2011 Dodge Caliber
by dogememe. 09/23/18 07:48 PM
Mixing transmission fluids - partial change
by spk2000. 09/23/18 07:31 PM
Counterfeit MANN filter???
by IllinoisSparky. 09/23/18 06:54 PM
The smell of an oil: VME adds?
by fdcg27. 09/23/18 06:48 PM
Classic road brake pads
by buck91. 09/23/18 06:18 PM
Air up your vehicle's tires
by Papa Bear. 09/23/18 06:07 PM
A cool litttle Fall foliage site
by Papa Bear. 09/23/18 06:02 PM
Suggestion: "Likes"
by SnowDrifter. 09/23/18 05:36 PM
Condensation in headlights?
by irv. 09/23/18 05:06 PM
Nissan VQ V-6 Engines
by Al. 09/23/18 04:57 PM
List of dexos licensed oils?
by k1xv. 09/23/18 04:24 PM
High flow oil pump? Thinner oil?
by SnowDrifter. 09/23/18 04:06 PM
Is Tiger back?
by gman2304. 09/23/18 03:51 PM
Castrol Edge Pro OE LLIV FE 0W20 for VW508
by BrandonT. 09/23/18 03:33 PM
Value of 90's stereo equipment
by wrcsixeight. 09/23/18 03:28 PM
Wisdom of BITOG'ers wanted- 19 Avalon Hybrid oil
by scion_xb. 09/23/18 02:36 PM
w116 300sd Mercedes Diesel HPR fuel
by Gito. 09/23/18 02:14 PM
Lilshady, SevenDu, sigpro, RayCJ, yellow97tt6spd
66055 Registered Users
116 registered members (69GTX, 65convertible, 2015Corolla, 2004tdigls, 11 invisible), 1,846 guests, and 35 spiders.
Topics290,912
Posts4,852,348
Members66,055
Most Online3,590
Jan 24th, 2017
Turbos and UOA #4635317
01/15/18 03:02 AM
01/15/18 03:02 AM
Fort Lauderdale, FL
DoubleWasp Offline OP
Fort Lauderdale, FL
Are turbochargers a factor in the wear metal results in a UOA, or are they just basically shedding so little (properly working) that it does not matter?
Re: Turbos and UOA [Re: DoubleWasp] #4635319
01/15/18 03:12 AM
01/15/18 03:12 AM
Waco, TX
Linctex Online content
Linctex  Online Content
Waco, TX
The bearings in a turbo are really small, and they can't wear very much at all before they are toast.
So, yes: "just shedding so little (properly working) that it does not matter?" is correct.
I have seen turbos with 5,000+ hours of operation show *NO* noticeable or measurable wear.
That's pretty good (assuming 5,000 x 60 mph = 300,000 miles equivalent)
Just today I talked to a trucker with a 2001 Freightliner with 1.6 million on the clock,
He says he replaced the original turbo at 1.2 million miles (60 Series Detroit)
100% Mobil Delvac 15W-40 it's entire life.
Re: Turbos and UOA [Re: Linctex] #4635395
01/15/18 07:35 AM
01/15/18 07:35 AM
Mt. Vernon, NY
ssamaroo01 Offline
ssamaroo01  Offline
Mt. Vernon, NY
Are there major differences between diesel turbos and gas turbos? Many people seem to think that they will be the first thing to go on a turbo engine. I have always wondered how turbochargers on turbo diesels go much longer than gas turbos - I'm assuming that they do last longer since I do not hear complaints about diesels requiring turbocharger replacements.
2015 Fusion Titanium AWD 2.0L Ecoboost 103k
2012 Escape Limited 2.5L Duratec 42k
2000 E-250 4.2L 90k
MC FS W/ MC Filters
Re: Turbos and UOA [Re: DoubleWasp] #4635434
01/15/18 08:42 AM
01/15/18 08:42 AM
SE British Columbia, Canada
Snagglefoot Online content
Snagglefoot  Online Content
How long are the gas turbos surviving? Is 200,000 miles too much to ask?
If you want the job done right......do it yourself.
Re: Turbos and UOA [Re: DoubleWasp] #4635463
01/15/18 09:17 AM
01/15/18 09:17 AM
Manchester, England
Olas Offline
Olas  Offline
Manchester, England
A properly lubricated and cooled turbo will last just as long as any other bearing in the engine. Lifespan is compromised in several ways:
Low oil kills the bearing
Insufficient cooling lets the oil in the bearing coke after shutoff, next run sees oil starvation and kills the bearing
Improper oil choice promotes coking in the bearing
Remapping or chipping the ECU for more boost puts more heat into the bearing accelerating wear
There used to be a mantra in the early days of mass turbocharging, they said "spool, then cool" and saw good life.
People who are in a rush to go shopping/get home etc who cut the ignition as soon as they reach their destination without sitting idle for a while to let the turbo cool see one of the above listed problems.
Good maintenance and operating procedure is key to good longevity, and Id guess the big-mileage turbo diesels in America are truck drivers who know how to operate their machinery, where a lot of petrol turbos are consumer items driven by people who don't know or care (generalisation, I know you're not all like that)
Cable ties should hold it
Re: Turbos and UOA [Re: Olas] #4635478
01/15/18 09:27 AM
01/15/18 09:27 AM
Campbellsville, KY
Alex_V Offline
Alex_V  Offline
Campbellsville, KY
This.
I like Chevy and Valvoline.
'13 Cruze, 1.4T, 113K
'85 GMC C3500, 454, 130K
'82 Mercedes 300CD, OM617 turbo, 169K
'67 Suburban, 350, 331K
Re: Turbos and UOA [Re: DoubleWasp] #4635572
01/15/18 10:52 AM
01/15/18 10:52 AM
Florida, Cape Coral
Eddie Online sleepy
Eddie  Online Sleepy
Florida, Cape Coral
Most over the rood big trucks are driven a a fairly constant speed. Their turbos are designed for high efficiency at a constant speed. The gas engine turbo is small to reduce speedup time for quick acceleration. I think that is why Diesel turbos last much longer than car turbos. ed
CX5 Touring 2.5L :-)
Re: Turbos and UOA [Re: DoubleWasp] #4635727
01/15/18 01:43 PM
01/15/18 01:43 PM
Massachusetts
VeryNoisyPoet Offline
Massachusetts
Diesel engines also tend to run lower exhaust gas temperature compared to boosted petrol engines.
That said a modern turbo can last a long time with water cooling (most of them), quality oil, staying on top of OCI, and letting them idle to cool down after hard driving.
I'll be checking the bearings for play in the spring, but my car has the original turbo after 184k and it still works just fine. No noises, unusual oil consumption,or other common signs of impending failure.
1998 V70 GLT / 192k miles [10w-30 Valvoline Syn w/ Maxlife Tech + Mann W917 filter]
"Use yah blinkah!"
"Be nice. The alternative involves an air horn and 7000 lumens of high beam."
Re: Turbos and UOA [Re: VeryNoisyPoet] #4635846
01/15/18 03:42 PM
01/15/18 03:42 PM
ecotourist Offline
ecotourist  Offline
It'll be fine. The oil cooled (only) turbo in my '86 Volvo 740 Turbo lasted a long time. Still going strong after 285,000 Km and 18 years. I then sold it to friends who drove it for 5 more years and the turbo was still fine.
Oil was not as good as today's (always conventional, often Pennzoil PZL Turbo) but changed every 3 months. And letting the turbo cool after hard driving.
2000 BMW 528i 5MT
2007 Honda Accord EX-L 4Door V6 6MT
Re: Turbos and UOA [Re: Eddie] #4636526
01/16/18 11:03 AM
01/16/18 11:03 AM
Idaho
CT8 Offline
CT8  Offline
Idaho
I could easily get the turbo temps to the red line on the pyrometer on the class 8 trucks which was 1200*f .
2015 Ford F150 2.7
2018 Ford F350 6.2
