How to fix swollen deckwood
by RazorsEdge. 03/18/19 01:52 PM
Which is more important: Oil or Filter?
by RDY4WAR. 03/18/19 01:45 PM
Dishonest car dealership?
by aquariuscsm. 03/18/19 01:21 PM
Phillips 66 Shield Choice $1.99 @ Orscheln
by Pat in Speedway. 03/18/19 12:41 PM
Barely there back seats
by y_p_w. 03/18/19 11:47 AM
should i be afraid of the DCT ?
by WhyMe. 03/18/19 11:28 AM
Friction modifiers
by Truckedup. 03/18/19 10:57 AM
Sometimes, choices are made for you!
by addyguy. 03/18/19 10:30 AM
I Hope This Amuses You Guys Like It Did Me
by NYEngineer. 03/18/19 10:27 AM
New Exmark Lazer Z / Oil ?
by johnD2. 03/18/19 10:13 AM
First welder recommendation
by Astro14. 03/18/19 09:55 AM
Amsoil Burning
by ridgerunner. 03/18/19 09:38 AM
2007 Sonata Pinging + DTCs
by F24Sonata. 03/18/19 09:31 AM
Nissan Maxima 2009 synthetic oil choices
by mahanddeem. 03/18/19 09:23 AM
Best coated rotors
by JMHC. 03/18/19 09:11 AM
Brake Bleeder Question
by maverickfhs. 03/18/19 08:57 AM
Ring alarm system, any good?
by Redright9. 03/18/19 08:18 AM
4 oil changes Saturday.
by ls1mike. 03/18/19 08:08 AM
Careers.....Boomers vs Millennias
by ZZman. 03/18/19 08:05 AM
Indyfordfan, toplscuda, swrve, TomRx, Ozdave
67548 Registered Users
108 registered members (aquariuscsm, AandPDan, advocate, aircooled, 2003f7, 53' Stude, 13 invisible), 2,309 guests, and 55 spiders.
Topics286,017
Posts4,900,829
Members67,548
Most Online2,967
Mar 10th, 2019
'97 Astro cam/timing data #4633992
01/13/18 09:08 PM
01/13/18 09:08 PM
Campbellsville, KY
Alex_V Offline OP
Alex_V  Offline OP
Campbellsville, KY
A customer with a '97 Astro (4.3, AWD) is trying to rule out a stretched timing chain as the cause of some problems: mainly, when placed under load it intermittently stumbles and then will run awful (missing and carrying on) until it's shut off and restarted.
Codes:
P0337 "CKP sensor A signal low frequency"
P0339 "CKP sensor A signal intermittent"
P0341 "CMP sensor circuit out of range"
Watching the live data as it idled in my shop, ignition timing was running right around 20 while "cam retard" was showing -6 or -7. How exactly do these two numbers correlate? Is the cam retard number comparing crank sensor to cam sensor, saying that it sees the cam (and therefore, distributor shaft) running 6 degrees behind the crank?
I had no time to do any physical checks, and the weather was going downhill fast so I didn't take it for a drive at the time - we agreed I'd do some homework on the codes and follow up later. He has changed the cam and crank sensors but says he's not moved or removed the distributor. Are the 4.3 dizzy's prone to excess wear on the driven gear like the Vortec V8's are?
To quote a friend, "Synthetics, man."
'85 GMC C3500, 454, 132K
'82 Mercedes 300CD, OM617 turbo, 173K (totaled 2018, in rehab)
'85 Mercedes 300TD, OM617 turbo, 217K (wife's)
'67 Suburban, 350, 331K
Re: '97 Astro cam/timing data [Re: Alex_V] #4634006
01/13/18 09:23 PM
01/13/18 09:23 PM
Fort Worth, Texas
clinebarger Offline
clinebarger  Offline
Fort Worth, Texas
I would ignore the P0341 for the time being.
Check the CKP wiring, Especially right at the CKP Connector as oil leakage/seepage can rot away the wiring insulation.
Cam Retard Offset readings are not accurate at idle, You have to rev the engine to 1200-1500 RPM.
2001 Chevy Camaro L92/4L80E
Re: '97 Astro cam/timing data [Re: Alex_V] #4634008
01/13/18 09:28 PM
01/13/18 09:28 PM
Campbellsville, KY
Alex_V Offline OP
Alex_V  Offline OP
Campbellsville, KY
I did, up to maybe 3,000 RPM. I didn't make great note of any of the readings but if memory serves, cam retard stayed about the same with ignition timing climbing up to about 30 degrees.
Re: '97 Astro cam/timing data [Re: Alex_V] #4634014
01/13/18 09:38 PM
01/13/18 09:38 PM
Fort Worth, Texas
clinebarger Offline
clinebarger  Offline
Fort Worth, Texas
Cam Retard in the single digits will not cause performance issues, And you don't have a P1345?
Re: '97 Astro cam/timing data [Re: Alex_V] #4634143
01/14/18 01:01 AM
01/14/18 01:01 AM
USA
oldhp Offline
oldhp  Offline
USA
We always would put the timing mark on TDC. Now turn the crankshaft backward while watching the distributor. If you can go more than 10 before the rotor starts to turn, change the chain.
2018 RAM 1500 3.6/8 speed.
2017 Jeep Sahara Unlimited 3.6
"U kan't fixe it......if'n it ain't broke."
Re: '97 Astro cam/timing data [Re: clinebarger] #4634306
01/14/18 09:28 AM
01/14/18 09:28 AM
Campbellsville, KY
Alex_V Offline OP
Alex_V  Offline OP
Campbellsville, KY
Nope, no 1345 - only those three. The first thing I'm doing if it comes back in is inspect the wiring to the sensors.
Re: '97 Astro cam/timing data [Re: oldhp] #4634307
01/14/18 09:28 AM
01/14/18 09:28 AM
Campbellsville, KY
Alex_V Offline OP
Alex_V  Offline OP
Campbellsville, KY
Good idea.
Re: '97 Astro cam/timing data [Re: Alex_V] #4634490
01/14/18 11:45 AM
01/14/18 11:45 AM
MN
14Accent Offline
14Accent  Offline
MN
Sounds like a failing crank sensor.
Can't recall seeing a timing chain stretch on any 4.3, not that it's impossible. But I would doubt it.
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
2003 Cadillac Seville STS - The winter "beater", it uses the Volt's fuel
Re: '97 Astro cam/timing data [Re: oldhp] #4634501
01/14/18 11:55 AM
01/14/18 11:55 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
REALLY? I would think that's about normal.
I wonder what a new one does.
Re: '97 Astro cam/timing data [Re: 14Accent] #4634949
01/14/18 06:56 PM
01/14/18 06:56 PM
Campbellsville, KY
Alex_V Offline OP
Alex_V  Offline OP
Campbellsville, KY
I'm also skeptical it's the chain, even with 230K on it. "Bad timing chain" gets thrown around a lot in recent years because of all the OHC engines, but a lot of people don't understand how rare it is for these short OHV chains to ever become a problem.
Re: '97 Astro cam/timing data [Re: Linctex] #4635301
01/15/18 02:07 AM
01/15/18 02:07 AM
USA
oldhp Offline
oldhp  Offline
USA
2-4....
