Dieselgate hits Ford too?
When the EPA or some real authority says someone cheated I might believe it. Lawyers looking to make a buck...forget it.Surprised it took this long. The slime lawyers went after GM too and nothing has happened.
Ummm... the EPA issued a notice of violation of the Clean Air Act to VW.
I think he is talking about the Ford lawsuit which seems to be lawyer driven.
But the EPA didn't issue such a notice to Ford, General Motors, or Daimler.
All of the above have had a *civil* class action suit brought against them by the same law firm, Hagens Berman. In all of these instances, there has been no accusal of wrongdoing by the EPA.
Anymore, Hagens Berman amount to ambulance chasers, looking for hot topics to bring class actions suits against and score a quick settlement.
Originally Posted By: nthach
https://www.bloomberg.com/news/articles/...nes-were-rigged
It seems like Bosch is the lowest common denominator here - seeing how they supply Ford with the engine control and SCR systems. Just like how VW and Daimler worked with Bosch as well.
Could this dramatically affect Ford?
I'm not saying Ford did or didn't do anything wrong. BUT, How would Bosch be culpable for Ford using a feature they shouldn't use? I tune GM products all the time & use features inside the Engine Controllers to defeat emissions devices, It's not GM's fault I chose to do that.
Wait... If these trucks are over 7600# GVW, is this even relevant??? Seems like lawyers trying to make a buck.
I honestly doubt Ford, GM or Chrysler will ever get in trouble. Just because it is a domestic brand and can't hurt the guys at home.
There is so much more stuff going on with the EPA and the other brands. They get mad at VW for their diesels yet the guy in the jacked F250 rolls coal without even touching the pedal.
this is becasue many states and Canadian provinces and do not have emission testing so new trucks off the lot are getting dpf, egr and cat coverter deletes right at the dealership
and the pollution is outrageous, but there is a phrase I often use "its what you voted for"
https://www.ctvnews.ca/canada/b-c-coal-r...lists-1.1916039
if you want something different you have to change your government
And the DOT put pressure on VW for their diesels, but is letting Honda take their sweet time with Takata airbags.
You can have power and not roll coal. I'd love to point out to a coal roller that your engine is a short bus engine(and also used by New Flyer and Gillig in hybrid transit buses).
My truck's exhaust is less visible with a delete than it was with the stock emissions in place.
People who get smoke tunes are idiots. People who make smoke tunes are even worse.
THIS is dead on.
Is there any company that sells a diesel truck in the USA and uses no Bosch parts on it? I can't think of any.
What does that matter? Bosch doesn't build automobiles!
I brought that up because Bosch parts were suspected to contribute to the problem according to the person who started the tread. I then tried to see if that was true by seeing:
1. How many diesel engines with fake smog tests had Bosch equipment
2. How many diesel engines without fake smog tests had Bosch equipment
3. If an engine didn't have any Bosch equipment,did that mean it wasn't producing fake smog tests?
I'm not saying Bosch builds cars, I am saying that Bosch builds car parts. I am just wondering if Bosch parts are behind the fake smog tests.
Just about every engine controller can be configured/programmed to do whatever you want it to do. The vehicle manufacturer writes the calibrations & has the vehicles certified.
If the manufacture decides to use features in a controller to cheat emissions tests, It's on the vehicle manufacturer NOT the supplier of the controller.
To answer your question. Yes, The Big 3 all use a Bosch engine controller on their diesel pick-ups.
Bosch has a good chunk of the truck spectrum in the US. Only Cummins on the heavy-duty side above the 8-liter class, Hino and maybe Isuzu but Bosch did license out the patents to common-rail injection to Denso, Zexel(Valeo) and a few other companies.
Okay. Those trucks haven't been caught making fake smog numbers, not yet anyway.
Still, Bosch can't exactly be blamed for these fake numbers. Bosch can't really be blamed for what people do to their engine modules.
