Hey folks - I've done some searching and have found very little info on here about Subaru's in general
I'll get the questionnaire first
1. What kind of vehicle you have
2004 Subaru STI (USDM) EJ257 engine has been rebuilt using Forged Pistons and Rods. The car is running a slightly larger than stock turbo ( Blouch 16G XTR Blouch 16G XTR). I'm also running E85 Fuel on a daily basis. The car also runs an aftermarket oil pan with an additional 1 quart capacity.
2. What your owner's manual says -- not just viscosity, but certifications (look for acronyms like API SM, ILSAC GF-4, etc.) and change intervals as well
I'm so far from original, I don't think this is super relevant, but 5W30 ILSAC GF-3
Interval is ~4000 miles per Subaru service bulletin years ago
3. Where you live
Silicon Valley
4. How you drive (easy? hard? fast? slow?)
The car is now having a 50-mile roundtrip commute in heavy bay area traffic. When I have room to run the car gets driven hard seeing canyon runs and autocross.
5. What your daily drive is like (short trips? long trips? city? highway?)
see above
6. Whether your car has any known problems
No
Here's the situation, for years my Subaru has been mostly a weekend/nights car. In the past, I've always used Torco, Redline or Amsoil for my motor oil. Figured they were overkill, but here we are. Subaru STI's have a short oil change cycle of 4000 miles, this isn't due to old thinking, that is the actual factory recommendation.
I've recently taken a new job that's about 25 miles away and have to use this car to commute (
). Now that I'm putting 1000+ miles per month on the car I'm really not wanting to spend $14/quart on oil; so am considering some less expensive options.
My company has a deal with Castrol (no not German) where I can buy it CHEAP so I'm leaning towards Edge.
I have nothing technical to back this up, but Mobil 1 is universally reviled in the Subaru community. Something about the formulation supposedly eats rod/main bearings.
I've built a spreadsheet trying to compare oils and that hasn't gone well.
Spreadsheet
When I asked the engine builder about what to use, his answer was a rather ambiguous "use Motul, Torco, Redline... they are all fine "
I'd love a recommendation from the pros
3. Where you live
Silicon Valley
see above
No
Spreadsheet
