Interior "quick detailer"
by Redright9. 03/25/19 08:21 AM
Seafoam For Last 100 Miles Before Oil Change ?
by ChrisD46. 03/25/19 07:56 AM
WIX 57151XP factory filled with synthetic oil
by Donald. 03/25/19 06:58 AM
BMW Buying Guide: Every Model, Explained
by wemay. 03/25/19 05:43 AM
Double Din Android Auto Advice
by JeffKeryk. 03/24/19 11:25 PM
VW mk5 a/c intermittently works
by ram_man. 03/24/19 11:01 PM
DIY alignment done right?
by tookien. 03/24/19 10:03 PM
Cell phone privacy question
by loneryder. 03/24/19 10:00 PM
Ride quality between 45 and 35 sidewall
by bowlofturtle. 03/24/19 09:23 PM
FRAM TG 7317 - 12K miles opened
by crazy_raccoon. 03/24/19 09:01 PM
2014-2017 Toyota Corolla CVT Quiet Recall
by StevieC. 03/24/19 08:11 PM
Finally Found Factory Ammo my 308 Bolt Gun Likes
by Fastzntn. 03/24/19 08:10 PM
Umarex Glock 19 Co2
by Sonic. 03/24/19 07:57 PM
I put in 2 1/2 qts, damage?
by JLawrence08648. 03/24/19 07:21 PM
How to dispose / recycle Li-Ion batteries?
by 92saturnsl2. 03/24/19 06:16 PM
New member of the (automotive) family!
by addyguy. 03/24/19 06:04 PM
sonusfaber, Rollo, Drifted, Jcar516, gregjr7
67614 Registered Users
79 registered members (beanoil, ARCOgraphite, avi1777, Bailes1992, BeerCan, Berny, 8 invisible), 1,639 guests, and 59 spiders.
Topics286,387
Posts4,907,333
Members67,614
Most Online2,967
Mar 10th, 2019
Opinion of Propane Furnaces #4630231
01/10/18 11:04 AM
01/10/18 11:04 AM
VA
Gebo Offline OP
Gebo  Offline OP
VA
I have an old Lennox Pulse Furnace from 1994 that is still running like a charm. 23 years is absolutely fantastic. The only maintenance done on it was when I replace that little round filter ever 7 years. It got really cold last week and I started wondering what I would do for a replacement. What is your opinion? I only use it for backup heat from 35 degrees and lower. HP for 35 degrees and up.
Are all propane brands about the same? Or is there a "leader" so to speak? I don't think I want the newest technology. Heck, would I be better off with electric heat strips and just eliminate the propane furnace once it dies?
'98 LEX LS400 290K
'02 4Runner 230K
'05 Lex LS430 85K
'07 Lex GX470 65K
Amsoil in last two.
Schaeffer in the first two.
Re: Opinion of Propane Furnaces [Re: Gebo] #4630278
01/10/18 11:42 AM
01/10/18 11:42 AM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
The house I bought in DE went from A/C with gas furnace to HP with electric booster coils. I can view history and the booster coils are not on much.
2015 Ford F250 w/Powerstroke
Re: Opinion of Propane Furnaces [Re: Gebo] #4630281
01/10/18 11:46 AM
01/10/18 11:46 AM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
Newer propane furnaces and boilers are modulating and condensing. All propane gas is the same. Tank rental/ownership is one issue. Get a propane generator since you have propane.
Re: Opinion of Propane Furnaces [Re: Gebo] #4630342
01/10/18 12:19 PM
01/10/18 12:19 PM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
My impression is propane furnaces are very close to being the same as a natural gas furnace . Just with different jetting ?
We have a Goodman 90% or 92& condensing natural gas furnace bought some time in the early 1990's . It has a 2 stage gas valve . Only time it goes into high flame is when I set back the tstat while we are out of town . When we return & I reset the tstat , it goes into high flame and warms up the house pretty quickly .
Probably the last thing I would do is go to electric resistance heat .
I think the newest , top of the line Mini Split HP's will operate down to close to 0F .
If you replace the propane furnace , continue with a condensing furnace ( high efficiency ) .
Also get a tank large enough to fill in the summer , when propane prices are down & last all / most of the winter .
Wyr
God bless
Re: Opinion of Propane Furnaces [Re: Gebo] #4630380
01/10/18 12:44 PM
01/10/18 12:44 PM
Indianapolis, IN
dnewton3 Offline
Global Moderator
dnewton3  Offline
Global Moderator
Indianapolis, IN
I first lived with natural gas (NG) for many years. Then my wife and I moved and lived with a propane condensing furnace for 15 years; there was no natural gas where I lived at the time. The propane furnace was fantastic. We moved yet again, and now back on natural gas. Still great.
Why? Because generally other than the burner orifices and regulator, furnaces (and most other gaseous fuel appliances) are the same. We first were on NG when we got a new gas dryer. Then we moved outside the city and I bought an OEM kit to convert it over to LPG and did it myself. Then, when we moved back into NG supply area, I converted the dryer back again. Furnaces can be done the same way; the orifices are changed out and the pressure regulator is modified (typically by a spring set kit).
Unless otherwise stated, my all appliances are sold as "NG" units. Some companies will sell LPG units at the consumer level (such as blue flame wall heaters, water heaters, clothes dryers). Other appliances are larger and simply converted upon installation (like whole-house furnaces).
My point is that regardless of the fuel supply, if the unit is a good performer, it will do so either way, if set up properly.
Brand loyalty? That's no difference than oils, guns and girlfriends. Some have it; some don't. You decide.
The act of preventative maintenance, in and of itself, is FAR MORE important than brand/grade/base choices among lubes and filters.
- under maintaining something is akin to abuse/neglect; that can kill equipment by shortening the lifespan
- over maintaining something has never been proven to be anything but a waste of time and money
Re: Opinion of Propane Furnaces [Re: Gebo] #4630388
01/10/18 12:49 PM
01/10/18 12:49 PM
PV Az @ 5000'
AZjeff Offline
AZjeff  Offline
PV Az @ 5000'
If you use it very little in your climate I'd consider replacing the propane furnace with an electric one when the time comes. The reason I'd consider it is because we moved to an all electric house in 2005 and were leery of it, but our utility bills have been perfectly acceptable, lower usually than most anyone we compare with when they ask about the electric heat. Could you get heat strips installed in your HP exchanger plenum? What is your stove & water heater?
86 Samurai 1.3 leftovers
14 RAV4 2.5 5W-20 PP
16 Silverado 1500 4.3, DI, AFM 5W-30 PP
The most important thing to do in your life is to not interfere with someone else's life. - Frank Zappa
Re: Opinion of Propane Furnaces [Re: Gebo] #4630392
01/10/18 12:50 PM
01/10/18 12:50 PM
Hudson, NH
LeakySeals Offline
LeakySeals  Offline
Hudson, NH
My house is 18 years old, approx 3k sf. Heat and hot water is propane. Forced hot air. Propane Generac outside. The fill ups are scary +-$800. Everything runs good. Can't tell the diff from when I had natural gas in the last house.
06 Escalade 6.0L LQ9 AWD 165k M1 0w40
03 Maxima 3.5L POS 162k ST HM 10w30
05 Malibu Classic 108k Unk
Re: Opinion of Propane Furnaces [Re: AZjeff] #4630402
01/10/18 12:58 PM
01/10/18 12:58 PM
VA
Gebo Offline OP
Gebo  Offline OP
VA
Stove electric, water heater propane
'98 LEX LS400 290K
'02 4Runner 230K
'05 Lex LS430 85K
'07 Lex GX470 65K
Amsoil in last two.
Re: Opinion of Propane Furnaces [Re: Gebo] #4630406
01/10/18 01:02 PM
01/10/18 01:02 PM
VA
Gebo Offline OP
Gebo  Offline OP
VA
Thanks for your input. I was hoping you could recommend or steer me clear of certain brands. Maybe in today's market, they are all the "same"?
I was reading consumer reports or some such magazine and was amazed at how many HP have the same "guts" but are being put in a different shell. I've about decided a Goodman propane furnace would be perfectly fine...
'98 LEX LS400 290K
'02 4Runner 230K
'05 Lex LS430 85K
'07 Lex GX470 65K
Amsoil in last two.
Re: Opinion of Propane Furnaces [Re: Gebo] #4630412
01/10/18 01:07 PM
01/10/18 01:07 PM
Hudson, NH
LeakySeals Offline
LeakySeals  Offline
Hudson, NH
Here are my 2. American Standard Freedom 90 on the left for the house and the "weather king" installed a few years ago for a finished basement.
Re: Opinion of Propane Furnaces [Re: Gebo] #4630426
01/10/18 01:22 PM
01/10/18 01:22 PM
Baltimore, Maryland, USA
zzyzzx Offline
zzyzzx  Offline
That's your problem right there! Newer high efficiency heat pumps still work good at way less than 35 degrees. Even during the recent cold snap that just ended the HP was running.
Re: Opinion of Propane Furnaces [Re: zzyzzx] #4630435
01/10/18 01:29 PM
01/10/18 01:29 PM
VA
Gebo Offline OP
Gebo  Offline OP
VA
What? Where is my problem? My propane furnace has lasted 24 years and I'm on my second HP. Seems to me things have really worked well????
grin
'98 LEX LS400 290K
'02 4Runner 230K
'05 Lex LS430 85K
'07 Lex GX470 65K
Amsoil in last two.
Re: Opinion of Propane Furnaces [Re: Gebo] #4630557
01/10/18 03:11 PM
01/10/18 03:11 PM
zzyzzx Offline
zzyzzx  Offline
I was just saying that if you had a better heat pump, you wouldn't be using electric heat even in the recent cold snap. Hence making the propane furnace useless and redundant.
Re: Opinion of Propane Furnaces [Re: Gebo] #4630564
01/10/18 03:16 PM
01/10/18 03:16 PM
Illinois
SHOZ Offline
SHOZ  Offline
Illinois
If getting a new furnace only for back up I would shy away from the really efficient condensing ones as they are more complicated. Ideally you would only need it in extreme cold.
2008 Hyundai Accent 1.6L 5 sp manual hatchback
2010 Hyundai Genesis Coupe Track 2L Turbo 6sp manual
Re: Opinion of Propane Furnaces [Re: zzyzzx] #4630601
01/10/18 03:38 PM
01/10/18 03:38 PM
VA
Gebo Offline OP
Gebo  Offline OP
VA
Understood.
But what I want is for HOT AIR to come out of my ducts when it gets really cold outside. I want that HOT air that feels warm to the touch. You get older and your body really likes that HOT air. LOL! smile
'98 LEX LS400 290K
'02 4Runner 230K
'05 Lex LS430 85K
'07 Lex GX470 65K
Amsoil in last two.
