Shell Rotella Grease
by WMW0505. 12/12/18 02:27 PM
Need to add attic ladder in stairwell
by Klutch9. 12/12/18 12:51 PM
Mystik JT-8 15w40, 2015 RAM EcoDiesel, 4,995 mi
by SavagePatch. 12/12/18 12:45 PM
Fram Tough Guard Air Filters at Rock Auto
by Snagglefoot. 12/12/18 12:42 PM
Electrical contact cleaner
by CELICA_XX. 12/12/18 12:32 PM
5w-30 in 277k mile chevy 350 tbi
by dogememe. 12/12/18 12:22 PM
voltage test for coolant condition
by NissanMaxima. 12/12/18 12:17 PM
paying Premiun for the name(infiniti/nissan
by 2008wrx. 12/12/18 11:25 AM
POE oil (R-410a)
by WyrTwister. 12/12/18 09:44 AM
Any Volvo Owners, need some help!
by LazyDog. 12/12/18 09:34 AM
NOACK & Sheer
by WyrTwister. 12/12/18 09:34 AM
Rotary help. 2010 series 2 RX8
by TinyVoices. 12/12/18 08:32 AM
Can you mathematically estimate top speed?
by KCJeep. 12/12/18 08:06 AM
2019 GM 6.2 AFM
by XL1200RFan. 12/12/18 07:32 AM
Dodge Challenger R/T Tips and Tricks?
by LoneRanger. 12/12/18 06:02 AM
MIL vehicle suggestion $8000
by madRiver. 12/12/18 06:00 AM
Toyota 2TR-FE 2.7 questions
by Doublehaul. 12/12/18 12:32 AM
Anybody used Eurolub?
by FordCapriDriver. 12/12/18 12:18 AM
jefe_de_estado, CM613, Geardaddies, 01ws666, ariefnrst
66660 Registered Users
110 registered members (46Harry, Alfred_B, 28oz, aquariuscsm, 2004tdigls, 53' Stude, 12 invisible), 2,023 guests, and 36 spiders.
Topics294,986
Posts4,925,484
Members66,660
Most Online2,553
Oct 27th, 2018
Best oil for 1999 Lexus GS300? Need opinions... #4631321
01/11/18 10:54 AM
01/11/18 10:54 AM
San Diego, CA
joshua777 Offline OP
San Diego, CA
I know this topic has been beaten over the head 1,000 times and trust me I've read every forum, many being from yeeeaaarrrrs ago. I currently have 196,XXX miles on my 1999 GS300 and have used Mobil 1 High Mileage Full Synthetic 5W-30 for about 2 years now. It's great, but I still burn through about 1 quart every 5,000 miles. I've been thinking about switching over to 10W-30 in a few months, since I live in San Diego, and summer weather will be here before I know it. When I make the switch, I was wondering opinions on Pennzoil Platinum High Mileage 10W-30 and Mobil 1 10W-30 High Mileage Full Synthetic. I want to get other's opinions, say money is no object when choosing between the two, which one would you guys recommend? I've recently read claims that Pennzoil is better and keeps the engine cleaner, and just helps maintain better than Mobil 1, but it's impossible to get non-sponsored opinions in 2018.
Re: Best oil for 1999 Lexus GS300? Need opinions... [Re: joshua777] #4631358
01/11/18 11:31 AM
01/11/18 11:31 AM
CA
raytseng Offline
raytseng  Offline
CA
i have a 1998 gs300. it did well on Pp and pup 5w30 normal. One oci i used m1 and had increased consumption.
However this engine still needed a .5qt topoff say halfway through my 7500oci. At the end of the oci the stick was in thr middle and ready to change.
I would suggest you try a different brand and stick with spec. Obviously M1 isnt making you happy. I don't know why you are staying loyal to it and going so far as to go offspec before trying a non m1. If it turns out the same on PP at least you know.
Re: Best oil for 1999 Lexus GS300? Need opinions... [Re: joshua777] #4631383
01/11/18 11:46 AM
01/11/18 11:46 AM
GA
Anthony Offline
Anthony  Offline
GA
I would keep running M1 HM and move to their 10w40 grade.
95 Nissan Hardbody V6 - M1 HM 5w30
13 Nissan Titan - Pennzoil Platinum 5w30
17 Ford Mustang GT - Pennzoil Platinum 5w20
Re: Best oil for 1999 Lexus GS300? Need opinions... [Re: joshua777] #4631385
01/11/18 11:47 AM
01/11/18 11:47 AM
CA
raytseng Offline
raytseng  Offline
CA
As far as the engine and performance and perceived cleanliness, I've found the engine to run slightly better if the fuel has some ucl. Also the rest of your maintenance is going to play a larger role over your oil.
As far as fuel, in particular shell vpower was smoother than chevron premium. I think the shell addpack has more ucl.
Or if you want to roll your own, using maintenance level dose of redline si1 with any station is best at providing the increased smoothness (and injector cleaning)
Note I've driven and maintained my gs for 20years so buttdyno is finely calibrated so take my experience and expertise into account. Of course its your car so do whatever you want with it.
Re: Best oil for 1999 Lexus GS300? Need opinions... [Re: joshua777] #4631410
01/11/18 12:04 PM
01/11/18 12:04 PM
Idaho
CT8 Offline
CT8  Offline
Idaho
Oil is oil .Try different brands 1qt in 5,000 miles isn't bad and what is the causeof the oil consumption if not the oil brand or type.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Best oil for 1999 Lexus GS300? Need opinions... [Re: joshua777] #4631473
01/11/18 01:07 PM
01/11/18 01:07 PM
NC
Vladiator Offline
Vladiator  Offline
NC
I had that engine in my IS300 and it definitely ran the happiest on 0w40 oils. Mobil1 0w40, if you wanna stay with the same brand, or Pennzoil Euro 0w40 at Walmart are good choices. Castrol 0w40 made the engine a bit more sluggish.
Just my 2 cents from personal experience with that engine. I even tried 0w20 in it, did not like it though. 0w30, 5w30, and 0w40 are your best bets. Some 5w40s made it too sluggish, just like Castrol 0w40.
Re: Best oil for 1999 Lexus GS300? Need opinions... [Re: joshua777] #4631540
01/11/18 02:10 PM
01/11/18 02:10 PM
Hudson, NH
LeakySeals Offline
LeakySeals  Offline
Hudson, NH
1 quart is not that bad considering the engine and year. Yes you may consume more M1 HM, but the reason is better flow. Want less consumption? Use a thicker poor flowing oil. You need to know why its consuming. If its rings or blocked oil control holes, HM oil won't help you. If its rubber valve seals (blue smoke at startup) then yes, it will help by plumping them up. When is the last time you replaced the PCV valve? I know that era had issues with the PCV system.
06 Escalade 6.0L LQ9 AWD 165k M1 5w30
03 Maxima 3.5L POS 152k ST HM 10w30
Re: Best oil for 1999 Lexus GS300? Need opinions... [Re: CT8] #4631598
01/11/18 03:19 PM
01/11/18 03:19 PM
NJ
Leo99 Offline
Leo99  Offline
NJ
Exactly. Try different oils and the best one might lessen the oil consumption to 25 oz per month instead of 32 oz.
My Rav4 uses a bit of oil. Maybe 1.5 qts every 5000 miles. I used whatever HM oil I can get for cheap. Right now it has Castrol green bottle in it. I find that switching oils works best for it. Next change will be ST HM and then maybe Pennzoil HM and then Valvoline Max.
Without data you're just another person with an opinion. W. E. Deming
2003 Corolla 250,000 miles (RIP)
2004 Corolla 125,000 miles
2004 Rav4 370,000 miles
2015 Camry 70,000 miles
Re: Best oil for 1999 Lexus GS300? Need opinions... [Re: joshua777] #4631720
01/11/18 06:08 PM
01/11/18 06:08 PM
OH
fdcg27 Offline
fdcg27  Offline
OH
A car of nearly twenty years with 200K using a quart in 5K isn't consumption at all.
I wouldn't even try to chase this down with different oil brands.
Won't likely matter.
All you can do is ensure that the PCV system is flowing properly and that the PCV valve itself is working.
Other than that, motor on in this fine old-school Toyota design and just dump in a quart every 5K.
The old GS and LS cars are very nice to drive and seem to hold up very well.
18 Accord Hybrid FF
17 Forester 18K VME 0W-20
12 Accord LX 96K SSO 0W-20
09 Forester 95K M1HM 10W-30
01 Focus ZX3 118K PP 5W-20
96 Accord LX 104K T5 10W-30
95 318i
Re: Best oil for 1999 Lexus GS300? Need opinions... [Re: joshua777] #4631771
01/11/18 06:44 PM
01/11/18 06:44 PM
Oshawa, Ontario Canada
JC1 Offline
JC1  Offline
Try some Liqui Moly Motor oil saver and keep using the M1 5w-30 HM.
https://products.liqui-moly.com/motor-oil-saver-3.html
2015 Grand Caravan SXT Plus 5w-20 PPPP/Fram Ultra Filter
1997 Honda Civic CX 5w-30 Shell Conventional/Fram Ultra Filter
Re: Best oil for 1999 Lexus GS300? Need opinions... [Re: fdcg27] #4631779
01/11/18 06:54 PM
01/11/18 06:54 PM
VA
maverickfhs Offline
maverickfhs  Offline
VA
+1 Million, 1 quart after 5K is nothing. Cheap insurance and these cars are built like TANKS smile
2006 Civic EX 202K/AT
2006 Acura TSX 180K/AT
Re: Best oil for 1999 Lexus GS300? Need opinions... [Re: joshua777] #4631795
01/11/18 07:10 PM
01/11/18 07:10 PM
VA
Gebo Offline
Gebo  Offline
VA
I'd use the Pennzoil in the 5w30 weight just for fun. It may not use as much oil or it may use more. You'll never know until you give it a try.
'98 LEX LS400 280K
'00 LEX GS300 195K
'02 4Runner 225K
'05 Lex LS430 85K
'06 Toyota Highlander 145K
'09 Lex IS350 85K
'07 Lex GX470 60K
Amsoil in all engines, transmissions and differentials
Re: Best oil for 1999 Lexus GS300? Need opinions... [Re: raytseng] #4632685
01/12/18 04:58 PM
01/12/18 04:58 PM
San Diego, CA
San Diego, CA
I've used Shell VPower, exclusively, for about 5 years now. I will never use any other gas, incredible stuff.
Re: Best oil for 1999 Lexus GS300? Need opinions... [Re: fdcg27] #4632688
01/12/18 05:00 PM
01/12/18 05:00 PM
San Diego, CA
San Diego, CA
Yeah that's basically how I feel, 1 quart every 5,000 isn't that bad. There's literally nothing wrong with the car. This is the biggest, and only, "problem."
Re: Best oil for 1999 Lexus GS300? Need opinions... [Re: joshua777] #4636780
01/16/18 02:09 PM
01/16/18 02:09 PM
Stewartstown PA
spiderbypass Offline
Stewartstown PA
Mobil 1 0w40 fs is hard to beat. Maybe 5w50 Mobil 1 fs ior 15w50 in Warmer temps.
Insecurity with overcompensation are the root of evil deeds.
