TallPaul
Thread starter
I have had the system re bled several times now and still seems to be losing pedal. Worse, there is no way to tell where the air is getting in because it is not showing signs of leakage, which means I will have to replace both slave and master and probably not get any replacement under warranty as no evidence of leakage unless we can visibly see a problem with the parts removed from the truck. I am done with so called Genuine Ford junk. I need to find a high end after market manufacturer, but my shop tells me it won't help because there is no way to know where this stuff is made. The mechanic said he has seen new Fords that lost and would not keep pedal.
