Redline releases Professional Series
by Marco620. 03/20/19 11:52 PM
M1 HM 10w-30 vs M1 FS 0w-40
by RDY4WAR. 03/20/19 10:04 PM
Need Recommendations For A New SUV
by Dwight_Frye. 03/20/19 08:50 PM
GE dishwasher clicking
by silverrat. 03/20/19 08:20 PM
Every 6 months or one year OCI
by asker123. 03/20/19 07:36 PM
Valu Home Ctr. Peak Oil $9.94/5 qt jugs
by Nickdfresh. 03/20/19 07:32 PM
Chemical fire in texas
by Fitter30. 03/20/19 07:09 PM
PZ 37 CUT OPEN
by 53' Stude. 03/20/19 06:42 PM
Lube Intervals
by NibbanaBanana. 03/20/19 06:41 PM
When to send in oil for testing?
by SnowDrifter. 03/20/19 06:12 PM
ATF vs CHF
by GG16v. 03/20/19 05:40 PM
Landline Answering Machines
by das_peikko. 03/20/19 05:10 PM
Mobil oil on “clearance” at Target
by WiskyBadger. 03/20/19 04:04 PM
Master Mechanic Motor Oil @ True Value
by CG_BrianM. 03/20/19 01:35 PM
Some cars haven't changed much in 30 years...
by addyguy. 03/20/19 01:16 PM
Super Knock - Engineering Explained
by StevieC. 03/20/19 01:11 PM
Mobil Super Synthetic Clearance at Meijer
by Tjbouwhu. 03/20/19 12:53 PM
DarkFrontier, Zuraxus, Burks21, GG16v, fleetwood62
67572 Registered Users
43 registered members (bbhero, Ag76, ArrestMeRedZ, Agnosto, Brad_C, Bailes1992, 6 invisible), 947 guests, and 57 spiders.
Topics286,170
Posts4,903,516
Members67,572
Most Online2,967
Mar 10th, 2019
Chevy 5.7 and cleaning #4634874
01/14/18 05:52 PM
01/14/18 05:52 PM
USA
lght1 Offline OP
lght1  Offline OP
USA
Hi
I havent posted here in ages but thought I'd post a cleaning question for my old school Chevy Vortec 5.7. Last fall I finally found a nice old body style Chevy Tahoe 2dr that was a southern rust free truck.
After acquiring it, we recently did the MPFI upgrade and while having the upper intake off the truck, noticed how dirty the top of the lower intake was.
The engine seems to be a replacement as the odometer shows 198,000 miles yet goes over 3000 miles on a quart of Penz 5w-30 synthetic.
To gently clean this engine, rather than run a "cleaner" through it, when spring arrives, I think I will try running 15-40 Rotella through the engine.
Any thoughts of this?
Thanks
Re: Chevy 5.7 and cleaning [Re: lght1] #4634885
01/14/18 06:07 PM
01/14/18 06:07 PM
Tennessee
ChevyMan93 Offline
ChevyMan93  Offline
Tennessee
I dont have anything useful to add, but i thought id congratulate you on saying Vortec instead of vortex! People always say vortex and it drives me up a wall lol
2016 Chevrolet Silverado Z71 5.3
2017 Honda CR-V 2.4
Re: Chevy 5.7 and cleaning [Re: lght1] #4634897
01/14/18 06:16 PM
01/14/18 06:16 PM
USA
lght1 Offline OP
lght1  Offline OP
USA
Hi
Thanks grin
Re: Chevy 5.7 and cleaning [Re: lght1] #4634910
01/14/18 06:26 PM
01/14/18 06:26 PM
Phoenix, AZ
Nick1994 Offline
Nick1994  Offline
Phoenix, AZ
Im not sure why youd think that consumption and mileage has anything to do with a replacement engine?
Id pop off a valve cover to see how dirty it is.
Personally, Id just keep using Pennzoil 5w30 for the cleaning and change it every 3,000 miles.
2015 Hyundai Sonata 2.4L 92k STP Synthetic HM 10w30 & Wix
2000 Toyota Camry 2.2L 233k Mobil Super HM 10w40 & Fram Ultra
1996 Jeep Cherokee 4.0L 148k Mobil 1 HM 10w40 & Fram Ultra
Re: Chevy 5.7 and cleaning [Re: lght1] #4634935
01/14/18 06:48 PM
01/14/18 06:48 PM
USA
lght1 Offline OP
lght1  Offline OP
USA
Hi
The truck, if not the engine, has 200,000 miles. I have polled others with this engine /mileage combo and 3000 miles to a quart of synthetic is not typical, hence the replacement engine theory.
I am inclined to use HDEO, Rotella, for the cleaning on the lower intake. Possible a bad pcv was to blame at some point.
Re: Chevy 5.7 and cleaning [Re: lght1] #4634937
01/14/18 06:50 PM
01/14/18 06:50 PM
Iowa
Nyquist Offline
Nyquist  Offline
Iowa
Does it leak oil? That would be the first thing I would check as opposed to assuming the missing oil is due to consumption. All that takes is a gasket replacement to fix.
2015 Chevy Traverse 3.6L (LLT) Mobil 1 5w30 w/ Fram Ultra
2018 Chevy Cruze 1.4L (LE2) Mobil 1 5w30 w/ ACDelco
Re: Chevy 5.7 and cleaning [Re: lght1] #4634941
01/14/18 06:51 PM
01/14/18 06:51 PM
Campbellsville, KY
Alex_V Offline
Alex_V  Offline
Campbellsville, KY
Congrats on a nice truck (the 2 dr. Tahoe has always caught my eye) with a darn good engine.
I think you have two misconceptions we need to dispel.
Oil consumption is not directly related to mileage, especially on an engine that is capable of over twice as many miles as yours has on it. It's possible it's been changed but engines treated properly can consume very little oil for much longer than that - you'll maintain your Vortec 350 wrong if you believe it's impossible for an engine to show almost no wear at 200K.
Secondly, Rotella 15w40 is a good oil but only a good choice in this engine if it's being worked to its limit in very hot weather or has low oil pressure. It's also not ideal for cleaning it up inside - thicker oils don't flush dirt away as well as thinner ones. A high mileage synthetic or blend will suit this engine very well - my dad has a '97 Suburban that has logged over 250,000 miles on Valvoline Maxlife 10w30 or 10w40... beginning at 170,000 when he got it. That engine has over 430K overhaul-free miles on it and consumption hasn't increased noticeably since he got it. I rest my case.
To quote a friend, "Synthetics, man."
'85 GMC C3500, 454, 132K
'82 Mercedes 300CD, OM617 turbo, 173K (totaled 2018, in rehab)
'85 Mercedes 300TD, OM617 turbo, 217K (wife's)
'67 Suburban, 350, 331K
Re: Chevy 5.7 and cleaning [Re: lght1] #4634973
01/14/18 07:18 PM
01/14/18 07:18 PM
USA
lght1 Offline OP
lght1  Offline OP
USA
Hi
Not sure why I would want to go to a blend for cleaning if I am already using Penz Plat 5w-30.
The Rotella is only for cleaning up the mess a sticky pcv may have left. Btw, this engine has metal backed lower intakes which the '97 orig engine were not built with. With the cleanliness of the external surface of the engine, I feel it was likely replaced.
When I got it in Oct, I replaced all rad hoses and flushed the Dex out and filled with G-05, a Hybrid OAT I have used for years.
I fluid filmed the truck before the snow came, so the nasty salt should have negligible opportunity to do its work.
Re: Chevy 5.7 and cleaning [Re: lght1] #4634979
01/14/18 07:26 PM
01/14/18 07:26 PM
Campbellsville, KY
Alex_V Offline
Alex_V  Offline
Campbellsville, KY
Ah, sorry - I glanced up at Nick1994's reply to double check the type/weight and he didn't say synthetic. No, there's no compelling reason to move back to a syn blend from that oil. If there's other evidence it was replaced then it may have been, but that information wasn't in your original post. I still wouldn't use 15w40 to "clean up" an engine that will otherwise see 5- or 10w30.
Re: Chevy 5.7 and cleaning [Re: lght1] #4634986
01/14/18 07:35 PM
01/14/18 07:35 PM
USA
lght1 Offline OP
lght1  Offline OP
USA
Quote:
"Does it leak oil? That would be the first thing I would check as opposed to assuming the missing oil is due to consumption. All that takes is a gasket replacement to fix."
No leaks. 3000 miles to a qt is very acceptable. :-) It appears this engine doesn't have a consumption problem.
I wanted to clean up the nasty mess caused likely by a $3.00 pcv a prior owner neglected.
Re: Chevy 5.7 and cleaning [Re: lght1] #4635013
01/14/18 07:56 PM
01/14/18 07:56 PM
Oshawa, Ont. Canada
irv Offline
irv  Offline
Oshawa, Ont. Canada
I'd stick to the PP or PUP 5W-30 if you want further cleaning. I don't know with a 100% certainty, but I don't think there's a better cleaning oil on the market, and according to Pennzoil, there isn't.
2017 Chevy Impala 3.6 L.
2013 Ram 5.7 L Hemi Bighorn QC 4x4
2008 Chevy Malibu 2.4 L Ecotec
Pennzoil Platinum and/or Pennzoil Ultra Platinum in all 3.
Re: Chevy 5.7 and cleaning [Re: lght1] #4635067
01/14/18 08:46 PM
01/14/18 08:46 PM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
The intake and heads may have been bolted to a new'ish short block, w/o cleaning ...
I'd run whatever you want for oil and toss a full can of BG109 in there 100 miles before every change. Drive that last 100 miles around town w/o revving the life out of it, and then do filter and oil smile
Due to the heat riser crossover in the manifold, they always back-on some crud to the underside. Perfectly normal smile
Re: Chevy 5.7 and cleaning [Re: lght1] #4635196
01/14/18 11:02 PM
01/14/18 11:02 PM
USA
lght1 Offline OP
lght1  Offline OP
USA
Hi
This one looked somewhat worse than what I saw on y-tube. Perhaps I will just keep going with the Penz Plat and change at 5000k.
Re: Chevy 5.7 and cleaning [Re: lght1] #4635244
01/15/18 12:02 AM
01/15/18 12:02 AM
Colorado
Chris B. Offline
Chris B.  Offline
Colorado
I have a 1997 GMC Sierra with the 5.7 Vortec. It only has 85,000 miles and only sees 1,000 milers per year and sits in the garage most of the time. I change the oil(Castrol GTX 5w30)once per year or 1,000 miles and it burns zero oil in that OCI.
Re: Chevy 5.7 and cleaning [Re: lght1] #4635254
01/15/18 12:19 AM
01/15/18 12:19 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
My 1995 K3500 (7.4 liter, not 5.7) has 284,000 and uses 1 quart in 2500-3000 driven lightly
(if its being worked hard, it'll use a quart in 1800-2000 or so) - Original engine, never rebuilt
15W-40 most all it's life..
usually TSC Traveler or Cenex(Land o' lakes) 15W-40,
sometimes SuperTech from walmart.
