more dumb questions!! infiniti Q50
by Robertslowpoke. 03/23/19 06:23 AM
VW Passat R36 504 00/ 507 00 oil
by antik. 03/23/19 04:43 AM
Oil for 2015 Ford Explorer
by oilnut12. 03/23/19 12:48 AM
Blains farm and fleet citgo syn
by BTLew81. 03/22/19 10:48 PM
2003 Duramax 208, XXX miles Rotella T4
by TurboJW. 03/22/19 08:11 PM
Turn signals on the freeway?
by das_peikko. 03/22/19 08:05 PM
Running Boards Restored
by kstanf150. 03/22/19 07:38 PM
QSUD at Canadian Tire
by Snagglefoot. 03/22/19 07:29 PM
Camry vs Accord vs ???
by Joe1. 03/22/19 07:26 PM
Fire up
by Matagonka. 03/22/19 07:16 PM
Mobil-1 AFE Discounted at Sam's Club
by ekpolk. 03/22/19 06:20 PM
Test drove a Tesla Model 3
by y_p_w. 03/22/19 05:54 PM
Did i make a mistake? Hilux 3.0 d4dhello
by Anton93. 03/22/19 05:52 PM
WM Valvoline Full Syn Modern Eng Clearance
by Spartanfool. 03/22/19 04:22 PM
Need Moly basic training
by Bill_W. 03/22/19 04:03 PM
P0420 code goes away in warmer weather
by 2010Civic. 03/22/19 03:54 PM
Customer declined new belt
by Chris142. 03/22/19 03:13 PM
How to deep clean back of wheels?
by qdeezie. 03/22/19 02:51 PM
Zahndkile, duradick, Harold1031, Skendread, NGK
67590 Registered Users
73 registered members (alarmguy, Astro14, 1foxracing, b1amgm47, AurionX2, 3 invisible), 1,474 guests, and 53 spiders.
Topics286,271
Posts4,905,701
Members67,589
Most Online2,967
Mar 10th, 2019
Whats a good budget ball joint press? #4635257
01/15/18 12:26 AM
01/15/18 12:26 AM
Wisconsin
Black_Thunder Offline OP
Wisconsin
I've always been able to get by without one but it looks like I'll be helping with some balljoints on an e150 soon and i they way the joints are the spindle i think i'm going to need one.
I'd rather buy one then rent because I could use one, as it can be used for u-joints etc.
I've been looking on Amazon etc, and there are ton of different products out there.
Just wondering what brands you guys have or would recommend.
I would like to keep the purchase in the 80 dollar range or lower.
I'd buy Callahan autoparts if I could.
Re: Whats a good budget ball joint press? [Re: Black_Thunder] #4635271
01/15/18 12:51 AM
01/15/18 12:51 AM
5600 feet elevation, Arizona
double vanos Offline
Harbor Freight probably has what you need. For the occasional user itd probably be fine.
Sabine Schmitz is the Queen of the 'Ring; Svetlana Kapanina is the Queen of the SKIES...
Re: Whats a good budget ball joint press? [Re: Black_Thunder] #4635276
01/15/18 01:01 AM
01/15/18 01:01 AM
PR CA, USA
2strokeNorthstar Offline
PR CA, USA
Autozone loaner has served me well. Did 2 ball joints on my F-150 and 2 on an Explorer. Replaced the slip yoke (ujoint removal) on my f-150 too. Free! If you buy one it will sit for years unused.
2001 F150 5.4L 140k miles
2013 Nissan Juke Nismo 80k
2000 Honda S2000 183k
1998 BMW 328i 170k
Re: Whats a good budget ball joint press? [Re: Black_Thunder] #4635296
01/15/18 01:55 AM
01/15/18 01:55 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Look at the one from OTC it may cost a little bit more but the quality is worth it.
Re: Whats a good budget ball joint press? [Re: Trav] #4635323
01/15/18 03:29 AM
01/15/18 03:29 AM
Wisconsin
Wisconsin
sounds like a good idea.
from the couple i'm looking at its only 20 to 30 more and only 10 more then the harbor freight kit.
Re: Whats a good budget ball joint press? [Re: Black_Thunder] #4635382
01/15/18 07:12 AM
01/15/18 07:12 AM
Trav Offline
Trav  Offline
The sets from most do not come with many adapter which are needed but you don't need to buy the expensive OTC one, an inexpensive set will more than do the job. When you buy these press tools you are paying for the frame and screw, those are the parts that take the load.
I bought mine some years ago from OTC and the frame and screw were still USA made, the adapter were Taiwan or China and probably no better than these.
https://www.amazon.com/Goplus-Remover-In...49K46RXRHB46P7B
Re: Whats a good budget ball joint press? [Re: Black_Thunder] #4635690
01/15/18 01:09 PM
01/15/18 01:09 PM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
Generally speaking, by the time, I go buy or rent a press, I can bang the the thing apart with a hammer and some sorta lever rigged to provide tension. OTOH, If I had been smart, I woulda bought one the first time I ever needed one. grin2
Thick oil is better grin2
Re: Whats a good budget ball joint press? [Re: Black_Thunder] #4636255
01/16/18 12:18 AM
01/16/18 12:18 AM
Wisconsin
Wisconsin
yeah i figure i have a bit to do some research and read reviews and such before i make my decision.
Re: Whats a good budget ball joint press? [Re: Black_Thunder] #4643394
01/22/18 09:27 PM
01/22/18 09:27 PM
Florida
aquartlow Offline
aquartlow  Offline
Florida
I purchased one from Harbor Freight to do the ball joints in my 2000 Ford SD 7.3 4x4, I have used it on 4 trucks now with no complaints, the SD ball joints are NOT the easiest to remove/install. Side note, try to use XRF ball joints, the best I have found for my application(diesel 4x4) and come with million mile warranty(they did when I installed the 4 sets).
Re: Whats a good budget ball joint press? [Re: Black_Thunder] #4645473
01/24/18 11:14 PM
01/24/18 11:14 PM
Wisconsin
Wisconsin
I generally use Moog parts but hey I'll check out the xrf line
Re: Whats a good budget ball joint press? [Re: Black_Thunder] #4645638
01/25/18 08:22 AM
01/25/18 08:22 AM
Florida
aquartlow Offline
aquartlow  Offline
Florida
The reason I mentioned the XRF's is that I have used Spicer(non-greasable like stock bj's) and Moog's(greasable), but surprisingly they both needed replaced after just 20-25K miles, the XRF ball joints have been installed for over 75K miles and still no issues(truck has 318K). The XRF's are very popular with Ford/Dodge diesel owners.
Re: Whats a good budget ball joint press? [Re: Black_Thunder] #4650498
01/29/18 07:21 PM
01/29/18 07:21 PM
Central Virginia
Silverado12 Offline
Silverado12  Offline
Central Virginia
Probably not helpful but I use a pickle fork. It rips up the boots but you're replacing the balljoints anyways.
12 Chevy Silverado ext. cab LS, 2WD 4.3 auto
18 Mustang GT 5.0 auto
07 Harley Dyna Street Bob 96 c.i. 6 sp.
00 Mustang GT auto
Re: Whats a good budget ball joint press? [Re: Silverado12] #4650864
01/30/18 09:12 AM
01/30/18 09:12 AM
Upper Midwest
kschachn Online content
kschachn  Online Content
Upper Midwest
If you are replacing them, sure. Sometimes you need to separate the joint for other reasons such as driveshaft removal or other maintenance and you don't want to damage the boots.
1994 BMW 530i, 241K
1996 Honda Accord, 267K
1999 Toyota Sienna, 409K
2000 Toyota ECHO, 280K
Re: Whats a good budget ball joint press? [Re: Black_Thunder] #4650902
01/30/18 09:54 AM
01/30/18 09:54 AM
Illinois
SHOZ Offline
SHOZ  Offline
Illinois
My Hyundai Accent is the only car I've owned that had bolt on ball joints.
2008 Hyundai Accent 1.6L 5 sp manual hatchback
2010 Hyundai Genesis Coupe Track 2L Turbo 6sp manual
