New R1250GS and R1250RT
by 02SE. 09/21/18 12:55 AM
Inside Break Booster & Master Cylinder
by StevieC. 09/20/18 11:22 PM
Inside an Alternator
by StevieC. 09/20/18 11:18 PM
What vehicles are you using Maxlife ATF in?
by BlakeB. 09/20/18 11:10 PM
How a Power Steering Rack Works (Electronic)
by StevieC. 09/20/18 11:00 PM
How a Power Steering Rack Works (Hydraulic)
by StevieC. 09/20/18 10:58 PM
silly wiper problem
by bowlofturtle. 09/20/18 10:33 PM
Canadian Tire Shell Rotella T-6 in Pails
by Snagglefoot. 09/20/18 10:04 PM
Best diesel fuel for cold weather?
by Dickm. 09/20/18 10:03 PM
Type 1 Diabetics - New Research
by StevieC. 09/20/18 10:00 PM
Tire Sizing and Options
by NewEnglander. 09/20/18 09:59 PM
2013 Scion FR-S | Transmission Fluid Questions
by nicknak. 09/20/18 09:47 PM
Meguiar's Liquid Cleaner Wax $5 WalMart, Amazon
by The_Cams. 09/20/18 08:42 PM
Winter oil recommendation
by Neptune. 09/20/18 08:27 PM
M1 0W-40
by CT8. 09/20/18 07:37 PM
What controls timing on my 08 Honda?
by Roland. 09/20/18 07:23 PM
The real culprit about 18k
by Ablebody. 09/20/18 06:04 PM
How not to drain a pool.
by StevieC. 09/20/18 05:50 PM
Direct_Rejection, donatom, Sylent_Snyper, Ajizzle, nicknak
66033 Registered Users
34 registered members (BlakeB, Ablebody, Bjornviken, BusyLittleShop, Blaze, 2 invisible), 880 guests, and 38 spiders.
Topics290,744
Posts4,849,439
Members66,033
Most Online3,590
Jan 24th, 2017
Black Oil #4633424
01/13/18 10:42 AM
01/13/18 10:42 AM
USA
Jason1221 Offline OP
USA
Purchased a 2014 chevy 2500hd with a 6.0 engine with 90,000 miles on it. I knew the truck and all are hwy miles the old owner had always changed the oil with mobil 1 5w-30 full synthetic every 5000 miles. Iv done two oil changes with the same oil in it and before i get 3000 miles on it the oil gets really really really black. Has anyone ever had this issue before? Engine runs great!
Re: Black Oil [Re: Jason1221] #4633443
01/13/18 10:58 AM
01/13/18 10:58 AM
SE British Columbia, Canada
Snagglefoot Offline
Snagglefoot  Offline
At 5000 miles how far are you along on the oil monitor, in percentage. I have essentially the same engine with 150,000 miles in a 2008 3/4 ton Suburban. Just had a look; at 70 % remaining itís still light brown. Always used Synthetic 5-30, often M-1. Iíll monitor this and let you when it turns black, and yes, when I change oil at 0 % , itís black.
SF
If you want the job done right......do it yourself.
Re: Black Oil [Re: Jason1221] #4633444
01/13/18 10:58 AM
01/13/18 10:58 AM
Indiana
farrarfan1 Offline
farrarfan1  Offline
Indiana
The below is what you get if you google "black oil bobistheoilguy.com". It will take a while to read all of the threads on this subject.
Link
Re: Black Oil [Re: Jason1221] #4633454
01/13/18 11:10 AM
01/13/18 11:10 AM
North Texas
ARB1977 Offline
ARB1977  Offline
North Texas
Get a uoa done if youíre concerned.
2015 Tacoma 4.0L 60K (as of 02/23/18)
AMSOIL SS 0W30 / Toyota filter
2018 CRV 1.5L (as of 05/11/18)
Factory fill / Honda filter
Re: Black Oil [Re: Snagglefoot] #4633459
01/13/18 11:13 AM
01/13/18 11:13 AM
USA
USA
At 5000 miles it was 30%
Re: Black Oil [Re: Jason1221] #4633466
01/13/18 11:21 AM
01/13/18 11:21 AM
Snagglefoot Offline
Snagglefoot  Offline
OK, Iíll report back when mine is definitely black, or at 30%, Whichever comes first. Currently putting on about 1,000 miles per month.
SF
Re: Black Oil [Re: Jason1221] #4633468
01/13/18 11:22 AM
01/13/18 11:22 AM
Texas
FZ1 Offline
FZ1  Offline
Texas
I think the Boron in the add pack is turning is turning the oil black. The Boron is also plating you cylinder bores.. Not a bad thing.
Re: Black Oil [Re: Jason1221] #4633533
01/13/18 12:02 PM
01/13/18 12:02 PM
War Eagle
toneydoc Offline
toneydoc  Offline
War Eagle
Mobil1 is great oil. Just doing its job. Follow your OLM and the engine will be just fine
1994 Jeep 159k Mobil 5000 5w30
2014 Camry 34k Havoline 5w20
2018 Jeep Cherokee 2k FactFill
2014 HD Ultra 40k Mobil1 15w50
2012 Rav4 37k Pennzoil Platinum 5w20
Re: Black Oil [Re: Jason1221] #4633556
01/13/18 12:35 PM
01/13/18 12:35 PM
Toronto Canada
WobblyElvis Offline
WobblyElvis  Offline
Toronto Canada
Cut open the next used oil filter and look for black/carbon/soot in the pleats of the media. Also look for oil on the throttle plate of the throttle body. These things suggest combustion products are blowing by the piston rings and contaminating the oil and quickly turning it black. The PCV system should be checked.
Does the engine consume oil?
Re: Black Oil [Re: Jason1221] #4633558
01/13/18 12:37 PM
01/13/18 12:37 PM
toronto
PeterPolyol Offline
PeterPolyol  Offline
toronto
Mobil 1 is incredible. It's engine oil, isn't that amazing?
Re: Black Oil [Re: WobblyElvis] #4633559
01/13/18 12:38 PM
01/13/18 12:38 PM
USA
USA
No sir it dont use a drop of oil
Re: Black Oil [Re: Snagglefoot] #4694132
03/13/18 11:58 PM
03/13/18 11:58 PM
Snagglefoot Offline
Snagglefoot  Offline
SF
Just checking back. Iím at 30% left. Getting darker but I wouldnít call it black just yet.
Re: Black Oil [Re: Jason1221] #4694187
03/14/18 03:27 AM
03/14/18 03:27 AM
N.Ohio
Lubener Offline
Lubener  Offline
N.Ohio
Congratulations, your oil is doing what it is engineered to do. Don't worry about it.
The "thinking" man's friend.
Re: Black Oil [Re: Jason1221] #4767573
05/25/18 07:04 AM
05/25/18 07:04 AM
Snagglefoot Offline
Snagglefoot  Offline
Well, finally got down to 0 %. And yes, it is Black.. The driving was all highway with just a bit of city driving. Funny how it seems dark brown on the dipstick but black in the container. Blot samples on paper towels are light brown. The mileage was 10,200 miles at 0 %.
Re: Black Oil [Re: Jason1221] #4767947
05/25/18 02:37 PM
05/25/18 02:37 PM
Senoia, GA
thooks Offline
thooks  Offline
Senoia, GA
The previous owner wasn't doing 5k mile intervals with Mobil 1.
I bet he was going per the OLM and using at best Mobil 5000.
If someone used Mobil 1 at 5k intervals, the engine should be spotless and the oil shouldn't be BLACK at 3k miles.
