Separating toddlers from their parents?
by fdcg27
06/19/18 08:50 PM
gm 8.6 truetrac
by Spitter
06/19/18 08:45 PM
New addition to my garage: 2000 Corvette FRC
by MrHorspwer
06/19/18 08:34 PM
Rockauto 5% off
by Spitter
06/19/18 08:32 PM
fumoto oil valve
by Santo
06/19/18 08:19 PM
Grand solar minimum...
by ridgerunner
06/19/18 07:57 PM
Pentofrost coolant $10 Autozone
by PD001
06/19/18 07:49 PM
The things you find cleaning Garage 30+ btls slob
by digger327
06/19/18 07:20 PM
Castrol GTX Magantec 0w20 - 6 pack $21.99 - Amazon
by 04SE
06/19/18 07:07 PM
Havoline Pro DS 5w20 $3.15/quart - Amazon
by 04SE
06/19/18 07:06 PM
Needing New Dipstick
by Geauxtiger
06/19/18 05:11 PM
'98 Mercedes E300TD Rotella T5 10W-30 5k miles
by KenO
06/19/18 04:35 PM
Premium guard oil filters
by Jaha24k
06/19/18 04:09 PM
76 super motor oil- synthetic blend 5w-30
by Jaha24k
06/19/18 04:07 PM
Who makes the Mopar 5038041AA filter?
by Quattro Pete
06/19/18 03:55 PM
Ruger Mini-14, yay or nay?
by 28oz
06/19/18 03:51 PM
USPS long long delivery to BlackStone Labs
by Pajero
06/19/18 02:58 PM
House A.c. vent leaking water
by motor_oil_madman
06/19/18 02:55 PM
"synthetic" gear oil and LS additive?
by nthach
06/19/18 01:54 PM
Supertech wix ST8 5514 miles
by jakewells
06/19/18 01:38 PM
Santo, aligoodn, memyself, MichiganKid419, kaphouston
65273 Registered Users
104 registered (addyguy, 2002 Maxima SE, AITG, Aero540T, 2015_PSD, 9050lx, 15 invisible), 1582 Guests and 30 Spiders online.
65273 Members
67 Forums
285621 Topics
#4630763 - 01/10/18 06:10 PM 08 buick lacrosse abs/traction control issues
lucerne06 Offline
Loc: northeast
So for the past few weeks everyone once and a while my abs/traction control lights would come on randomly, but by morning when I re started the car they would be gone..now after my battery went dead and I changed my battery the lights will not go off and the system is not working...took it to a mechanic said he ran a scan and it says the EBCM (co101) unit and the BPMV power unit are bad. It's like 1400.00 in parts alone..so question, what do you guys thing ??/ replace the units??? try something different ??? or just pull the fuses and turn off the traction control and abs, I dont really need the features, but will pulling the fuses also remove the dashlights that are on.. thanks
Edited by lucerne06 (01/10/18 06:11 PM)
#4630838 - 01/10/18 07:31 PM Re: 08 buick lacrosse abs/traction control issues [Re: lucerne06]
Dadillac Offline
Loc: Woodbridge, NJ
I would bet dollars to donuts that you have a bad wheel bearing/hub. GM vehicles use a bearing/hub combo that also houses the wheel speed sensor. When one fails you lose the ABS and traction control systems as these systems use the wheel speeds to determine what to do. You can pay a GM dealer to scan for the code to determine which bearing is shot. Or you can use a multimeter and figure it out for free.
Don
#4630840 - 01/10/18 07:34 PM Re: 08 buick lacrosse abs/traction control issues [Re: lucerne06]
WyrTwister Offline
Loc: Texas
https://www.google.com/search?q=abs+code...&channel=fs
I would start off by jacking up the rear of the car & visually examining the ABS wiring & sensors . I think the Right Rear .
Please report back what you find .
Wyr
God bless
#4630843 - 01/10/18 07:35 PM Re: 08 buick lacrosse abs/traction control issues [Re: lucerne06]
14Accent Offline
Loc: MN
We need codes... Without those it's hard to be of much help. C0101 isn't a valid code.
I highly doubt it's the EBCM unless you connected the new battery backwards or something crazy.
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
#4630848 - 01/10/18 07:42 PM Re: 08 buick lacrosse abs/traction control issues [Re: lucerne06]
JimPghPA Offline
Loc: Pittsburgh,PA U.S.A.
With all the salt that has been on the roads the last several weeks there is a very good chance that all that is wrong is that salt has gotten on the wheel speed sensors and is blocking it from working. Have someone put it up on a lift and hose off the sensors so there is no salt on them, and see if the problem goes away.
Edited by JimPghPA (01/10/18 07:43 PM)
Boy will I be happy when ALL vehicles on public roads are autonomous.
JimPghPa
#4630865 - 01/10/18 07:58 PM Re: 08 buick lacrosse abs/traction control issues [Re: lucerne06]
clinebarger Online   content
Loc: Fort Worth, Texas
Do you mean DTC C0110? If so....You most likely have a ABS Pump issue OR a ABS Pump Relay issue. The odds of BOTH going bad are remote at best!!!
The ABS Pump is part of the BPMV
The Pump Relay is part of the EBCM
Find a real Technician! Not a code reading parts changer, Or I might be able to walk you through at least testing the ABS Pump.....If it tests good, It's most likely the Relay.
Pulling fuses will not remove the warning lamps from the dash,The Cluster/IPC expects communication from the EPCM & if not received it will still light all the ABS warning lamps. You would have to pull & disassemble the IPC & pull the bulbs out. Most GM IPC's have the warning bulbs soldered to the circuit board which would make replacing the bulbs later a lot more involved.
If someone other than you drives this car....It would be best to fix the ABS/TCS. I disabled it on my Camaro but nobody else drives it.
2001 Chevy Camaro L92/4L80E
2010 Toyota Corolla 2ZR-FE/Auto
#4630902 - 01/10/18 08:45 PM Re: 08 buick lacrosse abs/traction control issues [Re: lucerne06]
TmanP Offline
Loc: MN
I had the same problem (warning lights) on my Lacrosse... turns out I ran over something that cut the wheel speed sensor wiring harness.
My code was a COO40. "Right front wheel speed sensor circuit malfunction".
2006 Buick Lacrosse 3.8 V6 150,000 mi
2015 Chevy Silverado LT Z71 5.3 V8 30,000 mi
2010 Toyota Sienna 3.5 V6 150,000 mi
#4630963 - 01/10/18 10:05 PM Re: 08 buick lacrosse abs/traction control issues [Re: lucerne06]
das_peikko Offline
Loc: San Antonio, TX
Those wheel speed sensors have delicate 20AWG wires and they live in a terrible environment.
#4631794 - 01/11/18 07:10 PM Re: 08 buick lacrosse abs/traction control issues [Re: lucerne06]
lucerne06 Offline
Loc: northeast
well just wanted to let all you gearheads know that it was fixed...the problem,, apparently when I removed and changed the dead battery and pu the new one in, I inadvertently caused one of the connections to come apart and when the mechanic traced the wires and re plugged them back together it solved the problem...freaking crazy....
#4632383 - 01/12/18 12:27 PM Re: 08 buick lacrosse abs/traction control issues [Re: lucerne06]
JimPghPA Offline
Sounds like you have an excellent mechanic.
JimPghPa
