Battery mfg date
by Donald. 01/18/19 08:14 AM
dexos1 Gen 2 License D10386HG025
by Virtus_Probi. 01/18/19 07:43 AM
KARMA
by Sayjac. 01/18/19 07:42 AM
Using a school bus as a camper?
by Kurtatron. 01/18/19 07:04 AM
Formula Shell Synthetic
by mmmmoil. 01/18/19 07:03 AM
free credit report
by bradepb. 01/18/19 06:25 AM
Elon Musk is running out of rich people...
by philipp10. 01/18/19 05:56 AM
Best/Cheapest UOA?
by Hemispheres. 01/18/19 05:02 AM
Hyundai/KIA Theta II multiple call campaigns
by wemay. 01/18/19 04:58 AM
How we do it in wichita! Go Shockers
by Marco620. 01/18/19 02:14 AM
Can 0w20 handle high RPMs
by Doublehaul. 01/18/19 01:16 AM
Dodge Grand Caravan OEM Floor Mats
by raburn2906. 01/17/19 11:52 PM
Mobil 1 0w30
by Doublehaul. 01/17/19 11:11 PM
(NEW) STP S3675 Cut Open
by rooflessVW. 01/17/19 10:00 PM
Anti-Counterfeiting packaging
by sloinker. 01/17/19 09:13 PM
Heavy Snow Predicted for Northeast Sat/Sun
by Donald. 01/17/19 08:34 PM
Pennzoil Ultra Plat 5w30 1.4L T Chevy Cruze 10k
by SubieBlue. 01/17/19 08:03 PM
Buddyp, RyanWu, Batteryspecialis, BamaDawg, JRBilt
66969 Registered Users
72 registered members (Anduril, badduxx, bmwpowere36m3, ARCOgraphite, biodiesel, bbslider001, 8 invisible), 1,775 guests, and 55 spiders.
Topics296,775
Posts4,958,671
Members66,969
Most Online2,577
Jan 14th, 2019
Page 1 of 3 1 2 3
Dynamic Skip Fire for 2019 Sierra V8 Engines #4635637
01/15/18 11:09 AM
01/15/18 11:09 AM
Idaho
SubLGT Offline OP
SubLGT  Offline OP
Idaho
GM has announced that the Dynamic Skip Fire cylinder deactivation system developed by Delphi (hardware) and Tula (software) will be implemented on the 2019 Sierra.
Quote:
...DSF is applied to each individual cylinder, and it continuously varies which cylinders must be firing, as it works in sync with the engine’s throttle system. In normal engines, the flap in the throttle body is almost always in a closed position but, with DSF, the flap is nearly always open to control the engine’s power by varying the number of cylinders needed.
The cylinders are shut off by stopping the flow of oil with special valve lifters on each cylinder.
“The more power you need out of your engine, the more torque, the harder you press down on the accelerator pedal, the greater percentage of your cylinders will fire. This is software-enabled variable displacement,” Tula CEO, Scott Bailey, told Automotive News.
Tula says a V8-powered SUV typically only requires 30 hp to cruise on a highway to hold its speed and, with DSF, six cylinders shut down to provide a monumental 21-percent increase in fuel economy, as tested in the real world on a GMC Yukon Denali.
Read more: http://gmauthority.com/blog/2015/09/gene.../#ixzz54H15HQ61 ….
http://articles.sae.org/15485/
Quote:
...DSF is claimed to be the industry’s first fully-variable engine cylinder deactivation technology….
...Delphi and partner Tula Technology have revealed test data showing NVH reduction benefits with use of their jointly-developed Dynamic Skip Fire (DSF) cylinder deactivation system that was designed to reduce engine fuel consumption and emissions
....During DSF operation, the decision to fire or skip a cylinder is made immediately prior to each ignition event, with each event considered independently and in sequence. DSF also allows all-cylinder cutoff during deceleration. Many factors are considered when deciding which cylinders to fire; these include torque demand, NVH characteristics of the engine and the frequencies and amplitudes that must be avoided in order to eliminate any impact on occupant comfort….
https://www.youtube.com/watch?v=ei1NyfgY5Ds
Re: Dynamic Skip Fire for 2019 Sierra V8 Engines [Re: SubLGT] #4635651
01/15/18 11:23 AM
01/15/18 11:23 AM
N.H, U.S.A.
ARCOgraphite Online content
ARCOgraphite  Online Content
N.H, U.S.A.
Isnt this Like what Fiat is doing with Multiair on their 4 cylinder engines? Throttling the engine with valve events timing and lift - of course minus the "skip fire" ( With the unfortunate name "skip fire" I see a tragedy for this tech and GM on the horizon )
2019 VW Jetta S,6M OCI#0 62mi-Castrol Edge Prof VW508+OE Filter; '17 Subaru Crosstrek CVT OC#5 37K mi-SOA/Idemitsu 0w20 + SOA Filter
Re: Dynamic Skip Fire for 2019 Sierra V8 Engines [Re: SubLGT] #4635692
01/15/18 12:10 PM
01/15/18 12:10 PM
Louisiana
SuzukiGoat Offline
SuzukiGoat  Offline
Louisiana
You want a GM designed system doing this.... Really?
2003 Nissan Xterra 4x4 M1 HM 10w40
2001 Toyota 4runner 4x4 M1 0w40
2016 Yamaha YXZ1000R VR1 20w50
Re: Dynamic Skip Fire for 2019 Sierra V8 Engines [Re: SubLGT] #4635699
01/15/18 12:16 PM
01/15/18 12:16 PM
Fort Lauderdale, FL
DoubleWasp Offline
DoubleWasp  Offline
Fort Lauderdale, FL
GM owes at least one awful ignition system to each decade.
Re: Dynamic Skip Fire for 2019 Sierra V8 Engines [Re: SubLGT] #4635710
01/15/18 12:27 PM
01/15/18 12:27 PM
Illinois
mrsilv04 Offline
mrsilv04  Offline
Illinois
Let's see what people think of it sometime around 2022.
2004 Silverado - on its 3rd Jasper engine in less than one year.
Re: Dynamic Skip Fire for 2019 Sierra V8 Engines [Re: SubLGT] #4635719
01/15/18 12:37 PM
01/15/18 12:37 PM
NH
supton Online content
supton  Online Content
NH
I'm sure those guys know what they are doing. But in my mind... I don't get it. Is it one common throttle valve or one per cylinder?
Seems like a "dead" cylinder would be best to be pulling air through a wide-open throttle plate. No drag. With DI just don't inject fuel. I don't know if they snap throttle plates fast enough to make it feel seamless but maybe it's fast enough to have one per cylinder. But the downside would be getting cool air into the exhaust stream; but perhaps by alternating cylinders the exhaust stays warm enough to be diluted by the firing cylinders.
Like everything else, the proof is in the pudding. Not sure I want to be first but I'll certainly watch from the sidelines.
2011 Toyota Camry, base, 2.5L/6MT, 176k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 145k, ours
1999 Toyota Camry LE, 2.2L/4AT, 199k, his
Re: Dynamic Skip Fire for 2019 Sierra V8 Engines [Re: SubLGT] #4635720
01/15/18 12:38 PM
01/15/18 12:38 PM
PimTac Offline
PimTac  Offline
All the automakers are working with new technologies for internal combustion engines. The days of getting a simple straightforward engine seem to be going away.
I agree. Wait two or three years for any durability effects.
Cannot see signatures any longer so it doesn’t matter.
Re: Dynamic Skip Fire for 2019 Sierra V8 Engines [Re: SuzukiGoat] #4635728
01/15/18 12:44 PM
01/15/18 12:44 PM
California
nthach Offline
nthach  Offline
California
Mopar, Nissan and Mercedes have been using multi-spark ignitions. Looks like this one is using code and algorithms instead of an secondary ignition system to fire the plugs more than once or even skip them.
Looks like it might be better than just killing the valves for DoD.
Re: Dynamic Skip Fire for 2019 Sierra V8 Engines [Re: SubLGT] #4635729
01/15/18 12:44 PM
01/15/18 12:44 PM
Toronto
PeterPolyol Offline
PeterPolyol  Offline
Toronto
Should be smooth as silk
Mopar, Nissan and Mercedes have been using multi-spark ignitions. Looks like this one is using code and algorithms instead of an secondary ignition system to fire the plugs more than once.
Don't think it's like wasted spark system at all, probably more like variable cylinder disablement where (eg) anywhere from 2 to 6 cylinders are shut down depending on demand. So really the only diff. between regular cylinder deactivation is that the amount of cylinders disabled can vary instead of just one whole bank.
There's no replacement...'scosity for natural viscosity
Re: Dynamic Skip Fire for 2019 Sierra V8 Engines [Re: SuzukiGoat] #4635733
01/15/18 12:48 PM
01/15/18 12:48 PM
Wisconsin
emmett442 Offline
emmett442  Offline
Wisconsin
This was developed by a private third party - Tula Technology. Been around for a decade.
As I understand it, there is no throttle valve: like a diesel. That way, since there is no air restriction, whichever cylinders are selected to fire are operating at peak efficiency every time they fire = less emissions and better fuel efficiency.
If that's correct, I suppose that means either they've done away with all vacuum operated equipment or they're going to use a vacuum pump to retain it.
As far as complication, it seems to me they'd be able to eliminate the throttle body and it's associated management. Not sure EXACTLY how this is implemented, but there's a chance that this could actually be a simpler (mechanically) system than what we currently have!
2011 Ford Crown Victoria LX 4.6L V8 auto
2009 Chevrolet Malibu LT 2.4L I4 auto
1974 Dodge D200 360 V8 4 speed manual
Re: Dynamic Skip Fire for 2019 Sierra V8 Engines [Re: SubLGT] #4635743
01/15/18 12:55 PM
01/15/18 12:55 PM
PV Az
AZjeff Offline
AZjeff  Offline
PV Az
Some people's heads are exploding as they read this..
86 Samurai 1.3 leftovers
14 RAV4 2.5 5W-20 PP
16 Silverado 1500 4.3, DI, AFM 5W-30 PP
The most important thing to do in your life is to not interfere with someone else's life. - Frank Zappa
Re: Dynamic Skip Fire for 2019 Sierra V8 Engines [Re: AZjeff] #4635748
01/15/18 12:57 PM
01/15/18 12:57 PM
Illinois
mrsilv04 Offline
mrsilv04  Offline
Illinois
No, but I am trying to reasonably calculate how many more years that my 2004 Silverado, which I can still work on myself, might last.
Re: Dynamic Skip Fire for 2019 Sierra V8 Engines [Re: SubLGT] #4635750
01/15/18 12:58 PM
01/15/18 12:58 PM
NH
NH
Ah, so one "flap" which is more of an on/off control. Enable/disable valves to limit pumping losses. Interesting. Must be able to "turn on" a cylinder pretty fast.
Re: Dynamic Skip Fire for 2019 Sierra V8 Engines [Re: emmett442] #4635763
01/15/18 01:09 PM
01/15/18 01:09 PM
MN
Tman220 Offline
Tman220  Offline
MN
This was developed by a third party - Tula Technology. Been around for a decade.
The way I understand it is that a throttle valve will still be used, you will need it to idle smoothly because that will most certainly be done on all 8.
Under load however the throttle will be adjusted by the PCM to establish a zero vacuum condition, then power will be adjusted by how many cylinders are firing and then will be smoothed out by throttle position. This is nothing new, the pcm’s in the 2014 and newer trucks are already using that strategy.
Also to clarify, when cylinders are shut down they are shut down immediately after a power stroke, the lifter is shut off via oil pressure and the exhaust valve doesn’t open, this maintains cylinder pressure (air spring) to seal the rings and to avoid the type of mis-fire that you can feel.
To me this sounds like more of an expansion of the current system. Most of the oil plumbing is already there, there will just by 16 special lifter rather than 8. But now the computer will have even more flexibility to make for an absolute seamless system. Right now it’s either 4 or 8. Also this is not ignition based, the spark plugs will keep firing away because they don’t need to be shut down, If valves don’t open and fuel injectors aren’t fired there is nothing to burn.
2012 Regal GS Turbo PP 5w30
1994 Camaro Z28 LT1 355 CI, 430 RWHP PP 5W30
Re: Dynamic Skip Fire for 2019 Sierra V8 Engines [Re: SubLGT] #4635780
01/15/18 01:31 PM
01/15/18 01:31 PM
N.H, U.S.A.
N.H, U.S.A.
yopr Chrylser /Ddoge Multiair 4 banger uses something similar minus the cylinder deactivation.Back in the 80's My plasma chamber vacuum pumps slowed down when pumping air (load) and speed up when at near perfect vacuum, so I don't fully understand pumping losses. If you aren't moving a fluid mass the work performed is less.
Page 1 of 3 1 2 3
