Honda ATF DW1 bottle stamp decoding
by parshisa
06/25/18 12:03 PM
How to lower throttle sensitivity?
by NICAT
06/25/18 11:41 AM
That's some service! (New Central AC...)
by xBa380
06/25/18 11:13 AM
Valvoline 2 Cycle TC-W3 Marine Oil - 6qt - $20
by Jimzz
06/25/18 10:45 AM
Plumbing/Bldg Experts: Cause of Wet Slab?
by LoneRanger
06/25/18 10:13 AM
How to CONFIRM the Country of Manufacture
by Ed_Flecko
06/25/18 09:58 AM
Replacing trans oil seal
by redhat
06/25/18 09:50 AM
VW diesels sitting in huge lots waiting......
by ZZman
06/25/18 09:09 AM
DTD/DT Independence Day Promos
by Sayjac
06/25/18 08:39 AM
It's AMSOILŪ, not Amsoil
by Rat407
06/25/18 06:39 AM
VW Passat 2007
by madRiver
06/25/18 06:18 AM
Review: CVJ Remanufactured CV Axles
by The Critic
06/25/18 03:40 AM
Towing without 85w140?
by OilFilters
06/25/18 03:07 AM
2015 VW GTI autobahn oil questions
by Skyalbo
06/24/18 11:28 PM
Corrosion in the garage - salt or humidity?
by Kurtatron
06/24/18 11:13 PM
Darn dogs
by AZjeff
06/24/18 10:21 PM
New GC?
by Bullwinkle007
06/24/18 10:04 PM
The guy with the plexiglass head on you tube
by andyd
06/24/18 09:21 PM
'07 Pacifica Timing Belt Replacement success
by 92saturnsl2
06/24/18 09:10 PM
SAE 90 v 85/140
by Knuckle078
06/24/18 09:10 PM
dhy808, ROD_Z, lozpxs, danthemanx07, FunktasticLucky
65319 Registered Users
82 registered (2015_PSD, 4WD, 69Torino, 77GrandPrix, 853okg, 6 invisible), 1631 Guests and 39 Spiders online.
65319 Members
67 Forums
285968 Topics
Page 1 of 2 1 2 >
#4630146 - 01/10/18 09:10 AM Wireless charging not dependable. Why?
LeakySeals Offline
Loc: Hudson, NH
Got an Atomi Fast Charge Wireless charger for Christmas. Using it with a Galaxy s7 and the adaptive wall charger the phone came with. Was great for a couple of days. Not having to plug it in is awesome. Was very happy with it. Then two days later... I started getting a "wireless charging paused" notification on my phone. The Atomi pad was shutting off completely. I googled and many reviews say its junk, stopped working, returned for something else. Then I started reading reviews of other wireless chargers to find a better one. Same complaint. Even the Branded Samsung wireless charger has complaints about reliability and paused charging.
Before I threw the charger away, tried an older generic wall charger without the fast adaptive stuff just to see what happens. Haven't had a problem since. Charges slower, and IMO for the better. Fast wireless charging was making the phone heat up. It doesn't do that anymore
Anyone else having problems with fast wireless charging?
06 Escalade 6.0L AWD 160k. M1 5w30 Fram TG
03 Maxima 3.5L 149k ST HM 10w30
#4630167 - 01/10/18 09:22 AM Re: Wireless charging not dependable. Why? [Re: LeakySeals]
zzyzzx Online   sleepy
Loc: Baltimore, Maryland, USA
Because it's not properly connected.
#4630175 - 01/10/18 09:23 AM Re: Wireless charging not dependable. Why? [Re: LeakySeals]
KrisZ Offline
Loc: Toronto, Canada
No experience with wireless charging, but my new phone also heats up on the fast charger and just like you I decided to use the slow charger form the old phone to charge overnight. I will use the fast charger when I need a quick boost, no need to fast charge when I'm sleeping.
2015 Dodge Grand Caravan-21k miles.
2006 Mazda 3-155k miles
#4630185 - 01/10/18 09:30 AM Re: Wireless charging not dependable. Why? [Re: LeakySeals]
Leo99 Offline
Loc: NJ
Mine works pretty good. About 5 times a year the charging will stop at around 75%. Other then that, no problems.
Without data you're just another person with an opinion. W. E. Deming
2003 Corolla 250,000 miles
2004 Rav4 359,000 miles
2015 Camry 59,000 miles
#4630201 - 01/10/18 09:44 AM Re: Wireless charging not dependable. Why? [Re: LeakySeals]
LeakySeals Offline
Loc: Hudson, NH
I'm wondering if the problem(s) is actually the white Samsung adaptive fast charger wall plug. If it shuts off power, or if the wireless charger senses the rapid charge changes as a problem and turns itself off.
#4630210 - 01/10/18 09:51 AM Re: Wireless charging not dependable. Why? [Re: LeakySeals]
tmorris1 Offline
Loc: MN
If the phone isn't lined up correctly on the pad it will not charge with the correct rate or at all.
#4630223 - 01/10/18 10:00 AM Re: Wireless charging not dependable. Why? [Re: LeakySeals]
LeakySeals Offline
Loc: Hudson, NH
I was hoping it was something simple like alignment. But this particular wireless pad has different LEDs to tell you if somethings off like alignment, finished charging, etc. Not what's happening here. Phone puts up a notification saying wireless charging is paused, and the wireless charger has no LED's. Dead. I have to unplug the wall outlet and plug it back in. Does not happen with a standard wall charger.
#4630298 - 01/10/18 10:56 AM Re: Wireless charging not dependable. Why? [Re: LeakySeals]
PeterPolyol Offline
Loc: toronto
I'd guess it's built-in overheat protection 'pausing' the charging. Samsung just came off a huge corporate nightmare with battery fires and inductive charging is wasteful and heat generating, albeit convenient. Doubt they're taking chances with batteries right now.
#4630301 - 01/10/18 10:58 AM Re: Wireless charging not dependable. Why? [Re: LeakySeals]
racer12306 Offline
Loc: Baltimore, MD
I have had zero problems with the actual act of wireless charging.
I have a wireless charger that I bought May 2015 to use when I got my Nexus 6. I used it until May 2017 when I switched to an iPhone 6 as I awaited for the next gen of iPhone's to come out. I now have an iPhone 8 that charges every night on the same charging pad.
The only problem I have is that the back of the iPhone 8/8+/X is glass, so it slides off while charging. I think the newer pads accommodate this better but I've put some dabs of hot glue on the charger and it works fine.
My charger is a Choetech Stadium. It's no longer available, but Choetech does still make wireless chargers.
I'd be looking at something in the phone or in the specific charger and yes, alignment is key. Mine has 3 coils on it to make the alignment less of an issue.
How many amps does the wall wort put out?
16 Ford Focus/2.0/6A
04 Dodge Neon SXT/2.0/MTX
12 Chrysler T&C/3.6/6A
#4630303 - 01/10/18 10:58 AM Re: Wireless charging not dependable. Why? [Re: LeakySeals]
2010Civic Offline
Loc: Minnesota
I use a cheap "KoolPad" brand wireless charger I bought off amazon. It works perfect with my S6 edge. I've had it for over a year.
2010 Honda Civic LX
Valvoline SynPower 5w-20 - Honda oil filter
54,061 miles
#4630355 - 01/10/18 11:25 AM Re: Wireless charging not dependable. Why? [Re: LeakySeals]
LeakySeals Offline
Loc: Hudson, NH
Here is a pic.
#4630364 - 01/10/18 11:31 AM Re: Wireless charging not dependable. Why? [Re: LeakySeals]
LeakySeals Offline
Loc: Hudson, NH
I think its something to do with fast/turbo 10w charging. The regular 5w charging seems to be fine.
#4630398 - 01/10/18 11:56 AM Re: Wireless charging not dependable. Why? [Re: LeakySeals]
billt460 Offline
Loc: Glendale, Arizona
If Tesla had lived another 50 years, we wouldn't have electric outlets in our homes. Just one main antenna.
#4630441 - 01/10/18 12:37 PM Re: Wireless charging not dependable. Why? [Re: LeakySeals]
CELICA_XX Offline
Loc: Oklahoma
I just recently started wireless charging with the new iPhone... never had any issues
15 Toyota Prius - M1 EP 0w20
02 Toyota ECHO - Valv MaxLife Full Syn 5w30
97 Lexus LX450 - M1 0w40
93 Lexus LS400 - Valv MaxLife Full Syn 5w30
#4630523 - 01/10/18 01:41 PM Re: Wireless charging not dependable. Why? [Re: LeakySeals]
beast3300 Offline
Loc: Ohio
I'm using a Samsung "Fast" wireless charger with my N8. It only messed up on me once. I woke up and the charge indicator on the charger was blinking. I took the phone off and re-positioned it and it was ok. I have the EP-NG930TBUGUS because it was free with the phone and works well.
'03 Regal GS L67: PPUP 5w30/FU3980
'99 Grand Prix L36: R.I.P.
'07 LaCrosse L26: QS HM 5w30/TG3387A
ASE L1 MT
Page 1 of 2 1 2 >
