Ac Delco oil on Rockauto
by WiskyBadger. 03/21/19 11:09 PM
Old Laptop - Keeps Freezing - Help!
by reemoe2. 03/21/19 09:52 PM
Cinnamon Cake
by StevieC. 03/21/19 09:43 PM
AMALIE OILS
by kstanf150. 03/21/19 09:41 PM
oem filters
by mobilaltima. 03/21/19 09:34 PM
Magna1 10W30
by mobilaltima. 03/21/19 09:32 PM
Found triple threat
by deven. 03/21/19 09:26 PM
Chrysler Valvetrain week??
by clinebarger. 03/21/19 08:50 PM
Lisle funnel for radiator drain & fill
by paulri. 03/21/19 07:45 PM
Rattle in Catalytic Converter 2003 Suburban
by Fitz98. 03/21/19 05:59 PM
Mobil1 5W-30 EP, 8317mi, 2007 Prius Touring, 98133
by DuckRyder. 03/21/19 05:32 PM
Maxima Pro Plus 20/50 syn bike oil
by Truckedup. 03/21/19 04:54 PM
CHAMPION COS 3593A **NEW** CUT OPEN
by 53' Stude. 03/21/19 04:28 PM
NAPA PROSELECT 21348 CUT OPEN
by 53' Stude. 03/21/19 04:21 PM
Atlanta No Nonsense Honda dealer
by DuckRyder. 03/21/19 04:16 PM
Echo (PAS) - Good, Bad, Other?
by GemStater. 03/21/19 04:06 PM
Serpentine Belt - When To Change?
by Propflux01. 03/21/19 03:08 PM
Magnetic Out, ST in at Wally Auto Care Center.
by csandste. 03/21/19 02:26 PM
scottjeffrey, Mowata, LoneWolf04, Paperboy, Flinch
67579 Registered Users
75 registered members (97prizm, Aichiguy, 2010Civic, beanoil, allgm59, 8 invisible), 1,255 guests, and 61 spiders.
Topics286,216
Posts4,904,436
Members67,579
Most Online2,967
Mar 10th, 2019
VW 1.6tdi - CJ4 instead of VW507? #4633455
01/13/18 11:11 AM
01/13/18 11:11 AM
Denmark
Donkeye Offline OP
Donkeye  Offline OP
Denmark
Hey!
I'm a bus mechanic, so I have plenty access to free CJ4 oils, 5w-30 vecton fuel save e6/e9.
Would it kill my car, a SEAT Ibiza 1.6tdi (common rail) if I used the CJ4 oil, instead of VW507? Cheers.
Re: VW 1.6tdi - CJ4 instead of VW507? [Re: Donkeye] #4633660
01/13/18 02:31 PM
01/13/18 02:31 PM
Denmark
shDK Offline
shDK  Offline
Denmark
Jeg ville ikke bekymre mig om det. Både cj4 og e6/e9 er ret høje krav.. og er også beregnet til partikelfilter, den skal også have en HTHS på min. 3.5 ligesom VW 507.00 normen. du kunne for en sikkerheds skyld skifte ved dobbelt interval når nu olien er gratis. Men vil mene olien er helt på højde
Re: VW 1.6tdi - CJ4 instead of VW507? [Re: Donkeye] #4634017
01/13/18 09:42 PM
01/13/18 09:42 PM
Albury, NSW
JFAllen Offline
JFAllen  Offline
Albury, NSW
Will it cause problems?
Almost certainly not, HOWEVER:
The big difference between CJ4 oils and 504/507 blends is the ash (SAPS) content. 1% for CJ4 and 0.6% for 504/507. With the EGR/DPF systems on modern small displacement TDi's, blends are specifically designed to limit carbon build-up (especially in the intake tract.) Also the vast majority of CJ4 oils are Mineral G2 oils, thus tend to have higher NOACK values. All 504/507 oils are synthetic and as a result have higher viscosity indices and lower NOACK.
Higher NOACK values for large Diesel engines are not really an issue, as the sump's are massive 10->20L+ is not uncommon for on-road use (sumps in excess of 100L are common on large stationary engines and mining equipment.) Thus the oil, even in constant high load applications (say a generator or a mining truck hauling up hill) tends to remain cooler than in a small displacement passenger diesels. The large units also tend to have massive oil coolers.
Further more they operate at lower RPM (often <2000,) and with complex multi stage filtration systems; CJ4 oils are great for use in their intended applications. Buit not ideal for a small VW 1.6 (oddly enough)
I'm sure there are punters running far worse oils in their VW TDi's, but VW spent a great deal of time, engineering and money ensuring that their engines with the 504/507 spec is the best combination when all things are considered.
I personally use 504/507 Shell Helix Ultra 0W30 in my vehicles (which are not from VW) as it's SN rated and has a VI of >200 with a very low NOACK (can't remember specifically.) It's not that expensive (even in Australia) and is good piece of mind.
Regards
Jordan
Re: VW 1.6tdi - CJ4 instead of VW507? [Re: Donkeye] #4634188
01/14/18 04:00 AM
01/14/18 04:00 AM
Regina, Saskatchewan, Canada
Garak Offline
Garak  Offline
Much was covered, and I couldn't even begin to build upon what shDK said. wink What I would add is that the Vecton would not kill your cats. The E6 lube is low phosphorus.
Plain, simple Garak.
Re: VW 1.6tdi - CJ4 instead of VW507? [Re: Donkeye] #4634210
01/14/18 05:12 AM
01/14/18 05:12 AM
Malaysia
zeng Offline
zeng  Offline
Malaysia
Concur with JF Allen on the above observations between CJ4 vs VW507.
Having said this,typically used in diesel work machines under low speed,high torque,high load and high temperature, I'm of the opinion that a CJ4 E6 E9 Vecton 5W30 is more than adequate in protecting a super-light duty (from the perspective of work machines) 1.6 tdi, hence it could not kill the tdi.
The pertinent question to ask is their respective OCI's, not protection capability per se.
JMHO.
Re: VW 1.6tdi - CJ4 instead of VW507? [Re: Donkeye] #4641967
01/21/18 02:54 PM
01/21/18 02:54 PM
South Wales, UK
Bailes1992 Offline
Bailes1992  Offline
South Wales, UK
If the engine burns relativity little oil I would use it and not look back! Rein in the OCI's a little bit and get a few UOA done before you start to extend them again.
'17 Volvo V40 D3 Geartronic - Total V-Drive 0w20
'18 Dacia Sandero 0.9T - Fuchs GT1 5w40
'96 LR Defender 300TDi - Fuchs GT1 5w40
'12 BMW 320d Sport - Fuchs GT1 5w40
Re: VW 1.6tdi - CJ4 instead of VW507? [Re: Donkeye] #4643746
01/23/18 09:01 AM
01/23/18 09:01 AM
London, England
bigjl Offline
bigjl  Offline
London, England
I can't see what is to be gained apart from a tiny financial saving at the expense of peacs of mind
16 S350d LWB 25k Mobil Super 3000 XE 5w30
17 Smart ForFour Auto 6.5k Mobil 1 0w40 FS
Re: VW 1.6tdi - CJ4 instead of VW507? [Re: Donkeye] #4654709
02/03/18 11:32 AM
02/03/18 11:32 AM
Slovenia EU
Kamele0N Offline
Kamele0N  Offline
Slovenia EU
https://www.oilspecifications.org/acea.php
ACEA E6/E9 more than good for any passenger car equiped with DPF filter...
thumbsup
2008 Toyota Yaris 1ND-TV 1.4 D4-D Elf FullTech FE 5w30
1997 Toyota Landcruiser KZJ95 3.0 TD Shell Rimula R6M 10w40
