How to dispose / recycle Li-Ion batteries?
by 92saturnsl2. 03/24/19 06:16 PM
New member of the (automotive) family!
by addyguy. 03/24/19 06:04 PM
6.2 f250 6.4 ram 2500 towing with a gasser
by FLORIDA. 03/24/19 05:55 PM
T5 15w40 for my bike?
by Degreaser. 03/24/19 05:47 PM
Studded tires in warm weather
by y_p_w. 03/24/19 05:28 PM
ST 15W40
by mobilaltima. 03/24/19 05:02 PM
I need a filter cutter person
by Marco620. 03/24/19 03:21 PM
VIRGIN BOSCH D+ 3421 CUT OPEN
by 53' Stude. 03/24/19 02:45 PM
My first cut. Donaldson P502503
by BeerCan. 03/24/19 02:25 PM
Sludge and Facebook's infinite wisdom
by RDY4WAR. 03/24/19 02:05 PM
Gear lube 75W90 Synthetic GM# 88900401
by rcbob. 03/24/19 01:47 PM
Rislone Rebates
by Nickdfresh. 03/24/19 01:42 PM
IndyCar Classic at COTA
by bdcardinal. 03/24/19 12:29 PM
STP 500 at Martinsville
by bdcardinal. 03/24/19 12:27 PM
Source For Microfiber Towels
by Wrenchturner44. 03/24/19 12:26 PM
Jcountry, CMichael, dude59, Petrolhead, stp
67608 Registered Users
114 registered members (2003f7, 53' Stude, 2015_PSD, A1O, ammolab, Aichiguy, 17 invisible), 2,127 guests, and 61 spiders.
Topics286,352
Posts4,906,957
Members67,608
Most Online2,967
Mar 10th, 2019
Honda Shin Etsu ? #4635095
01/14/18 09:04 PM
01/14/18 09:04 PM
Rochester
Drew1987 Offline OP
Drew1987  Offline OP
Rochester
Hello
I have an odyssey and with this wonderful negative Fahrenheit temps lately, the doors are freezing shut. If you know Odysseys, very expensive door parts and tens of hours I donít want to spend wrenching in the cold (been there, done that. Both sides!). Someone recommended Shin Etsu grease from Honda, said itís amazing. Just wondering what it is, if there is a good alternative, and if there is something else all together you all could recommend for this? Iíve used silicon grease (Napa silglide) for sunroofs but no risk of wife and/or kids rubbing against that. We typically donít stand out of the sunroofs anymore
Thanks all
Re: Honda Shin Etsu ? [Re: Drew1987] #4635101
01/14/18 09:10 PM
01/14/18 09:10 PM
Utah
CKN Offline
CKN  Offline
Utah
I have used that grease and it's a perfect solution for what you need. I used it for squeaky rubber door seals on a Honda Accord that made all kind of noise. They quieted right down.
Yes-it's expensive but works.
Re: Honda Shin Etsu ? [Re: Drew1987] #4635102
01/14/18 09:10 PM
01/14/18 09:10 PM
Bucks, PA
zfasts03 Offline
zfasts03  Offline
Bucks, PA
Shin Etsu grease from Honda works great. I cut a sponge into a small piece approx. 1 x 3 inches (dampen sponge with water to soften). A little on the weatherstripping spreading it as far as you can. It conditions, protects and lubricates weatherstripping.
1 tube will last for many years and do many cars.
- 03 Corvette Z06
Amsoil 5w-30 SS
- 07 Honda Accord 2.4L
Amsoil 5w-20 SS
- 16 Suburban 5.3L
Amsoil 0w-20 SS, XG10575(16-28 by-pass)
- 18 4Runner TRD Off Road
Amsoil 0w-30 SS, TRD filter
Re: Honda Shin Etsu ? [Re: Drew1987] #4635130
01/14/18 09:27 PM
01/14/18 09:27 PM
Rochester
Drew1987 Offline OP
Drew1987  Offline OP
Rochester
Well sounds like I got my answer! Thanks guys. So itís worth the money over Napa Silglide?
Re: Honda Shin Etsu ? [Re: Drew1987] #4635136
01/14/18 09:31 PM
01/14/18 09:31 PM
Rochester
Drew1987 Offline OP
Drew1987  Offline OP
Rochester
and we are talking $20, yes?
Re: Honda Shin Etsu ? [Re: Drew1987] #4635162
01/14/18 10:03 PM
01/14/18 10:03 PM
Bucks, PA
zfasts03 Offline
zfasts03  Offline
Bucks, PA
A little goes a long way use sparingly.
- 03 Corvette Z06
Amsoil 5w-30 SS
Amsoil 5w-20 SS
- 16 Suburban 5.3L
Re: Honda Shin Etsu ? [Re: Drew1987] #4635168
01/14/18 10:11 PM
01/14/18 10:11 PM
out there
spasm3 Online content
spasm3  Online Content
out there
Is sil-glyde comparable?
13 elantra 75k 5w30 QSUD
03 chevy avalanche 80k synpwr 5w30
17 mazda cx-5 9500 miles m1 0w30
Re: Honda Shin Etsu ? [Re: Drew1987] #4635192
01/14/18 10:46 PM
01/14/18 10:46 PM
Chicago, IL
EdwardC Offline
EdwardC  Offline
Chicago, IL
I have a tube of Shin Etsu and it is pretty fantastic, but I don't know if any other quality silicone paste wouldn't work just as well.
The Shin Etsu isn't particularly less greasy than the 3M or Mission Automotive 100% silicone paste that I have also used. I think the key is that you are putting on a very very thin layer, rubbing it in a little, then rubbing off the excess. Should properly clean everything before applying as well. Both those silicone pastes are in the $20 range for an 8 oz bottle though.
I've never used Sil-Glyde, but I remember reading that it wasn't 100% silicone, and had other stuff that might not be as great for rubber. I don't know that to be fact though.
Re: Honda Shin Etsu ? [Re: Drew1987] #4635201
01/14/18 11:06 PM
01/14/18 11:06 PM
PimTac Offline
PimTac  Offline
Sounds like Gummi Pflege from Nextzett (Einzett)
Cannot see signatures any longer so it doesn’t matter.
Re: Honda Shin Etsu ? [Re: PimTac] #4635259
01/15/18 12:28 AM
01/15/18 12:28 AM
North Carolina
rooflessVW Offline
rooflessVW  Offline
North Carolina
That and Shin Etsu are all I'll use... But to me at least they serve different purposes.
I'd use Gummipfleger on an old seal to help rejuvenate it, then Shin Etsu to help maintain it. Shin Etsu is better for newer seals or for seals that need a little help, like the 128x10Ļ≤ in a modern convertible top.
"Zed's dead baby, Zed's dead."
Re: Honda Shin Etsu ? [Re: Drew1987] #4635383
01/15/18 07:17 AM
01/15/18 07:17 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Good stuff for weatherstrip and door window slides, it really makes the window operation smoother and takes wear and tear of the motor and regulator especially the cable type.
Just lower the window and use a long wooden Q tip to smear it inside the track on the door frame.
Re: Honda Shin Etsu ? [Re: Drew1987] #4635402
01/15/18 07:54 AM
01/15/18 07:54 AM
Rochester
Drew1987 Offline OP
Drew1987  Offline OP
Rochester
Thanks all. I am really glad I asked. Iíll be picking some up for sure
Re: Honda Shin Etsu ? [Re: Drew1987] #4635411
01/15/18 08:05 AM
01/15/18 08:05 AM
NY
demarpaint Offline
demarpaint  Offline
NY
Smart move, and well worth it!
God Bless Our Troops
Re: Honda Shin Etsu ? [Re: zfasts03] #4635480
01/15/18 09:29 AM
01/15/18 09:29 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
very sparingly - the film need only be the thickness of one molecule grin
Re: Honda Shin Etsu ? [Re: Drew1987] #4635524
01/15/18 10:04 AM
01/15/18 10:04 AM
DFW
DBMaster Offline
DBMaster  Offline
DFW
From a suggestion on this forum a few years ago I started using DOT 5 silicone brake fluid. I don't know what the percentage of silicon is, but it works very well. It can also be used to condition the rubber on wiper blades. The single small bottle I bought will last me the rest of my life.
