6600 @ -30
10W 7000 @ -25
15W 7000 @ -20
20W 9500 @ -15
25W 13000 @ -10
If you want the job done right......do it yourself.
Re: Mobil 1 5W-30 vs 0W-30 AFE [Re: ZraHamilton] #4635900
01/15/18 04:47 PM
01/15/18 04:47 PM
Snagglefoot Offline
Snagglefoot  Offline
At -40 F/C, the results are fairly dramatic and you can make yourself a You Tube video to show everyone. At higher temps the difference is less dramatic. 0W-30 at -35 C flows like 5W-30 at -30 C which flows like 10W-30 at -25 C. I've personally done flow tests at -20 C and I can say you'll notice the difference between 5W-30 and 10W-30, but it is not dramatic like at -40. And yes, you probably wouldn't notice a difference between 0W-30 and 5W-30 at 0 degrees C.
SF
Re: Mobil 1 5W-30 vs 0W-30 AFE [Re: ZraHamilton] #4635908
01/15/18 04:58 PM
01/15/18 04:58 PM
montreal ,canada
madeej11 Offline
madeej11  Offline
montreal ,canada
The difference between the two of those oils are negligible at 32F. The 0w30 would pay dividends at roughly -20F which you would hardly ever see in Tennessee. JMO. Good luck.
Re: Mobil 1 5W-30 vs 0W-30 AFE [Re: Rolla07] #4635968
01/15/18 06:13 PM
01/15/18 06:13 PM
'Stralia
Shannow Offline
Shannow  Offline
'Stralia
see, that's the problem with the laws of physics...they don't really mind what people like to think.
at 32F, if anything has a slight edge it will be the marginally thinner 5W30.
As to what you've lost
Dexos
HTO-06
lighter basestocks with more "fillers'
Re: Mobil 1 5W-30 vs 0W-30 AFE [Re: ZraHamilton] #4635974
01/15/18 06:17 PM
01/15/18 06:17 PM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
The oil viscosity choice will not matter as far as cold starting until you start to ge below -25 *f.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Mobil 1 5W-30 vs 0W-30 AFE [Re: ZraHamilton] #4635994
01/15/18 06:38 PM
01/15/18 06:38 PM
Pennsylvania
Astro_Guy Online content
Astro_Guy  Online Content
Pennsylvania
'01 Volvo V70XC, 236k, 10W-30 M1 High Mileage
'16 Accord, 28k, 0W-20 M1 EP
Re: Mobil 1 5W-30 vs 0W-30 AFE [Re: Astro_Guy] #4636002
01/15/18 06:49 PM
01/15/18 06:49 PM
Ontario, Canada
OVERKILL Online content
OVERKILL  Online Content
Ontario, Canada
Originally Posted By: Astro_Guy
That's not accurate below 0C.
Viscosity measured via CCS and MRV roughly halves as you increase temperature by 5C. So a 0w-30 with a CCS of 5,600cP @ -35C would be roughly 2,800cP @ -30C.
However, the issue is that if you are comparing say a 5w-30 and a 0w-30, at somewhere around -15C, that trick stops working and we start heading toward what you'd see in the calculator. Basically, that's where an oil's VI starts to become relevant. It's not a hard line, as it would vary based on base oil, PPD's, VII treatment....etc but it seems to be somewhere in that neighbourhood.
So we have this range between -15C and 0C where the visc calc isn't accurate and the halving rule isn't either.
2016 Grand Cherokee SRT - Castrol Edge 0w-40, FRAM Ultra
Re: Mobil 1 5W-30 vs 0W-30 AFE [Re: Bxnanaz] #4636078
01/15/18 07:54 PM
01/15/18 07:54 PM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
Higher Vi in a finished oil is usually due to more viscosity improvers used. Although I like the 0w- oils myself 1 oil from -35*f to over 100*f.
2015 Ford F150 2.7
2018 Ford F350 6.2
