Calling all Ford Owners
by dogememe. 12/18/18 01:01 PM
2003 Ford CVPI, 86kmi, 6kmi on Edge HM Ti 5W30
by Colt45ws. 12/18/18 12:35 PM
2017 Kia Sportage recall notice
by SlavaB. 12/18/18 12:26 PM
My VW Service Experience
by Delta. 12/18/18 11:36 AM
Nissan high idle, P0507
by LeakySeals. 12/18/18 11:23 AM
Should i go for even thinner fluid ?
by NICAT. 12/18/18 11:06 AM
Viscosity question
by dbierman. 12/18/18 10:50 AM
48 hours and a used car
by Imp4. 12/18/18 09:32 AM
Test driving PHEV w no battery charge
by RichardS. 12/18/18 09:02 AM
2005 Ford PSD with hard shifts when cold?
by racin4ds. 12/18/18 08:08 AM
18% off Ravenol + EVERYTHING @ Blauparts.com
by CleverUserName. 12/18/18 07:48 AM
Mattress shopping .....
by dblshock. 12/18/18 04:57 AM
AmazonBasics Oil May Drive Prices Down
by knerml. 12/18/18 04:45 AM
Hemi MDS issues are how common?
by Gasbuggy. 12/18/18 03:21 AM
Why use Redline and Redline Clone oils...
by burla. 12/17/18 11:38 PM
Tire choice
by CincyReds. 12/17/18 11:14 PM
MuhThugga, wxo, dbierman, keyblade, leeal
66716 Registered Users
120 registered members (14Accent, 4WD, 53' Stude, 25ring, 28oz, 15 invisible), 2,109 guests, and 42 spiders.
Topics295,222
Posts4,930,323
Members66,716
Most Online2,553
Oct 27th, 2018
Home Heating - Cost Difference #4633379
01/13/18 09:09 AM
01/13/18 09:09 AM
California
SavagePatch Online content OP
SavagePatch  Online Content OP
California
Once your desired temperature is met, let's use 70, does it cost more to maintain that 70 than a lower temperature such as 65?
Propane central heating, home built 1991, 30 low during the night.
Thanks!
Re: Home Heating - Cost Difference [Re: SavagePatch] #4633393
01/13/18 09:17 AM
01/13/18 09:17 AM
Lyndhurst NJ
Audios Offline
Audios  Offline
Lyndhurst NJ
I think the quality of your homes insulation comes into play here. If your home can maintain that 70 without help from the heater, than it wont matter. But if its a drafty or older house, than its constantly losing heat, so the heater will run more to maintain the warmer temp. Plus the more loss the more it needs to bring it up to 70
2002 VW Golf TDI-Mobil 1 5/40 TDT
2007 Mercedes GL320 CDI Fuchs 5/40 GT Pro XTL
2005 BMW M3 BMW Twin Power 10/60
2003 BMW M5-Fuchs 5/40
1998 BMW M3/4/5 Fuchs 5/40
Re: Home Heating - Cost Difference [Re: SavagePatch] #4633395
01/13/18 09:17 AM
01/13/18 09:17 AM
NEUS
Bandito440 Offline
Bandito440  Offline
NEUS
Its beneficial to lower the temperature when you can. Ive got a programmable thermostat.
Nights - 60
Morning and evening - 68
Days when Im at work - 55
Info from the DOE
'14 Grand Cherokee EcoDiesel
Rotella T6 5w-40 & OEM filter
Re: Home Heating - Cost Difference [Re: SavagePatch] #4633399
01/13/18 09:22 AM
01/13/18 09:22 AM
PimTac Offline
PimTac  Offline
Insulation plus the type of house will determine the cost. A two story will be more than a one story in general. The condition of your furnace is another key point. Maintenance will assure proper function.
Cannot see signatures any longer so it doesn’t matter.
Re: Home Heating - Cost Difference [Re: SavagePatch] #4633401
01/13/18 09:24 AM
01/13/18 09:24 AM
Hudson, NH
LeakySeals Offline
LeakySeals  Offline
Hudson, NH
I have fha heat and hot water with propane from the 1990s as well. Excluding this winter which has been very cold I have found the settings of 66 during day 68 when I get home and 63 at night have the fill-ups costing $150 less on average using a Honeywell programmable thermostat. Each climate is different so your winter and summer programs will differ from mine of course. There is no real rule of thumb you take into account the climate and the insulation and watch where the house stays constant with minimal fuel I guess. And if you can live with that that's the way to go just monitor the house without anything and see how close you can get to that where it's comfortable
06 Escalade 6.0L LQ9 AWD 165k M1 0w40
03 Maxima 3.5L POS 152k ST HM 10w30
Re: Home Heating - Cost Difference [Re: SavagePatch] #4633412
01/13/18 09:32 AM
01/13/18 09:32 AM
Kansas
Kruse Offline
Kruse  Offline
Kansas
It does cost more to keep at 70 than 65, but how much depends on a lot of variables.
Just don't overdue it. There have been a lot of older houses around here that have had frozen pipes because the owner set the thermostat at a much lower temp (e.g. 50) and they've had water pipes freeze, resulting in lots of damage.
With lows in the 30 there, you probably have nothing to worry about.
Re: Home Heating - Cost Difference [Re: SavagePatch] #4633453
01/13/18 10:10 AM
01/13/18 10:10 AM
DFW
DBMaster Offline
DBMaster  Offline
DFW
I like it cool in the summer. If it costs me $50 more for electricity to accomplish that, so be it. I'll pay $150 over the course of a year to be comfortable. The same goes with heating. I like it on the cool side, but if you like to be toasty, why not spend a few extra bucks to be comfortable?
Re: Home Heating - Cost Difference [Re: SavagePatch] #4633472
01/13/18 10:25 AM
01/13/18 10:25 AM
OH
fdcg27 Offline
fdcg27  Offline
OH
Thanks!
Just use a little common sense.
The only reason you need space heating is that heat is lost to the colder outside air.
The greater the differential between the two then the greater the amount of heat that the furnace has to make up.
Cooler will necessarily always be cheaper.
It's just a matter of what feels okay to you as well as what you're willing to spend.
18 Accord Hybrid FF
17 Forester 18K VME 0W-20
12 Accord LX 96K SSO 0W-20
09 Forester 95K M1HM 10W-30
01 Focus ZX3 118K PP 5W-20
96 Accord LX 104K T5 10W-30
95 318i
Re: Home Heating - Cost Difference [Re: SavagePatch] #4633609
01/13/18 12:41 PM
01/13/18 12:41 PM
Jupiter, Florida
Cujet Online content
Cujet  Online Content
Jupiter, Florida
Temperature differential is the metric you seek.
Re: Home Heating - Cost Difference [Re: DBMaster] #4633625
01/13/18 12:51 PM
01/13/18 12:51 PM
MTL, CANADA
Rolla07 Offline
Rolla07  Offline
MTL, CANADA
I agree here. I keep it 68 F on my main and top floor at all times. Basement is at about 61 F since I'm rarely down there, except for laundry etc..
2007 Corolla Red Pearl 155k miles
PP 0w20 & ST 4967
Re: Home Heating - Cost Difference [Re: SavagePatch] #4633629
01/13/18 12:57 PM
01/13/18 12:57 PM
Elizabethtown, Pa
Al Offline
Al  Offline
Elizabethtown, Pa
If the outside average is say 45 you will save as much 20% by keeping it 65 instead pf 70.
Re: Home Heating - Cost Difference [Re: SavagePatch] #4633644
01/13/18 01:15 PM
01/13/18 01:15 PM
ME
eljefino Offline
eljefino  Offline
ME
Isn't there another thread about this going on right now?
Graph the outside temp every hour for a day. Then put the inside temp on the same graph. Color in between. That's how much heat you need. If your inside temp dips during "whenever" you save money as it narrows the amount of heat you're adding.
For a setback thermostat to "really work", though, your house needs to coast down to its lower temperature quickly due to bad insulation. Who wants that? Your temperature spread, multiplied by your average "R" value constant, multiplied by cost of fuel, is how much money you'll spend.
Re: Home Heating - Cost Difference [Re: SavagePatch] #4633887
01/13/18 05:48 PM
01/13/18 05:48 PM
DFW
DBMaster Offline
DBMaster  Offline
DFW
Just for context, the maximum temperature I use for heating is 68 and the minimum temperature I use for A/C is 71. Most people around here set their heat higher (Texans are wusses when it comes to cold.) and their A/C quite a bit higher.
Re: Home Heating - Cost Difference [Re: SavagePatch] #4635701
01/15/18 12:18 PM
01/15/18 12:18 PM
Hudson, NH
LeakySeals Offline
LeakySeals  Offline
Hudson, NH
Just had the tank filled. Only $450! Was $750 before the new programmable thermostat set to above. Using the old type analog dial was very inefficient
Re: Home Heating - Cost Difference [Re: SavagePatch] #4635943
01/15/18 04:47 PM
01/15/18 04:47 PM
MI, USA
Whitewolf Offline
Whitewolf  Offline
MI, USA
It really does depend on the type of house and method of construction, plus insulation. I have had houses that were cheaper to run at a constant temperature without using the thermostat and others that were the opposite.
My definition of an expert in any field is a person who knows enough about what's really going on to be scared.
~ PJ Plauger
