rotella t4 vs delo
by 1978elcamino. 04/18/19 03:50 PM
Champion Oil Filters any Good?
by spk2000. 04/18/19 03:46 PM
Opinions on the best hidden dash cam?
by FordBroncoVWJeta. 04/18/19 03:28 PM
Maxlife Synthetic or PPHM 10w30
by 53' Stude. 04/18/19 03:27 PM
PYB 10w30 question
by 1978elcamino. 04/18/19 03:16 PM
Misbehaving Mechanic Caught On Dash Cam
by BlueOvalFitter. 04/18/19 02:38 PM
What oil for my newly acquired Samurai
by ad244. 04/18/19 02:37 PM
Check your Oil (SMA YouTube Video)
by javacontour. 04/18/19 02:37 PM
Wearing Hiking Shoes Full-Time
by oilpsi2high. 04/18/19 01:56 PM
Apply brakes, steering wheel shakes
by grampi. 04/18/19 01:35 PM
F150 Exhaust whistle
by Redright9. 04/18/19 01:20 PM
Boy, what a marketing win!
by SubieRubyRoo. 04/18/19 12:06 PM
auto shipping question for a friend
by earlyre. 04/18/19 11:02 AM
O Reilly motor oil
by porvdub. 04/18/19 10:59 AM
GM & JEEP O/S OIL FILTERS
by adrenalin89. 04/18/19 10:56 AM
Accord AC Issue
by maverickfhs. 04/18/19 10:54 AM
Transatlantic Communication Lines and the story
by StevieC. 04/18/19 10:41 AM
Kenzitoz, White12Boss302, terryj, Hadryk, djcavein
67844 Registered Users
121 registered members (2dogs, 53' Stude, 28oz, 1978elcamino, 2003f7, ad244, 9 invisible), 2,193 guests, and 24 spiders.
Topics287,704
Posts4,932,636
Members67,844
Most Online2,967
Mar 10th, 2019
Page 1 of 6 1 2 6
0W-40 pros & cons... #4630661
01/10/18 04:57 PM
01/10/18 04:57 PM
WI.
dblshock Offline OP
dblshock  Offline OP
WI.
If your speced for a CAFE 0/20 and concerned for drag friction vs. wear just short fill it with 0/40 like 1/8" lower than you would otherwise.
...double protection with even less friction drag.
16 Civic Coupe Touring 38k
640:1 TCW-3 E091
Edge 0/40 XG7317
Firehawk Indy 500
06 4Runner SR5 146k
640:1 TCW-3
PP 5/30 XG3614
Falken Wildpeak AT3W
Re: 0W-40 pros & cons... [Re: dblshock] #4630673
01/10/18 05:11 PM
01/10/18 05:11 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Some of the newer engines are specifically designed for xw20 oil verses engines that were designed for multiple grades that can use xw20 and get by with it.
If the engine is designed for it there is no benefit in going with heavier weight oil, in fact with the clearances and surface finish on the crank and dual stage oil pumps it may be detrimental.
Re: 0W-40 pros & cons... [Re: dblshock] #4630678
01/10/18 05:16 PM
01/10/18 05:16 PM
Kendall, FL
wemay Offline
wemay  Offline
Kendall, FL
popcorn2 popcorn
18 KIA Sportage 2.4 AWD
QSUD 5W-20, PH9688
13 Hyundai Santa Fe Sport 2.0T
PP EuroL 5W-30, OE
Re: 0W-40 pros & cons... [Re: dblshock] #4630681
01/10/18 05:22 PM
01/10/18 05:22 PM
SE British Columbia, Canada
Snagglefoot Offline
Snagglefoot  Offline
horse Cheers2
40 weight is becoming a dead issue. Take a look at GM. 0-20, 5-20, 5-30. Period.
Gas mileage requirements and a need for thinner oil to keep the AFM system operable are the main reasons. The Doxos designation is required to keep those fancy lifters in good shape.
SF
If you want the job done right......do it yourself.
Re: 0W-40 pros & cons... [Re: dblshock] #4630682
01/10/18 05:23 PM
01/10/18 05:23 PM
New England
Virtus_Probi Offline
New England
OK, I'll bite...how does underfilling a bit lower the friction drag?
I would imagine any reasonable answer would also imply a loss of protection...
2014 Forester XT, 95000 miles
Last Change;
M1 0W30 AFE d1G2
Tokyo Roki 15208AA170 filter
Re: 0W-40 pros & cons... [Re: Virtus_Probi] #4630684
01/10/18 05:31 PM
01/10/18 05:31 PM
Deplorable in apple valley, ca
Chris142 Online content
Chris142  Online Content
ya what the heck?
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: 0W-40 pros & cons... [Re: dblshock] #4630685
01/10/18 05:33 PM
01/10/18 05:33 PM
Middlesex County CT
simple_gifts Offline
Middlesex County CT
Never seen CAFE 0/20 in my owners manual.
t
2004 Prius; 113K; ASL
2007 Yaris 86K 0w-40 Castrol
2006 B2300;135K;ALM
Was driving an ox cart; Now on the USS Enterprise
Re: 0W-40 pros & cons... [Re: simple_gifts] #4630690
01/10/18 05:46 PM
01/10/18 05:46 PM
New England
New England
t
That's a popular PQIA red dot grade...
Last Change;
M1 0W30 AFE d1G2
Re: 0W-40 pros & cons... [Re: dblshock] #4630707
01/10/18 06:09 PM
01/10/18 06:09 PM
Down Under
SR5 Offline
SR5  Offline
Down Under
I honestly don't believe this "modern engines are specifically designed for xw20 only" thing. Sure modern engines run well on 20 grades, and they are well establish oils that work well and protect well, they are also certainly encouraged by the manufacturer as they ccontribute positively to fuel economy - maybe only a little bit, but it all adds up.
If you look at engine clearances they are typically measured in 10's of microns, while if you look at operational oil film thicknesses they are typically measured in single microns (Shannow has some good tables here). Any reasonable oil grade should operate fine in any reasonable mass produced engine. As long as it starts OK or it's not being raced.
Also look at the effects of temperature
M1 0W40 FS
KV40 = 70.8 cSt
KV100 = 12.9 cSt
M1 0W20 AFE
KV40 = 44.8 cSt
KV100 = 8.7 cSt
Right now I am in the middle of an hot Australian summer while most of you are in the middle of a cold North American winter. It's not unusual for me to "cold" start my car at 40C and quickly go up from there, here overheating cars, of which I've seen a few recently, are the big issue. But in NA you could be starting your car at -30C and maybe then short tripping it to work, with the oil never fully heating up.
Given the above situation, with the same cars, me running 0W40 in Australia and you running a 0W20 in NA, it's quite possible that for most of the drive I'm running the lower viscosity oil (as in operational viscosity). It's easy for a cold 20 grade to be a lot thicker than a hot 40 grade.
So if a modern engine isn't designed to run well on a 40 grade at full operational temperature, then how does it run on a 20 grads at below 0F (-20 C) ?
Castrol GTX Ultraclean 15W40 A3/B3 + Wesfil-Cooper Z154
Re: 0W-40 pros & cons... [Re: dblshock] #4630715
01/10/18 06:18 PM
01/10/18 06:18 PM
NC
Vladiator Offline
Vladiator  Offline
NC
OK I am officially a 0w20 convert...I think... BUT 0w40 does have a lot of benefits. This is just from personal experience with my vehicles, your results may vary.
Pros:
- Much easier starting than any 5w30. I started to notice the difference from 40°F and below.
- Little to no "metal rattle" at high RPMS, compared to 0w20, 0w30, 5w30. It is more of a metal cricket sound than a rattle, but 0w40 heals it. No, it is not a mechanical problem, just the nature of the engines I serviced.
- Same type of rattle/tick never shows up after excessive idling on 0w40. It always becomes more audible after excessive idling with 0w20, 0w30, 5w30.
- Out of 0w40s that I have tried - PENNZOIL 0w40 SRT actually improves my MPG by a hair across the range. Improved the MPG in 2006 Toyota Highlander Hybrid by 3mpg.
Cons:
- Castrol 0w40, Mobil1 0w40, and PENNZOIL Euro 0w40 give a slight MPG hit. Very little, not significant, maybe 1-2mpg at most across the board. PENNZOIL 0W40 SRT DOES NOT have that issue.
No other Cons from my experience in my daily drivers. Results could be different in more demanding applications. Just sharing my real world experience.
Re: 0W-40 pros & cons... [Re: dblshock] #4630716
01/10/18 06:20 PM
01/10/18 06:20 PM
New Braunfels
Bryanccfshr Offline
Bryanccfshr  Offline
New Braunfels
I don’t understand the underfilling having any relevance.
The viscosity difference is negligible.It really doesn’t make a big difference. Low power engines (less this 200hp)May have a difference in performance while cold.
2018 Trd Pro 4Runner
2018 Tacoma off-road
Dealer 0w20 to M1 0w40 FS -it depends
Re: 0W-40 pros & cons... [Re: SR5] #4630720
01/10/18 06:25 PM
01/10/18 06:25 PM
NC
Vladiator Offline
Vladiator  Offline
NC
EXACTLY! Funny how so many people refuse to realize that simple fact.
P.S. I really Crack up when I hear or read some people say that they don't want to use w40 because it will clog up the oil passages in the engine.
Re: 0W-40 pros & cons... [Re: dblshock] #4630725
01/10/18 06:31 PM
01/10/18 06:31 PM
'Stralia
Shannow Offline
Shannow  Offline
'Stralia
Designed specifically for thinner oils...
OK, Honda admit that they are making bearings bigger (length and diameter), while reducing oil clearances. This is the behaviour to increase minimum oil film thickness with thinner oils...aka they have reached the point where they can't go thinner on bearings.
Why are they doing this ?
Primarily to reduce the still comparatively massive piston/skirt frictional losses, by reducing viscosity.
This will decrease skirt drag, while increasing bearing drag, so there's an optimisation taking place.
So YES, Honda are designing engines for thinner oils.
But that's not an argument that these engines must exclusively use them. Per SR5, can't ever cold start them if 12Cst is going to damage an 8cst engine.
Re: 0W-40 pros & cons... [Re: dblshock] #4630730
01/10/18 06:36 PM
01/10/18 06:36 PM
PimTac Offline
PimTac  Offline
And this is another episode of The Thick and Thin Oil Turns, the most popular soap opera on BITOG.
Cannot see signatures any longer so it doesn’t matter.
Re: 0W-40 pros & cons... [Re: PimTac] #4630733
01/10/18 06:43 PM
01/10/18 06:43 PM
Wet side WA
JohnnyJohnson Online content
JohnnyJohnson  Online Content
Wet side WA
crackmeup thumbsup
2004 Corolla 130785
Out: EDGE EP 5W-30 Bosch 3311 7156 Miles
In: Havoline Pro DS 10w-30 Purolator PureOne 3-14-19 129693
2006 Duramax 74725
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Page 1 of 6 1 2 6
