POE
by WyrTwister. 12/12/18 09:44 AM
Any Volvo Owners, need some help!
by LazyDog. 12/12/18 09:34 AM
NOACK & Sheer
by WyrTwister. 12/12/18 09:34 AM
Rotary help. 2010 series 2 RX8
by TinyVoices. 12/12/18 08:32 AM
Can you mathematically estimate top speed?
by KCJeep. 12/12/18 08:06 AM
2019 GM 6.2 AFM
by XL1200RFan. 12/12/18 07:32 AM
Dodge Challenger R/T Tips and Tricks?
by LoneRanger. 12/12/18 06:02 AM
MIL vehicle suggestion $8000
by madRiver. 12/12/18 06:00 AM
Toyota 2TR-FE 2.7 questions
by Doublehaul. 12/12/18 12:32 AM
Anybody used Eurolub?
by FordCapriDriver. 12/12/18 12:18 AM
Micro-Green Cut Open
by David1. 12/11/18 11:45 PM
Witch way does this valve work?
by Dylan1303. 12/11/18 11:42 PM
Santa came early..
by leoblack9. 12/11/18 11:22 PM
dropped a zip tie in my prius trans
by eljefino. 12/11/18 09:54 PM
2 Cello's - Some talented fellows right here.
by StevieC. 12/11/18 09:49 PM
Something different for sure - Punjabi Celtic
by StevieC. 12/11/18 09:40 PM
Honda eu200i hiccuping @ low idle - fixed
by Jmoney7269. 12/11/18 09:34 PM
Your dealer is here - Humor
by StevieC. 12/11/18 08:46 PM
tedonom, 01ws666, ariefnrst, tcoffin014, Schm1d
66657 Registered Users
109 registered members (aquariuscsm, 28oz, andyd, AnonOIl, anndel, 2018matto, 14 invisible), 1,860 guests, and 34 spiders.
Topics294,975
Posts4,925,199
Members66,657
Most Online2,553
Oct 27th, 2018
Home Heating Oil #4629838
01/09/18 09:35 PM
01/09/18 09:35 PM
Northeast
Finz Offline OP
Finz  Offline OP
Northeast
Can home heating oil freeze or gel?
My nephew arrived at our family place near Cambridge, VT this evening to no heat or water
We drain the plumbing when we leave as well as close all heating vents. Thereís a thermostat in basement Which holds heat to mid to high 40ís to prevent pipes in basement from freezing.
Been doing this since the seventies
Nephew arrives and the basement is below freezing. Of course water wonít turn on (good at this point)
Iím told: ď... furnace kicks on. Makes a loud strange noise, then stops. Does this very few minutesĒ
My question being 300 miles away: could the heating oil have gelled? Could that possibly be why the furnace is cycling?
God Bless America
Re: Home Heating Oil [Re: Finz] #4629846
01/09/18 09:52 PM
01/09/18 09:52 PM
MI
doitmyself Offline
doitmyself  Offline
MI
If they do not have diy diagnostic skills, you will probably have to call someone in. I.E., they could loosen the fuel line at the furnace and see it there is flow. Its been decades since I used fuel oil heat, but since it is a form of diesel fuel( No. 2 fuel oil), I would say that yes, it is possible for it to have gelled if it is located outdoors. Usually, the fuel is treated for this, but who knows. It could be a bit of water in the line or filter that has froze. Maybe a clogged filter? Maybe a bad igniter, sensor, or nozzle on the furnace?
Good luck!
Re: Home Heating Oil [Re: Finz] #4629849
01/09/18 09:54 PM
01/09/18 09:54 PM
New England
madRiver Online content
madRiver  Online Content
New England
Home heating gets gelled or Clouded. I am guessing the boiler failed though if you maintain 40F as that is too warm for gel/clouding to happen.
Good luck. Really hard time to find service as they overwhelmed for obvious reasons.
Re: Home Heating Oil [Re: Finz] #4629851
01/09/18 09:55 PM
01/09/18 09:55 PM
NJ
irad Offline
irad  Offline
NJ
Gels at 15-20 degrees F. It clogs filters and the inside of fuel lines. Add kerosene to lower the gel point.
Re: Home Heating Oil [Re: Finz] #4629858
01/09/18 10:17 PM
01/09/18 10:17 PM
Marshfield , MA
andyd Online content
andyd  Online Content
Marshfield , MA
Fuel oil gels about 0F. Plain old 2.93 $ a gallon road diesel didn't look too clear as I decanted 14 gallons all told into my near empty outside oil tank. I ran out over Sat night. Froze is probably more accurate. The heat tape I installed 5 yrs ago failed. I shut a few valves and open a few connections The line is 7/16 copper tubing, about a 6' run to the filter which has a shut off/ heat gizmo left handed valve. Tank outlet has one too, plus a ball valve. I was getting no flo, so I got more diesel. I only have a 5 gall and a 2 gallon jugs. No joy. Got out the heat gun heated the out side of the run and the tank. I opened the valve, no flow. I blew through the tube. At first resistance, then bubbles.I tilted the tube down into a vessel and it flowed. I ran out, shut off the the flow. I reconnected the line and bled the filter. The burner took a few primes to catch. after I bled the pump until fuel flowed.
what your nephew needs is to get some diesel anti -gel either from a plumbing supply or an auto parts store. The heat gun I used is a glorified hair dryer. I used some clear tubing and a gallon jug to catch oil as I played with stuff. Please report back TIA
Thick oil is better grin2
Re: Home Heating Oil [Re: irad] #4629861
01/09/18 10:20 PM
01/09/18 10:20 PM
Northeast
Finz Offline OP
Finz  Offline OP
Northeast
Thanks all...
His diy skills are... maturing shall we say. Tool selection up there isnít horrible but you have to improvise
He found a heating guy who should be there within an hour... NJ rates? 2nd mortgage. Up there in VT? Not a clue but will be worth every penny (within reason) if they can get the place heating up.
Round II: Water tomorrow
Off topic but this is among the reasons I have my kids place a cheap backpack in their cars with a wool cap, gloves, emergency blankets, heavy socks, matches,... Jeremiah Johnson stuff.
Takes up so little room and, if itís always there, you know right where to look
Thanks again
God Bless America
Re: Home Heating Oil [Re: andyd] #4629864
01/09/18 10:24 PM
01/09/18 10:24 PM
Northeast
Finz Offline OP
Finz  Offline OP
Northeast
Thanks Andy... good stuff. Iím copying/texting this to myself as a note just in case
God Bless America
Re: Home Heating Oil [Re: Finz] #4629883
01/09/18 10:50 PM
01/09/18 10:50 PM
Marshfield , MA
Marshfield , MA
Survival cold weather clothes kit is a great Idea. I would add D handle coal shovel for ice and snow removal. Plumber will have heat faster than I can type this. Best choice. I got up to an angry wife and 45F house. Couldn't think straight, due to cold. Fog cleared fast at 7F Make sure the thermostat is calling for heat too. grin2
Re: Home Heating Oil [Re: Finz] #4629913
01/09/18 11:45 PM
01/09/18 11:45 PM
MA
Wolf359 Offline
Wolf359  Offline
MA
Is there a condensate pump for the furnace? Just happened to someone I know, it pumps water out and it was too cold in the basement, so the sewer lines clogged.
When temps have been below freezing for so long, there's lots of frozen pipes out there and plumbers tend to recommend setting the thermostat to 70.
Sounds like it's just time to warm up the basement with some electric heaters.
Re: Home Heating Oil [Re: Wolf359] #4629997
01/10/18 06:09 AM
01/10/18 06:09 AM
New York
georgemiller Offline
New York
Started putting this in my tanks and haven't had any freeze ups.
FPPF Hot 4-In-1 Heating Oil Treatment
Re: Home Heating Oil [Re: Finz] #4630038
01/10/18 07:21 AM
01/10/18 07:21 AM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
Most houses have oil tanks in basement which is typically above freezing. Or underground which is probably also above freezing.
Some, mostly trailers have outside oil tanks and need a blend. Many outdoor oil tanks hold kerosene for trailer heaters.
2015 Ford F250 w/Powerstroke
Re: Home Heating Oil [Re: Finz] #4630053
01/10/18 07:38 AM
01/10/18 07:38 AM
Indianapolis, IN
dnewton3 Offline
dnewton3  Offline
Indianapolis, IN
Home heating oil is just the cheap version of diesel fuel; HHO does not have the added lubricity and detergents necessary for fuel injection systems. Other than that (and no on-road taxes, dye, etc) it's pretty much the same.
Therefore, it's susceptable to the same concerns. Most notably:
1) gel point (aka cloud point, CPP, etc)
2) contamination
As for concern #1, if your tank is stored in an area that gets below 40F, and/or has a line that goes in such an area, you need to use an anti-gel agent. There is a difference between the wax cloud and ice crystals. Depending upon raw fuel used, wax can start to harden as early as 40F, whereas ice crystals can form at 32F. Both need separate treatment plans.
As for concern #2, filtration can help, but also poses issues, because HHO and diesel fuel LOVES to entrain moisture in the fuel. That often encourages folks to use a demulsifier (agent that causes moisture to fall out of suspension). Problem with that is that the water can collect in certain areas, and then micro-organisms can grow; you get bacterial growth that looks very much like "snot" (mucus). This can coat surfaces of filters and clog up lines. So often an anti-microbial agent is also necessary.
If the fuel is not flowing freely, you must ascertain WHY it's not flowing, and discover the root cause, or the wrong treatment might not affect your concern.
I recommend treating the fuel with an anti-microbial at all times; use with every tank fill-up. If you have moisture and/or wax and ice concerns, treat for that too, as needed.
The act of preventative maintenance, in and of itself, is FAR MORE important than brand/grade/base choices among lubes and filters.
- under maintaining something is akin to abuse/neglect; that can kill equipment by shortening the lifespan
- over maintaining something has never been proven to be anything but a waste of time and money
Re: Home Heating Oil [Re: Finz] #4630111
01/10/18 08:41 AM
01/10/18 08:41 AM
Owego, New York
Gillsy Offline
Gillsy  Offline
Owego, New York
Yes it can gel if it gets cold enough. Many outside tanks get a fuel oil/kerosene blend to prevent gelling. Call your fuel oil supplier, and have them add (or you add)the proper mixture. I think locally they use a 50/50blend. Can you get a portable electric heater to warm the basement? Good luck!
Many are the afflictions of a righteous man
2018 F150 Supercab 2.7 Ecoboost 4x4
400 lbs/ft of grin at 2750 RPM
2016 Kawasaki 650 Versys LT
Re: Home Heating Oil [Re: Finz] #4630168
01/10/18 09:22 AM
01/10/18 09:22 AM
Illinois
SHOZ Offline
SHOZ  Offline
Illinois
The pump will have a bleeder screw on it to check for flow. I also have a schrader valve installed just inside the house where the line comes in. Using a shut of valve between it and the pump I can blow air back into the tank to open that line or mix the fuel in the tank.
2008 Hyundai Accent 1.6L 5 sp manual hatchback
2010 Hyundai Genesis Coupe Track 2L Turbo 6sp manual
Re: Home Heating Oil [Re: SHOZ] #4630934
01/10/18 09:28 PM
01/10/18 09:28 PM
Northeast
Finz Offline OP
Finz  Offline OP
Northeast
Many thanks everyone... they were able to get a heating guy in who, last I heard, determined that the furnace blower was on the fritz... explains the odd noises they were hearing.
Was supposed to have been replaced this evening but I havenít gotten any updates
Really great input from you all...
Thanks again...!
God Bless America
