Toyota factory pink mixed with zerex coolant
by Rohan. 04/21/19 04:48 PM
Schaeffer 204SAT and 205A
by Gebo. 04/21/19 04:32 PM
Oil for old Chevy TBI 350
by RonRonnster. 04/21/19 04:19 PM
2012 chevy equinox transmission fluid
by krdoss. 04/21/19 03:50 PM
How Often Change Fuel Filters?
by Gebo. 04/21/19 03:17 PM
New Hyundai Elantra tell me all I need to know
by DONWATERS. 04/21/19 02:28 PM
How much balance weight is too much
by Hitman70. 04/21/19 02:02 PM
bought steel cut oats by mistake
by andyd. 04/21/19 01:50 PM
Mobil1 Synthetic Lubricating Spray
by EvanR. 04/21/19 01:01 PM
List of cars you've owned
by SLO_Town. 04/21/19 12:30 PM
Email Notice
by borgward. 04/21/19 12:14 PM
Why would 10w burn more than 5w?
by D1dad. 04/21/19 11:57 AM
02 Silverado 5.3L, LT, Low Oil Pressure
by Gito. 04/21/19 11:54 AM
0 to 60 in 1.9 seconds...
by JeffKeryk. 04/21/19 11:16 AM
Luxury Car Owners Switching to Pickup Trucks
by SubLGT. 04/21/19 11:05 AM
Easiest Way to Gravity Bleed Brakes
by jims5600. 04/21/19 10:55 AM
Newcastle Brown Ale replacement?
by Reddy45. 04/21/19 10:31 AM
Easter Sunday
by gman2304. 04/21/19 10:17 AM
Old Buick Century Question
by GrtArtiste. 04/21/19 10:03 AM
Texas72, RamblerReb, rchapin, js1956, krdoss
67865 Registered Users
92 registered members (53' Stude, andyd, Astro14, alphadog, 2dogs, 2015_PSD, 12 invisible), 1,897 guests, and 25 spiders.
Topics287,853
Posts4,935,596
Members67,865
Most Online2,967
Mar 10th, 2019
Page 1 of 4 1 2 3 4
Fram Ultra restict flow? #4634709
01/14/18 02:58 PM
01/14/18 02:58 PM
Illinois
SHOZ Offline OP
SHOZ  Offline OP
Illinois
On my Genesis Coupe 2L turbo I am using Mobil 1 0w40 and a Fram XG3593A filter. That filter is just a bit bigger than the Fram XG9688 which is the recommended filter. I have about 12k miles on the filter, second oil change for it.
I don't usually drive the car in the extreme cold but did last night at 5F. The oil pressure peaked at 74psi at around 3000 rpm and would not go higher. This is cold or hot (180F) oil.
In the past I have seen upper 80's usually at redline, 7500 rpm.
I was surprised that at 3k rpm and cold oil it peaked so low. I'm guessing the oil pump is seeing higher pressure and bypassing?
2008 Hyundai Accent 1.6L 5 sp manual hatchback
2010 Hyundai Genesis Coupe Track 2L Turbo 6sp manual
Re: Fram Ultra restict flow? [Re: SHOZ] #4634726
01/14/18 03:13 PM
01/14/18 03:13 PM
NJ
Leo99 Offline
Leo99  Offline
NJ
Why aren't you using the recommended filter?
Is this something new for the filter? Maybe it's getting clogged and bypassing?
Without data you're just another person with an opinion. W. E. Deming
2003 Corolla 250,000 miles (RIP)
2004 Corolla 125,000 miles
2004 Rav4 370,000 miles
2015 Camry 70,000 miles
Re: Fram Ultra restict flow? [Re: Leo99] #4634735
01/14/18 03:19 PM
01/14/18 03:19 PM
Illinois
SHOZ Offline OP
SHOZ  Offline OP
Illinois
It's the second oil change on the filter for a total of around 12k miles currently. It is something new for the car. I had higher oil pressure last summer with it.
Not a whole lot of difference between the XG9688 and the XG3593A. Just a little bit longer. I usually run the XG9688 but bought one of the other to use and cut open.
Re: Fram Ultra restict flow? [Re: SHOZ] #4634745
01/14/18 03:33 PM
01/14/18 03:33 PM
Georgia
MParr Offline
MParr  Offline
Georgia
Maybe you should have changed the filter when you changed the oil. Have you seen the TSB concerning oil viscosity and oil change intervals?
http://genesisforums.org/attachments/gen...e-09-em-003.pdf
2019 VW Tiguan SE Now: Factory fill & OEM filter
2017 Ford Escape SE 2.0T Now: NAPA Synthetic 5W30 & NAPA Gold 1348
Re: Fram Ultra restict flow? [Re: SHOZ] #4634746
01/14/18 03:35 PM
01/14/18 03:35 PM
Illinois
SHOZ Offline OP
SHOZ  Offline OP
Illinois
Yes I have seen the TSB. It's referring to the OE filter though.
Re: Fram Ultra restict flow? [Re: SHOZ] #4634750
01/14/18 03:37 PM
01/14/18 03:37 PM
Wet side WA
JohnnyJohnson Offline
Wet side WA
I doubt very much it restricted any flow it was very likely in bypass.
2004 Corolla 130880
Out: EDGE EP 5W-30 Bosch 3311 7156 Miles
In: Havoline Pro DS 10w-30 Purolator PureOne 3-14-19 129693
2006 Duramax 74725
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: Fram Ultra restict flow? [Re: JohnnyJohnson] #4634755
01/14/18 03:44 PM
01/14/18 03:44 PM
Illinois
SHOZ Offline OP
SHOZ  Offline OP
Illinois
If the filter was in bypass on hot oil would that not mean it is too restrictive?
BTW that TSB was put out because Hyundai shipped the first year 2L turbos out with 5w20 oil.
Re: Fram Ultra restict flow? [Re: SHOZ] #4634759
01/14/18 03:48 PM
01/14/18 03:48 PM
Georgia
MParr Offline
MParr  Offline
Georgia
SHOZ
I referring to the TSB I pasted on my above reply. It doesn’t talk about what brand filter you should use.
Re: Fram Ultra restict flow? [Re: SHOZ] #4634764
01/14/18 03:59 PM
01/14/18 03:59 PM
San Antonio, TX
das_peikko Online content
das_peikko  Online Content
San Antonio, TX
XG9688
XG3593A
The only way I'd run the larger filter is if the base gasket size was the exact same size as the specified filter. That way the only difference would be the length of the filter. Your selection doesn't match up which introduces all kinds of variables into the mix. If the substitute filter is affecting the flow rate, which of the differences is having the affect? You've got a difference in overall length, overall diameter, base gasket dimensions, and by-pass valve setting. Kind of spooky.
Re: Fram Ultra restict flow? [Re: MParr] #4634792
01/14/18 04:28 PM
01/14/18 04:28 PM
Illinois
SHOZ Offline OP
SHOZ  Offline OP
Illinois
Originally Posted By: MParr
SHOZ
It's from Hyundai right? What other filter would they be considering. This is not he Hyundai after market filter TSB.
Re: Fram Ultra restict flow? [Re: SHOZ] #4634851
01/14/18 05:23 PM
01/14/18 05:23 PM
Georgia
MParr Offline
MParr  Offline
Georgia
Hyundai TSB-09-EM-003
It more or less says use 5W20, 5W30 or 5W40 oils
For the 2.0T
Normal service: Every 4,800 miles or 6 months
Severe Service: Every 3,000 miles or 3 months
For the 3.8 V6
Normal service: 7,500 miles or 12 months
Severe service: 3,750 miles or 6 months
NO FILTER MENTIONED
Check the Genesis Coupe forums and see what filters they are using.
Re: Fram Ultra restict flow? [Re: SHOZ] #4634858
01/14/18 05:33 PM
01/14/18 05:33 PM
Illinois
SHOZ Offline OP
SHOZ  Offline OP
Illinois
That tsb is the same as what the owners manual says.
The 2013s they dropped the 5w20 oil.
I don't drive it much when it's cold so I guess I'll see what it's like next spring.
Re: Fram Ultra restict flow? [Re: SHOZ] #4634871
01/14/18 05:46 PM
01/14/18 05:46 PM
Tennessee
goodtimes Offline
goodtimes  Offline
Tennessee
The flow stays the same unless the oil pump relief valve opens, or the oil pump is worn. This should be a class on here. Lower oil pressure, all else being equal, oil, temp, etc, means parts clearances in the galleries beyond the oil sender are wider. Higher oil pressure, more restriction. Lower oil pressure, less restriction. At the sender. It took me a while reading here to understand this. I still am working on it. ZeeOughtSix does a better job of explaining it.
Re: Fram Ultra restict flow? [Re: SHOZ] #4634886
01/14/18 06:10 PM
01/14/18 06:10 PM
Illinois
SHOZ Offline OP
SHOZ  Offline OP
Illinois
There is plenty of oil pressure. It just peaks too early at 3k rpms and too low compared to what it use to do. Hot idle is over 20 psi.
Re: Fram Ultra restict flow? [Re: SHOZ] #4634905
01/14/18 06:20 PM
01/14/18 06:20 PM
Western S.C.
CR94 Offline
CR94  Offline
Western S.C.
Someone is overly worried about a non-problem, methinks.
2011 Toyota Prius now at 98K
Page 1 of 4 1 2 3 4
