2011 Chevy equinox overheating
by hardcore302
06/18/18 06:00 PM
Are my rotors warped?
by Dylan1303
06/18/18 05:44 PM
Ultimate Fast Finish on sale at CDN tire.
by irv
06/18/18 05:23 PM
96 Civic 5w20 Castrol GTX Ultraclean UOA
by researcher
06/18/18 04:52 PM
VOA Castrol Magnatec D1G2, 5w30
by researcher
06/18/18 04:38 PM
Unused dented silicone Fram PH8316 cut open
by slacktide_bitog
06/18/18 04:28 PM
Bring back Merkava_4
by mjoekingz28
06/18/18 04:28 PM
Same grade with differing low start temps
by mjoekingz28
06/18/18 04:24 PM
Self defense
by Camprunner
06/18/18 03:13 PM
Any apple experts here?
by maverickfhs
06/18/18 02:50 PM
Cost-no-object 75W-90 GL-5 for a differential?
by d00df00d
06/18/18 02:34 PM
Pittsburgh Dad, this guy is a trip
by Rat407
06/18/18 02:06 PM
14 Jeep GC 5.7, PP 5w20 & 0w20
by Vigg
06/18/18 01:52 PM
Sell me on a SSD drive...........
by ZZman
06/18/18 01:07 PM
need some ideas on my issue
by matrass
06/18/18 12:36 PM
Put Pennzoil Platinum Euro L in a Honda.
by dunlop0078
06/18/18 12:36 PM
BMW V8 Oil Consumption Fix
by doc540
06/18/18 11:25 AM
More info on Valvoline Modern Engine Oil
by buster
06/18/18 11:07 AM
Shelf life of synthetic 2 stroke engine oil ?
by ScottMill
06/18/18 10:34 AM
Oil sample extraction
by Tikka
06/18/18 10:30 AM
WtsTacoma01, Orion62, Revd, blinky1041, mostdecent
65262 Registered Users
100 registered (4WD, Astro14, 555, 1JZ_E46, Aero540T, aquariuscsm, 11 invisible), 1565 Guests and 43 Spiders online.
65262 Members
67 Forums
285535 Topics
Page 1 of 2 1 2 >
#4631391 - 01/11/18 11:49 AM Steering Wheel Shock
artbuc Offline
Loc: West Chester, PA
Re: 1999 Toyota Avalon V6
For some time now I have been feeling vibration in the steering wheel when stopped in gear but not in P or N. I replaced my rear motor mount and dogbone with OEM a few years ago so I am pretty sure they are ok but maybe front mount is bad. Tranny mount checks out fine.
More recently I notice that when I hit a bump, I feel the shock in the steering wheel as if it has not been absorbed. What can be causing this? The steering rack is only connected through the tie rod ends, right? Do you think these two (vibration when stopped in gear and shock when I hit a bump) issues are related? Thanks.
Edited by artbuc (01/11/18 11:51 AM)
#4631404 - 01/11/18 12:02 PM Re: Steering Wheel Shock [Re: artbuc]
kschachn Online   content
Loc: Upper Midwest
If that rack is the same as on my Sienna (which I think it is) then it has rubber bushings both at the two vertical attachment bolts and at the single wrap-around bushing. All or some of those may be degraded. IIRC one of the rubber bushings is available from Toyota, and the other(s) are available aftermarket. All can be changed with the rack installed on the vehicle (at least in my Sienna) but it isn't easy. Whiteline makes a set for your car I believe.
If you can get underneath the car while someone turns the wheel a bit against the ramps, you can see the rack move if they are bad.
1994 BMW 530i, 227K
1996 Honda Accord, 262K
1999 Toyota Sienna, 394K
2000 Toyota ECHO, 267K
#4631420 - 01/11/18 12:11 PM Re: Steering Wheel Shock [Re: artbuc]
LeakySeals Offline
Loc: Hudson, NH
Replace intermediate shaft
06 Escalade 6.0L AWD 160k. M1 5w30 Fram TG
03 Maxima 3.5L 149k ST HM 10w30
#4631421 - 01/11/18 12:13 PM Re: Steering Wheel Shock [Re: kschachn]
LeakySeals Offline
Loc: Hudson, NH
Just had my GF Dad's Sienna in for the intermediate shaft replacement under warranty. Its been a Toyota weak spot for over a decade. If you're under 100k they will cover it. Bumping, knocking turning the wheel. Vibration over bumps, all symptoms of the shaft failing. If you google the problem, its downright dangerous if it completely fails. The steering wheel disconnects entirely, free spinning with no control
#4631485 - 01/11/18 01:12 PM Re: Steering Wheel Shock [Re: LeakySeals]
artbuc Offline
You may be right but my steering is perfectly smooth and does not make any noises while turning.
#4631524 - 01/11/18 01:54 PM Re: Steering Wheel Shock [Re: artbuc]
Kestas Offline
Loc: The Motor City
Is the engine/transmission centered left-to-right in the car?
#4631530 - 01/11/18 01:59 PM Re: Steering Wheel Shock [Re: artbuc]
Nick1994 Offline
Loc: Phoenix, AZ
Pop the hood and sit in the car with the engine running. Put it in drive and hold the brake, touch the gas pedal a little. Look at the engine through the gap under the hood. Is it flopping back and forth?
That's how I found out my mounts were bad in my Camry last year. It was flopping back and forth, I didn't know it.
2015 Hyundai Sonata 2.4L 79k PU 5w30 & OEM
2000 Toyota Camry 2.2L 228k M1 AFE 0w30 & Wix
1996 Jeep Cherokee 4.0L 146k M1 HM 10w40 & Fram Ultra
#4631534 - 01/11/18 02:05 PM Re: Steering Wheel Shock [Re: kschachn]
artbuc Offline
Looks like you get the prize! Just observed the rack (carís rack to be specific) while my wife turned the wheels. Could see the driver side well from above but not the passenger side. The driver side bushing was clearly bad allowing substantial movement when the steering direction changed. Looks like a nice winter time project if I can find the bushing part numbers. Thanks!
Edited by artbuc (01/11/18 02:06 PM)
#4631538 - 01/11/18 02:07 PM Re: Steering Wheel Shock [Re: Kestas]
artbuc Offline
Centered? What do you mean? How would it get uncentered?
Edited by artbuc (01/11/18 02:08 PM)
#4631548 - 01/11/18 02:15 PM Re: Steering Wheel Shock [Re: artbuc]
Kestas Offline
Loc: The Motor City
Sometimes the subframe needs to be dropped for certain repairs. It then needs to be centered while reattaching the mount bolts. If not centered, the half-shafts can run out of axial travel when jumping around.
#4631575 - 01/11/18 02:39 PM Re: Steering Wheel Shock [Re: Kestas]
artbuc Offline
Got cha. Subframe has never been touched.
#4631624 - 01/11/18 03:58 PM Re: Steering Wheel Shock [Re: artbuc]
artbuc Offline
Dorman and Whiteline sell bushing kits. Both use polyurethane. Dorman is about $10 cheaper. Any reason to spend extra for Whiteline? Thx.
#4631661 - 01/11/18 04:50 PM Re: Steering Wheel Shock [Re: artbuc]
artbuc Offline
Nevermind. Just checked her out. Must remove rack to replace bushings. 25 years ago it would have been out already. But my days of removing steering racks are long gone.
#4631703 - 01/11/18 05:47 PM Re: Steering Wheel Shock [Re: artbuc]
HoosierJeeper Offline
Loc: WI
One thing you might be able to do is just take the bolts out and shore it up with some rubber washers, extra good if you can slip some under the bushings but if you can only put a few on top it'll still help. Did that with my Liberty for a few months before I got the courage to replace the rack.
15 Jeep KL Limited V6: Formula Shell 5W20
07 LR3 SE V8: Maxlife 5W30
05 Jeep KJ Limited: PHM 5W30
96 Jeep XJ Country: STP HM 5W30 (winter)
#4632133 - 01/12/18 06:13 AM Re: Steering Wheel Shock [Re: artbuc]
artbuc Offline
Ok, the morning light has brought me new energy and hope! Really isnít that big of a deal to pull this rack so letís get on with the program.
So here is my new question. As far as I can tell, my original rack with 135k is in fine working order. I did replace the passenger side inner tie rod end a few years ago but no leaks or other issues. I would not replace it with an aftermarket unit but can get a Toyota remanufactured rack for $600. I plan on keeping this car for a long time driving about 5k miles per year getting groceries. Do I really want to go to the trouble of removing this rack, installing new bushings and reinstalling? Chances are good it will last the lifetime of the car. OTOH, would be nice to have a new Toyota remanufactured unit in there to make my labor seem worthwhile. What would you guys do?
Page 1 of 2 1 2 >
