DIY alignment done right?
by tookien. 03/24/19 10:03 PM
Cell phone privacy question
by loneryder. 03/24/19 10:00 PM
Ride quality between 45 and 35 sidewall
by bowlofturtle. 03/24/19 09:23 PM
FRAM TG 7317 - 12K miles opened
by crazy_raccoon. 03/24/19 09:01 PM
2014-2017 Toyota Corolla CVT Quiet Recall
by StevieC. 03/24/19 08:11 PM
Finally Found Factory Ammo my 308 Bolt Gun Likes
by Fastzntn. 03/24/19 08:10 PM
Umarex Glock 19 Co2
by Sonic. 03/24/19 07:57 PM
I put in 2 1/2 qts, damage?
by JLawrence08648. 03/24/19 07:21 PM
How to dispose / recycle Li-Ion batteries?
by 92saturnsl2. 03/24/19 06:16 PM
New member of the (automotive) family!
by addyguy. 03/24/19 06:04 PM
6.2 f250 6.4 ram 2500 towing with a gasser
by FLORIDA. 03/24/19 05:55 PM
T5 15w40 for my bike?
by Degreaser. 03/24/19 05:47 PM
Studded tires in warm weather
by y_p_w. 03/24/19 05:28 PM
ST 15W40
by mobilaltima. 03/24/19 05:02 PM
I need a filter cutter person
by Marco620. 03/24/19 03:21 PM
VIRGIN BOSCH D+ 3421 CUT OPEN
by 53' Stude. 03/24/19 02:45 PM
My first cut. Donaldson P502503
by BeerCan. 03/24/19 02:25 PM
Rollo, Drifted, Jcar516, gregjr7, daveed
67613 Registered Users
79 registered members (69Torino, 4WD, AdditiveOCD, 2010Civic, 2015_PSD, 8 invisible), 1,582 guests, and 57 spiders.
Topics286,361
Posts4,907,089
Members67,613
Most Online2,967
Mar 10th, 2019
watch that oil cooler seal! neighbor 4 qts low! #4629882
01/09/18 11:48 PM
01/09/18 11:48 PM
Chicago, IL
tomcat27 Offline OP
tomcat27  Offline OP
Chicago, IL
Nissan 3.5; neighbor complained that the check engine light was on. P0011. timing off on bank 1. hmmmm. pulled dipstick. 4 quarts low!!!
It was an easy repair: replace the o ring between the oil cooler and the block. supposedly book time is 1.2 hours. didn't take half that.
2019 Cherokee, 2018 Jetta, 2014 Sentra, 1995 Escort, 1970 Cougar, 2013 XT250, 2010 Vstar, 2014 CTX1300
Re: watch that oil cooler seal! neighbor 4 qts low! [Re: tomcat27] #4629905
01/10/18 12:31 AM
01/10/18 12:31 AM
Texas (south)
FermeLaPorte Offline
Texas (south)
That was a close one for your neighbor
Always Mobil 1
2014 1.6L Nissan Versa Sedan, 5 spd, 5k OCI.
2011 3.5L Chevrolet Impala, Automatic, 5k OCI.
Re: watch that oil cooler seal! neighbor 4 qts low! [Re: tomcat27] #4629936
01/10/18 02:18 AM
01/10/18 02:18 AM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
Watch that dipstick might be more generally applicable advice, assuming you have got one.
Re: watch that oil cooler seal! neighbor 4 qts low! [Re: tomcat27] #4629989
01/10/18 06:59 AM
01/10/18 06:59 AM
Central Florida
Mr Nice Offline
Mr Nice  Offline
Central Florida
Are the piston rings shot ?
Re: watch that oil cooler seal! neighbor 4 qts low! [Re: tomcat27] #4630032
01/10/18 08:13 AM
01/10/18 08:13 AM
Central NY
Miller88 Offline
Miller88  Offline
Central NY
My replacement 5.4 is permanently noisey from that happening. Oil cooler went bad and it dumped 6 quarts of oil into both the coolant and out of the cooler itself while driving. Never had the oil light come on, but it was realllll low.
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: watch that oil cooler seal! neighbor 4 qts low! [Re: tomcat27] #4630083
01/10/18 09:12 AM
01/10/18 09:12 AM
Hudson, NH
LeakySeals Offline
LeakySeals  Offline
Hudson, NH
I acquired a free 03 Maxima with a 3.5L with the infamous busted radiator/tie bar support. When I got it the 3.5 was dangerously low on oil. I added 3.5 qts! There are a couple of leaks. One is the cam sensor o ring. Another is from the pan area. I assumed its the drain bolt washer. Could that possibly the o ring you describe??
06 Escalade 6.0L LQ9 AWD 165k M1 0w40
03 Maxima 3.5L POS 162k ST HM 10w30
05 Malibu Classic 108k Unk
Re: watch that oil cooler seal! neighbor 4 qts low! [Re: LeakySeals] #4630232
01/10/18 11:05 AM
01/10/18 11:05 AM
Utah, USA
28oz Offline
28oz  Offline
Utah, USA
The O-ring is behind the "oil cooler"......the round thingy that the oil filter screws onto. You remove the filter, then there's a big nut behind it (if memory serves correctly). The housing (oil cooler) is then able to move away from the block. There is a big O-ring behind it where it mates to the block. They tend to start leaking above 100k miles. Get the replacement from the dealer. They've been redesigned over the years and I think I only paid about $8 for it.
Edit: There are two rubber hoses that connect to the oil cooler. They contain coolant. Be careful with them..........unless you're replacing them also. Mine were oil saturated from the leaking O-ring, so I replaced mine.
1990 Nissan 300zx VG30DE - PP Euro 0W-40
2004 Nissan Quest VQ35DE - PP Euro 0W-40
2003 Ford Excursion 7.3 PSD - Rotella T6 5W-40
2005 Ford Taurus 3.0 Vulcan - Havoline HM 5W-20
