Guys doesn't know the very basics. At 4:30 he's talking about no bypass valve and it will "just get clogged up". Well, little does he know that any filter put on a motor that doesn't have a bypass valve, the valve is built into to engine somewhere. Always need a filter bypass valve unless you want to risk the chance of damaging the filter with too much delta-p. I can't watch the whole 30 min video ... just too painful.
I stopped on the first piece of disinformation. He did not understand the eCore has a combo valve made of nitrile and it doubles as a bypass and ADBV. The problem is someone will believe what he is saying. I failed to catch the time.
It may be interesting for someone that has not seen the inside of a filter. I'd give it one or two stars.
