Kendall nitro 70
by Bullwinkle007. 01/19/19 11:11 PM
Dexron HP
by Snagglefoot. 01/19/19 11:11 PM
Ruger American 22 Mag
by TiredTrucker. 01/19/19 11:06 PM
Prestone Dex Cool vs Carquest Dexcool
by A_User55555. 01/19/19 11:05 PM
FRAM end cap differences EG and TG vs XG
by wemay. 01/19/19 09:25 PM
Valvoline modern Engine
by Pinoak. 01/19/19 09:02 PM
30 Vintage Photos
by StevieC. 01/19/19 08:23 PM
Low mileage, when to change oil?
by Metfanant. 01/19/19 08:05 PM
Filter with bypass when OEM has built-in bypass
by rubberchicken. 01/19/19 07:43 PM
Barrett Jackson 2019 Pics
by Nick1994. 01/19/19 05:41 PM
What do y'all do with old car parts?
by qdeezie. 01/19/19 05:11 PM
Diagnosing catalytic converters.
by Tlhfirelion. 01/19/19 04:20 PM
Oil recommendations for GM Vortec 8100
by Dudemanmaximus. 01/19/19 04:14 PM
Leaf Spring Questions- Lots of Questions
by George7941. 01/19/19 04:02 PM
Am I being out of line?
by Chris142. 01/19/19 04:00 PM
Some good modern rock songs
by 53' Stude. 01/19/19 03:51 PM
06 Pathfinder O2 sensor voltage sensor 1
by Bluestream. 01/19/19 03:50 PM
Honda Blue Coolants
by redhat. 01/19/19 03:49 PM
dougway, Jetsfan421, Fordman420, 72sbc, ejmiller
66982 Registered Users
45 registered members (928, bdcardinal, BLND1, A_User55555, bbhero, Bullwinkle007, 1 invisible), 1,171 guests, and 40 spiders.
Topics296,863
Posts4,960,350
Members66,982
Most Online2,688
Jan 19th, 2019
2006 Duramax LBZ, 10k mi, Delvac1 CK-4 #4630123
01/10/18 08:52 AM
01/10/18 08:52 AM
Richmond, VA
DNVDMAX Offline OP
DNVDMAX  Offline OP
Richmond, VA
I've been meaning to post this for a while. Ran my tow tune during last 5,000 miles. Towed occasionally, 5k to 10k lbs.
Code:
MI/HR on Oil			10,019			5,314			15,592			10,746			21,466			13,893
MI/HR on Unit			153,066			148,361			143,047			127,455			106,671			85,205
Sample Date			12/16/17		08/05/17		05/03/17		08/10/14		01/13/14		03/05/12
Oil				Delvac1 ESP CK-4	Delvac1 ESP CK-4	M1 TDT			Rotella T5 		Rotella T6 5w-40	Rotella T6 5w-40
				5W-40			5W-40			5W-40			10w-30
Make Up Oil Added		1 qts			0 qts			0 qts			0 qts			.5 qts (Filter)		0 qts
ALUMINUM			3			3			4			4			6			6
CHROMIUM			<1			<1			2			<1			<1			1
IRON				38			23			47			49			24			34
COPPER				2			1			4			3			4			14
LEAD				2			<1			4			2			1			0
TIN				2			3			3			2			2			3
MOLYBDENUM			45			36			2			3			67			62
NICKEL				<1			<1			4			<1			<1			0
MANGANESE			Not Tested		Not Tested		Not Tested		Not Tested		Not Tested		1
SILVER				<1			<1			<1			<1			<1			0
TITANIUM			<1			<1			<1			<1			<1			0
POTASSIUM			2			2			<1			<1			<5			7
BORON				54			76			43			15			23			38
SILICON				9			7			13			11			6			8
SODIUM				11			1			8			5			10			4
CALCIUM				1262			1212			1354			2517			860			970
MAGNESIUM			961			828			990			50			1171			1258
PHOSPHORUS			1148			981			1185			1091			1070			1098
ZINC				1386			1207			1385			1254			1312			1309
BARIUM				<1			<1			<1			<1			0
SUS Viscosity @ 210F		Not Tested		Not Tested		Not Tested		Not Tested		Not Tested		77.3
cSt Viscosity @ 100C		13.2			13.3			17.0			12.7			15.0			14.84
Flashpoint in F		Not Tested		Not Tested		Not Tested		Not Tested		Not Tested		420
Fuel %				<1			<1			<1			<1			<1			<0.5
Antifreeze %			No			No			No			No			No			0.0
Water %				<0.05			<0.05			<0.05			<0.05			0.07			0.0
Soot %				0.4			0.6			1.6			0.5			0.3			0.1
TBN				8.0			8.8			7.0			6.1			7.2			8.3
06 GMC 2500HD DMAX EFILIVE M1 TDT 5w-40 FRAM Ultra
91 GMC K1500 5.7L 5w-30 Quaker State HM Bosch D+
72 Nova 350 SBC 74mm AirWerks Turbo 15w-40 HDEO
Re: 2006 Duramax LBZ, 10k mi, Delvac1 CK-4 [Re: DNVDMAX] #4630521
01/10/18 01:40 PM
01/10/18 01:40 PM
Fort Lauderdale, FL
DoubleWasp Offline
DoubleWasp  Offline
Fort Lauderdale, FL
My uneducated observation is that your iron likes to show itself since you switched to T5. Your iron doubled in half the OCI.
Has there been any other changes, such as duty cycle, filter choice, or usage since then around that time?
Re: 2006 Duramax LBZ, 10k mi, Delvac1 CK-4 [Re: DNVDMAX] #4630828
01/10/18 07:21 PM
01/10/18 07:21 PM
Regina, Saskatchewan, Canada
Garak Offline
Garak  Offline
Looks good. I see the magnesium is still there, and you had plenty reserve TBN.
Plain, simple Garak.
2008 Infiniti G37 - Shell ROTELLA T6 Multi-Vehicle 5w-30, NAPA Gold 7356
Re: 2006 Duramax LBZ, 10k mi, Delvac1 CK-4 [Re: DoubleWasp] #4631110
01/11/18 07:18 AM
01/11/18 07:18 AM
Richmond, VA
DNVDMAX Offline OP
DNVDMAX  Offline OP
Richmond, VA
No real change on the T5 run. Although she was running a tad warm on I-5 in Cali on that run pulling a cargo trailer from Georgia to Cali to Alaska. Mainly used Baldwin filters until recently I experimented with a Wix XP on the previous run and a Fram Ultra on this UOA.
Re: 2006 Duramax LBZ, 10k mi, Delvac1 CK-4 [Re: DNVDMAX] #4632127
01/12/18 05:58 AM
01/12/18 05:58 AM
Indianapolis, IN
dnewton3 Offline
dnewton3  Offline
Indianapolis, IN
Not a bad run. Within normal wear expectations. That's the good news. But, it's a Dmax; "normal" is normal - that's what we expect. What we see here is totally within "normalcy".
I realize this is your UOA in your thread, but I offer this for consideration ...
https://bobistheoilguy.com/forums/ubbthreads.php/topics/4527295#Post4527295
As you can see, I am getting slightly lower wear than you, when Fe wear-rate is averaged.
In contrast, I run dino Rotella 10w-30. All while flogging my 2006 Dmax in heavy towing this last UOA. I assure you you're not running your rig any harder than I did in my last UOA; I was running at/near max EGTs for most all the trip, fighting headwinds pulling my RV for hours on end.
Are you getting "better" results using an expensive syn?
It depends on how you define "better" ....
- You certainly are not getting less wear, that's for sure.
(your last three Mobil syn oil UOAs have given you 3ppm/1k mi, 4ppm/1k mi, 4ppm/1k mi)
(my last four Rotella dino UOAs have given me 2ppm/1k mi, 2ppm/1k mi, 2ppm/1k mi, 3ppm/1k mi)
- You certainly don't need a syn for "cold" starts in most areas.
(these are HPCR injection, with intake grid heaters and glow plugs; starting generally isn't an issue if your batteries are in good shape. My Dmax has started as low as -17F, on dino 10w-30)
You're probably spending 3x more money than I am; what is 3x "better" in your UOAs?
The Dmax engines simply don't care what is in the crankcase, as long as it's an appropriate lube. Base stocks don't matter. Vis does not matter. Brand does not matter. Your UOAs, and others, and mine, just continue to convince me that the Dmax is one of the best wearing light-duty engines made. And they don't need anything special to return excellent results. Syns have not shown any statistical advantage of wear reduction in a Dmax. The lube system design of the Dmax is what controls wear rates; not the base stock or brand of oil.
Yes- this is a challenge to you. It's not meant to be a taunt, but a friendly challenge for you to think outside the synthetic box.
The act of preventative maintenance, in and of itself, is FAR MORE important than brand/grade/base choices among lubes and filters.
- under maintaining something is akin to abuse/neglect; that can kill equipment by shortening the lifespan
- over maintaining something has never been proven to be anything but a waste of time and money
Re: 2006 Duramax LBZ, 10k mi, Delvac1 CK-4 [Re: DNVDMAX] #4632806
01/12/18 06:37 PM
01/12/18 06:37 PM
Michigan
A_Harman Offline
A_Harman  Offline
Michigan
You seem to have had a winner with the Rotella T6 when you went 21k miles and only had 24 ppm of Fe. That seems so good, maybe it was an error at the lab. I think you should do another OCI with RT6.
I'm jealous of your oil consumption. I wish my diesel was that good.
1985 Z51 Corvette track car
2002 Camaro Z28 LS1/6-speed
2001 Dodge Ram 2500 diesel
1972 GMC 1500 shortbed project truck
Re: 2006 Duramax LBZ, 10k mi, Delvac1 CK-4 [Re: DNVDMAX] #4633078
01/12/18 10:41 PM
01/12/18 10:41 PM
Richmond, VA
DNVDMAX Offline OP
DNVDMAX  Offline OP
Richmond, VA
DN3, valid statement on the lack of ROI with synthetics in my application. This is my wifes daily driver and she does jack rabbit starts in the morning, 13..0x sec 1/4 mile times on occasion, and does not let the turbo cool before shutting her down after a hard pull. I guess the synthetics just give me peace of mind so I sleep well at night. I dont think I would run synthetics if I wasnt continuously finding it on sale for $10/gal or less. I have 2.5 gals of T5 in 10w-30 and 15w-40. I will likely run one of these in my next OCI.
Re: 2006 Duramax LBZ, 10k mi, Delvac1 CK-4 [Re: DNVDMAX] #4640567
01/20/18 12:01 AM
01/20/18 12:01 AM
BC, Canada
userfriendly Offline
BC, Canada
Can someone prove that the metals found in used oil are from engine wear?
Re: 2006 Duramax LBZ, 10k mi, Delvac1 CK-4 [Re: DNVDMAX] #4640821
01/20/18 10:19 AM
01/20/18 10:19 AM
Wet side WA
JohnnyJohnson Offline
Wet side WA
userfriendly the best laugh I've had all week with my morning coffee!
2004 Corolla 128276
Out: VML 5w-30 TG4967 OCI 5007 Miles
In: EDGE EP 5W-30 Bosch 3311 122537 7-18-18
2006 Duramax 74615
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: 2006 Duramax LBZ, 10k mi, Delvac1 CK-4 [Re: DNVDMAX] #4691034
03/11/18 12:07 AM
03/11/18 12:07 AM
BC, Canada
BC, Canada
Happy daylight saving time!
Re: 2006 Duramax LBZ, 10k mi, Delvac1 CK-4 [Re: DNVDMAX] #4691036
03/11/18 12:14 AM
03/11/18 12:14 AM
BC, Canada
BC, Canada
Changing the clock make the days longer.
Re: 2006 Duramax LBZ, 10k mi, Delvac1 CK-4 [Re: DNVDMAX] #4966690
01/01/19 07:12 AM
01/01/19 07:12 AM
BC, Canada
BC, Canada
Bump!! happy new year 2019. I'm still waiting for an answer to my question.
Re: 2006 Duramax LBZ, 10k mi, Delvac1 CK-4 [Re: DNVDMAX] #4966931
01/01/19 12:34 PM
01/01/19 12:34 PM
Fort Lauderdale, FL
DoubleWasp Offline
DoubleWasp  Offline
Fort Lauderdale, FL
Better question: If not from engine wear, then what would the metal particulates in the engine oil come from?
Re: 2006 Duramax LBZ, 10k mi, Delvac1 CK-4 [Re: DNVDMAX] #4967599
01/02/19 06:47 AM
01/02/19 06:47 AM
Indianapolis, IN
dnewton3 Offline
dnewton3  Offline
Indianapolis, IN
VOAs certainly don't show high metal counts.
As DoubleWasp asks, if not from the engine, then where in the heck does one think they originate from ?????
Maybe Cu, Fe, Pb, Al, Cr and such are all floating about in the air we breathe, in nano-micron form, and they absorb through the engine block? grin2
Re: 2006 Duramax LBZ, 10k mi, Delvac1 CK-4 [Re: DNVDMAX] #4969338
01/04/19 12:48 AM
01/04/19 12:48 AM
Fort Lauderdale, FL
DoubleWasp Offline
DoubleWasp  Offline
Fort Lauderdale, FL
Maybe because I use a copper/iron/aluminum/lead oil cap and always cross-thread it when installing?
Re: 2006 Duramax LBZ, 10k mi, Delvac1 CK-4 [Re: DoubleWasp] #4969601
01/04/19 10:35 AM
01/04/19 10:35 AM
MD
claluja Offline
claluja  Offline
MD
From the fuel is possible. Not specific for this uoa, but just in general.
https://www.bobistheoilguy.com/foru...-4l-gm-marine-application-high-manganese
2014 F250 6.7L PSD
2006 Sequoia 4.7L
2005 E500 5.0L
2018 Jeep Rubicon, Pentastar 3.6L
Re: 2006 Duramax LBZ, 10k mi, Delvac1 CK-4 [Re: DNVDMAX] #4969610
01/04/19 10:48 AM
01/04/19 10:48 AM
Indianapolis, IN
dnewton3 Offline
dnewton3  Offline
Indianapolis, IN
Possible? Yes.
Probable? No.
This specific series of UOAs shows very low (typical of Dmax) Cu, Pb, Al. The Fe can track a bit with severity of use, but generally does not get altered much in the grand scheme.
I'm not sure what userfriendly was really getting at here ... shrug
Was he being generic?
Was he being facetious?
Was he being specific to this UOA?
Seems he like to bump and run.
