OCI. With short trips. Nissan 4 liter
by Gawardawg
40 minutes 14 seconds ago
Approach Watching on the Beach @ St Maarten ...
by LoneRanger
51 minutes 35 seconds ago
Honda Accord Needs Shocks; Front, Back, or Both?
by tc1446
Today at 05:50 AM
How much oil does your oil filter hold?
by Snagglefoot
Today at 05:44 AM
better day
by mx5miata
Today at 05:26 AM
BRAVO to Officer Wheeles......
by Sayjac
Today at 05:17 AM
People Watching ....Airport style.
by ZZman
Today at 04:24 AM
Subaru's at play...
by OneEyeJack
Today at 03:50 AM
Treating a 2003 Jetta
by llmercll
Today at 01:41 AM
Brakes not working - brake pedal sinks
by tookien
Today at 12:42 AM
Dave thinks I can make it 12--15k
by Marco620
Today at 12:26 AM
'05 Impala front wheel "squeal". Cost !
by Lee4212
Today at 12:16 AM
One Dollar Per Gallon?
by Y_K
Yesterday at 11:53 PM
Walmart Tightening up Returns
by John_K
Yesterday at 10:21 PM
flare nut wrench set
by spasm3
Yesterday at 09:46 PM
Auto trans temperature scanner - help!
by JeffKeryk
Yesterday at 09:45 PM
How much is too much?
by Sealbilly
Yesterday at 09:34 PM
Correct oil filter for a Vovlo S60, 2003
by earthworm
Yesterday at 09:17 PM
Prestone coolant $3.50 Target YMMV
by pda1122
Yesterday at 09:13 PM
Need Windows 7 Pro ISO
by MONKEYMAN
Yesterday at 08:33 PM
JustaDude, 3horseman, Firedog45, WtsTacoma01, Orion62
65265 Registered Users
70 registered (1foxracing, 69Torino, 91camarosRS, advocate, adamrc, AndyB, 5 invisible), 1219 Guests and 39 Spiders online.
65265 Members
67 Forums
285582 Topics
Page 1 of 2 1 2 >
#4631059 - 01/11/18 05:45 AM Soft brakes after bleeding on 2011 Silverado 1500
dja4260 Offline
Loc: Greenville, SC via Chicago, IL
Just replaced both the front calipers and brakes on friends 2011 Silverado 1500.
We bleed both drivers and passenger side with the car off. We went through alot of fluid. Air is no longer exiting the caliper tubing when bleeding. The brakes are still spongy. What am I missing?
I'm frustrated and tired.
Thank you!
2013 Hyundai Elantra Gt Hatch 6 spd
2005 Toyota Highlander V6
1997 HD Sportster
#4631068 - 01/11/18 06:12 AM Re: Soft brakes after bleeding on 2011 Silverado 1500 [Re: dja4260]
Char Baby Offline
Loc: ROCHESTER, NY
Must be the feel of the new pads until they seat/bed in.
How did you bleed the brakes?...
1)Gravity?
2)Vacuum Pump?
3)Two man system? I don't do a 2 man setup anymore as the person inside the truck can/could be pushing the master cylinder piston too far(not realizing) and cause cylinder wall scoring. You really shouldn't push the brake pedal to the floor!
What type of brake pads did you use?
Did you stray from OE or OE-like? Meaning did you change from the factory friction material(Semi-Mets vs Ceramic) and brake coefficient of friction/CoF(FF vs GG)?...I don't like CoF-GG pads but most others here do so, I'm the oddball in this camp.
Edited by Char Baby (01/11/18 06:20 AM)
"Retired"
'06 Mazda 3i 2.0L
'15 Nissan Altima 2.5 SV
#4631069 - 01/11/18 06:12 AM Re: Soft brakes after bleeding on 2011 Silverado 1500 [Re: dja4260]
barkingspider Offline
Loc: socal
Perhaps bleed the rear brakes, too
06 Cadillac Escalade Ext
17 Cadillac ATS (wife)
05 Toyota Camry (daughter)
11 GMC Canyon off-road (daily)
#4631074 - 01/11/18 06:24 AM Re: Soft brakes after bleeding on 2011 Silverado 1500 [Re: barkingspider]
Char Baby Offline
Loc: ROCHESTER, NY
^^^Yes, this too however, I don't think(just me) that this is going to change the sponginess feeling since the brakes were feeling normal prior to the pad/rotor change.
Edited by Char Baby (01/11/18 06:28 AM)
"Retired"
'06 Mazda 3i 2.0L
#4631080 - 01/11/18 06:29 AM Re: Soft brakes after bleeding on 2011 Silverado 1500 [Re: dja4260]
dja4260 Offline
We bleed the brakes with two people. My buddy on the pedal, and I working the wrench.
1997 HD Sportster
#4631081 - 01/11/18 06:31 AM Re: Soft brakes after bleeding on 2011 Silverado 1500 [Re: dja4260]
NGRhodes Offline
Loc: West Yorkshire, UK
Thank you!
Have you fired the engine up to get the servo working ?
#4631084 - 01/11/18 06:35 AM Re: Soft brakes after bleeding on 2011 Silverado 1500 [Re: NGRhodes]
dja4260 Offline
Yes, drove around after the process as well.
1997 HD Sportster
#4631085 - 01/11/18 06:35 AM Re: Soft brakes after bleeding on 2011 Silverado 1500 [Re: NGRhodes]
dja4260 Offline
Thank you!
Yes
1997 HD Sportster
#4631089 - 01/11/18 06:38 AM Re: Soft brakes after bleeding on 2011 Silverado 1500 [Re: Char Baby]
das_peikko Offline
Loc: San Antonio, TX
Banjo washers. You will get air in the system if you don't use new washers.
#4631091 - 01/11/18 06:45 AM Re: Soft brakes after bleeding on 2011 Silverado 1500 [Re: Char Baby]
BigD1 Offline
Loc: NC
Had a few master cylinders go bad after bleeding brakes two man. The last one I had go bad had a big block of wood under the brake pedal during the two man bleed. Thought the block of wood would help but nope.
1992 Toyota Pickup--Havoline HM 10W-30--Motorcraft FL-910S
#4631095 - 01/11/18 06:53 AM Re: Soft brakes after bleeding on 2011 Silverado 1500 [Re: BigD1]
Char Baby Offline
Loc: ROCHESTER, NY
Yeah, I either gravity bleed or use the Mityvac.
I'll gravity bleed if I'm just inspecting/cleaning/lubing the brakes.
I'll Mityvac when doing a whole brake job. I'll turkey baste the master cylinder and start with fresh fluid.
"Retired"
'06 Mazda 3i 2.0L
#4631100 - 01/11/18 06:59 AM Re: Soft brakes after bleeding on 2011 Silverado 1500 [Re: dja4260]
AZjeff Offline
Loc: PV Az
This is a great tool if you have to bleed the whole system again. Super easy to do a complete flush. You need compressed air to use it but it's a 1 man job. https://www.harborfreight.com/brake-fluid-bleeder-92924.html
86 Samurai 1.3 leftovers
14 RAV4 2.5 5W-20 PP *gasp*
16 Silverado 1500 4.3 Ecotec3, DI, AFM 5W-30 PP
Why know when you can guess?!
#4631102 - 01/11/18 07:00 AM Re: Soft brakes after bleeding on 2011 Silverado 1500 [Re: BigD1]
Trav Offline
Loc: MA, Mittelfranken.de
It sound like the MC went dry and now there is air in the ABS, use a scan tool to trigger the bleeding.
If you don't have one a shop wont charge much to do that for you.
#4631164 - 01/11/18 08:26 AM Re: Soft brakes after bleeding on 2011 Silverado 1500 [Re: dja4260]
64bawagon Offline
Loc: Michigan
First thing I would do is gravity bleed the rear brakes. Its simple enough to do and you dont even need to pull the wheels. Just break the bleeder free and place a hose on it to a container, let it drip for 10 minutes or so (watching the level in the MC reservoir) Do the drivers side first then the passengers. Cheap and easy. If that doesnt do it I would drive the truck and try to get the ABS to activate a few times then rebleed the system (you could get a Tech tool to activate the ABS for bleeding but I dont have one so this is the shadetree method)
Its also possible that one of the new calipers isnt any good or that the pads arent moving freely in the calipers. If the pads are binding and wont slide freely in the mounts it will give you a mushy peddle.
Edited by 64bawagon (01/11/18 08:29 AM)
05 Duramax Chevy(SOLD), 64 Chevy wagon, 10 Jeep Wrangler, 17 Equinox (rental), 18 Silverado 1/2 ton
#4631243 - 01/11/18 09:51 AM Re: Soft brakes after bleeding on 2011 Silverado 1500 [Re: dja4260]
LeakySeals Offline
Loc: Hudson, NH
Why were the calipers replaced? I thought my front right caliper was frozen. Nope, it was the CRC grease recommended by the auto parts store. Do Not use standard brake grease on the calipers of that truck. The grease will get hot, boil, and harden jamming up the caliper bolts and slides. Use syl glide or a silicon based paste. Bad movement could cause spongy response.
You said replaced brakes, what does that include? (rotors, pads, etc). If it was just ceramic pads, old rotors, that may take a while for bedding to occur. The old rotor should come off and thoroughly cleaned to remove pad glazing and grease.
You're in Chicago. Go slip on something making the ABS flutter, try bleeding again. smile
You have a hydro boost system which means you rely on the PS pump for your power assisted brakes. Turn on truck and listen. Turn the wheel, step on the brakes. Hear any whining? May need to replace the PS pump. At least, turkey baste the PS reservoir a few times. this was my spongy brake issue. Not enough hydroboost pressure, faulty PS pump.
06 Escalade 6.0L AWD 160k. M1 5w30 Fram TG
03 Maxima 3.5L 149k ST HM 10w30
Page 1 of 2 1 2 >
