Account and posts removal
by newbe46 - 09/16/19 10:00 PM
Yamaha EF2800i break-in
by Uregina09 - 09/16/19 09:43 PM
Adding TCW3 to Gas Tank?
by maverickfhs - 09/16/19 08:45 PM
Motul 75w90 1L 12 pack $13.25
by wkcars - 09/16/19 08:36 PM
2019 Ford Fusion vs used?
by FL-400S - 09/16/19 08:33 PM
What is the reasoning for 2-fuel tanks on a rv?
by RazorsEdge - 09/16/19 07:54 PM
Thoughts and opinions on family haulers
by ram_man - 09/16/19 07:53 PM
2018 Silverado 5.3L M1 AFE 0W-20 5,065
by K20FA5 - 09/16/19 07:43 PM
18 Jeep 3.6 PPU 0w20 5k OCI
by IndyFan - 09/16/19 07:06 PM
Federal 9mm 115g FMJ Brass - $7.97/50 @ Walmart
by blupupher - 09/16/19 06:47 PM
Motorcraft FL-1995W different than than non-W?
by Cubey - 09/16/19 05:31 PM
1973 Bronco w/original 302
by BKinSD - 09/16/19 05:18 PM
B&S 21hp burning oil
by Mike141 - 09/16/19 04:28 PM
Prime Guard POF2222 C&P...
by AnthemBassMan - 09/16/19 03:36 PM
Verizon FIOS direct connect HD local channels
by Vikas - 09/16/19 02:36 PM
Bentonite grease abrasive properties?
by berlyn - 09/16/19 02:19 PM
'13 Camry, ATF replacement
by parshisa - 09/16/19 02:02 PM
R0CKETMAN, Southbend9, Bigaledge32, emilio15, Kokopelli34179
69303 Registered Users
72 registered members (A_Spruce, aquariuscsm, Ag76, b1amgm47, bbhero, 8 invisible), 1,497 guests, and 26 spiders.
Topics294,667
Posts5,064,146
Members69,303
Most Online3,532
Jul 30th, 2019
Stant vs Mopar rad cap #4633599 01/13/18 01:27 PM
H
HoosierJeeper Offline OP
H
Broke the seal on my OEM cap this morning checking the level on my 05 Liberty. Ran to the dealer and they wanted $90 for it and didn't have it in stock. Stopped at a local chain store they recommended and got a Stant for $5, it's 16PSI like the OE one. Do I need to order a Mopar one or is the Stant good enough to stay?
15 Jeep KL Limited V6: Formula Shell 5W20
07 LR3 SE V8: Maxlife 5W30
05 Jeep KJ Limited: PHM 5W30
96 Jeep XJ Country: STP HM 5W30 (winter)
Re: Stant vs Mopar rad cap [Re: HoosierJeeper] #4633619 01/13/18 01:48 PM
J
JC1 Offline
J
I'd go for the Stant.
2015 Grand Caravan SXT Plus 5w-30 Valvoline White Bottle/Fram Ultra Filter
1997 Honda Civic CX 5w-30 Shell Conventional/Fram Ultra Filter
Re: Stant vs Mopar rad cap [Re: HoosierJeeper] #4633620 01/13/18 01:49 PM
O
oldhp Offline
O
No need for over priced OEM one, the Stant will be just fine. I tried to buy a dealer OEM Mopar oil filter (MO-349) for my Jeep Wrangler 3.6....$13.30. Nope. A NAPA Gold for $6.45 will do just fine.
2018 RAM 1500 3.6/8 speed.
2019 Dodge Charger SXT 3.6/8 speed.
"When others cut you down, remember where they came from."
"I don't run...........I just wait"
Re: Stant vs Mopar rad cap [Re: HoosierJeeper] #4633623 01/13/18 01:51 PM
1
14Accent Offline
1
WHAT?? $90 is insane. Mopar PN# 4596198 is $15 on Amazon. Your dealer must have hit the crazy button.
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
2003 Cadillac Seville STS - The winter "beater", it uses the Volt's fuel
Re: Stant vs Mopar rad cap [Re: HoosierJeeper] #4633652 01/13/18 02:22 PM
T
Trav Offline
T
Stant blows get an OE one online. Stant was a good name years ago but those day are long gone.
Re: Stant vs Mopar rad cap [Re: HoosierJeeper] #4633689 01/13/18 03:07 PM
T
THafeez Offline
T
pepboys stant rad caps come with a 1 year warranty i believe. Gotta sign up when you buy it. I've never had someone bring it in, but it definitely beats having nothing. Most stores probably won't have a problem replacing it either as long as you have the receipt.
2004 Toyota Solara SE 2.4 2AZFE
187,000 miles
Castrol Magnatec Semi-Syn 5W30 3 quarts and 1 quart of Valvoline Syn-Power 5W30 that I had left over
Fram Ultra XG3600 oversize 1st run
Re: Stant vs Mopar rad cap [Re: HoosierJeeper] #4633701 01/13/18 03:18 PM
Chris142 Offline
We only use stant where I work. The chinese and made in india caps are junk.
02 Wrangler traveler sae30
87 F250 Valvoline 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor Chevron sae30
Re: Stant vs Mopar rad cap [Re: HoosierJeeper] #4633703 01/13/18 03:20 PM
Chris142 Offline
Oh and your 12 yr old cap was way past due for replacement. How swelled is the rubber?
Re: Stant vs Mopar rad cap [Re: HoosierJeeper] #4633708 01/13/18 03:23 PM
H
H
I don't know if it was that swollen, I thought it just broke from the cold and me kind of ripping it out. LOL
Re: Stant vs Mopar rad cap [Re: HoosierJeeper] #4633714 01/13/18 03:31 PM
danez_yoda Offline
I bought one for my toyota on amazon that has a silicone seal that instead of rubber. Pt auto warehouse was the name. Made in japan. Great quality. Stopped my pink sline around the radiator neck. (Pink rad fluid leaking)
Re: Stant vs Mopar rad cap [Re: 14Accent] #4633799 01/13/18 05:00 PM
K
Kruse Offline
K
^This. The $90 that was quoted must have been from my local Mopar/Ram dealer. I'd get a Mopar replacement online instead of a Stant, even though Stant is probably better than some of the other brands now found on RockAuto.
Re: Stant vs Mopar rad cap [Re: 14Accent] #4633874 01/13/18 06:36 PM
slacktide_bitog Online Content
Online Content
approved
Rock Auto has the Mopar cap for $13 with that same part number smile
Re: Stant vs Mopar rad cap [Re: HoosierJeeper] #4633914 01/13/18 07:20 PM
H
H
Thanks for the help everyone! I ordered a Mopar one off eBay. Oddly the Rockauto and every other catalog lists a different one than what it had in it. Rockauto and others spec a 17 or 18PSI, the one in it is a 16 and it's been that way forever. Had a part number on it (mopar 05278697aa) so I figured that's the safest option.
