Fullers Vintage Ale anyone?
by Lolvoguy. 12/18/18 11:23 PM
Got an alignment
by michaelluscher. 12/18/18 11:18 PM
Castrol Edge 0W-40; 9,762 mi; 2016 Ford Fiesta ST
by asiancivicmaniac. 12/18/18 10:50 PM
Windows Defender Error Code
by ZeeOSix. 12/18/18 10:20 PM
UOA Motul 300V, 5w40, 2013 BMW S1000RR
by Sportbiker. 12/18/18 09:53 PM
Under valve cover pics
by barkingspider. 12/18/18 09:47 PM
Kubota Super UDT2? Anything better?
by Jmoney7269. 12/18/18 09:23 PM
Car Door Fabric Glue
by cb450sc. 12/18/18 08:57 PM
Canadian Uber
by StevieC. 12/18/18 08:13 PM
71141 / Lifeguard 5
by chefwong. 12/18/18 07:52 PM
Tested Positive for Flu
by john_pifer. 12/18/18 07:37 PM
Cooper RTX?
by 01rangerxl. 12/18/18 07:25 PM
IPhone SE or flip phone?
by 53' Stude. 12/18/18 05:49 PM
1993 K1500 hard cold start
by BrianF. 12/18/18 05:43 PM
Put my wife's dog down yesterday
by Stelth. 12/18/18 05:04 PM
ATF Filter oem vs aftermarket any differences?
by 97prizm. 12/18/18 03:50 PM
Depth-Fiberglass Filter Media.
by Al. 12/18/18 03:43 PM
Sportbiker, trollhattan, MuhThugga, wxo, dbierman
66718 Registered Users
44 registered members (ABCarr, 01rangerxl, anndel, 19VWJettaS6speed, asiancivicmaniac, AndyB, 2 invisible), 1,234 guests, and 35 spiders.
Topics295,247
Posts4,930,829
Members66,718
Most Online2,553
Oct 27th, 2018
Fram PH3387A #4630462
01/10/18 12:57 PM
01/10/18 12:57 PM
Texas
WyrTwister Offline OP
Texas
$ 3.77 at Home depot and Walmart .
$ 3.59 Napa Silver with current discount .
Which is the better filter ?
Thanks , :-)
Wyr
God bless
Re: Fram PH3387A [Re: WyrTwister] #4630476
01/10/18 01:07 PM
01/10/18 01:07 PM
OH
SatinSilver Offline
SatinSilver  Offline
OH
Should probably throw in the ST Wix at WM for around $2.77 or so. The Fram has an efficiency rating of 95% for 20 microns and larger.
Re: Fram PH3387A [Re: WyrTwister] #4630498
01/10/18 01:24 PM
01/10/18 01:24 PM
Houston, Texas
WellOiled Offline
WellOiled  Offline
Houston, Texas
If you are referring to the Fram Extra Guard for $3.77, I would prefer it over the NAPA Silver for the following reason(s):
1. The Fram Extra Guard has a dome end bypass valve and it is independent from the ADBV in some/most cases.
2. The NAPA Silver has a combo valve. Some folks take issue with the nitrile combo valves. Again for some/most cases.
3. The Fram Extra Guard efficiency is better. 95% @ 20 micron.
4. Rare to see a bad cut & post of either filter even when seriously abused.
5. Still can't decide, flip a coin.
2004 Ford Ranger 4.0L V6
Valvoline Advanced Full Synthetic 5W30 + Fram Tough Guard
Re: Fram PH3387A [Re: WyrTwister] #4630513
01/10/18 01:35 PM
01/10/18 01:35 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Either is fine for a 5,000 mile OCI
Re: Fram PH3387A [Re: WyrTwister] #4630518
01/10/18 01:37 PM
01/10/18 01:37 PM
OH
SatinSilver Offline
SatinSilver  Offline
OH
More important is what air filter will be used. For that I'd go oem or a Fram Extra Guard. With the Fram being preferred.
Re: Fram PH3387A [Re: WyrTwister] #4630541
01/10/18 01:58 PM
01/10/18 01:58 PM
Texas
Texas
For the Lacrosse 3.8l , 3000 mile OCI on dino oil .
Thanks , :-)
Wyr
God bless
Re: Fram PH3387A [Re: WyrTwister] #4630542
01/10/18 01:58 PM
01/10/18 01:58 PM
Idaho
CT8 Offline
CT8  Offline
Idaho
The end result in the differences in engine wear in real life would be iconsequential. What really matters in that the filter doesn't fail in operation .
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Fram PH3387A [Re: WyrTwister] #4630554
01/10/18 02:10 PM
01/10/18 02:10 PM
Tennessee
goodtimes Offline
goodtimes  Offline
Tennessee
Neither has a bypass valve required so the Napa Silver for me. I just don't like some of the EG 's pictured here. I got the Luber Finer PH477 for about $5 with discount, which is above these filters.
Re: Fram PH3387A [Re: WyrTwister] #4630562
01/10/18 02:15 PM
01/10/18 02:15 PM
Cincinnati, OH, USA
bullwinkle Offline
bullwinkle  Offline
Cincinnati, OH, USA
I would pick the Super Tech, since it should be exactly the same filter as the NAPA Silver, for less money.
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: Fram PH3387A [Re: bullwinkle] #4630641
01/10/18 03:22 PM
01/10/18 03:22 PM
Houston, Texas
WellOiled Offline
WellOiled  Offline
Houston, Texas
Bullwinkle - actually, the NAPA silver has 10% more media than the Proselect. The Proselect and the Super Tech are the same filter AFAIK.
Re: Fram PH3387A [Re: WyrTwister] #4630656
01/10/18 03:46 PM
01/10/18 03:46 PM
Georgia
MParr Offline
MParr  Offline
Georgia
NAPA Silver
2013 KIA Optima EX 2.4L. Now: QSUD 5W30 & STP S2808ML
2017 Ford Escape SE 2.0T Now: Mobil 1 5W30 & NAPA Gold 1348
Re: Fram PH3387A [Re: WyrTwister] #4630669
01/10/18 04:06 PM
01/10/18 04:06 PM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
If you want better efficiency and a silicone ADBV (only on the newer EGs, so check ADBV color before buying), then get the Fram over the NAPA Silver.
Re: Fram PH3387A [Re: WyrTwister] #4630696
01/10/18 04:53 PM
01/10/18 04:53 PM
California
nthach Offline
nthach  Offline
California
It doesn't matter. As long as the engine sounds good and the filter doesn't fail either will work.
Re: Fram PH3387A [Re: WyrTwister] #4630700
01/10/18 05:01 PM
01/10/18 05:01 PM
USA
slacktide_bitog Offline
USA
Fram has started using silicone ADBV's on even their cheapest filters, so if you can find a PH3387A with the silicone, that would be my choice. Otherwise, Napa Silver.
FWIW, the ST at Walmart is less than $3 is the same as the Napa Proselect smile
Re: Fram PH3387A [Re: WyrTwister] #4630853
01/10/18 07:44 PM
01/10/18 07:44 PM
Texas
Texas
How does the Napa Proselect " rate " compared to the Napa silver ?
Thanks , :-)
Wyr
God bless
