Phillips 66 Shield Choice $1.99 @ Orscheln
by Pat in Speedway. 03/18/19 12:41 PM
Barely there back seats
by y_p_w. 03/18/19 11:47 AM
should i be afraid of the DCT ?
by WhyMe. 03/18/19 11:28 AM
Friction modifiers
by Truckedup. 03/18/19 10:57 AM
Sometimes, choices are made for you!
by addyguy. 03/18/19 10:30 AM
I Hope This Amuses You Guys Like It Did Me
by NYEngineer. 03/18/19 10:27 AM
New Exmark Lazer Z / Oil ?
by johnD2. 03/18/19 10:13 AM
First welder recommendation
by Astro14. 03/18/19 09:55 AM
Amsoil Burning
by ridgerunner. 03/18/19 09:38 AM
2007 Sonata Pinging + DTCs
by F24Sonata. 03/18/19 09:31 AM
Nissan Maxima 2009 synthetic oil choices
by mahanddeem. 03/18/19 09:23 AM
Best coated rotors
by JMHC. 03/18/19 09:11 AM
Brake Bleeder Question
by maverickfhs. 03/18/19 08:57 AM
Ring alarm system, any good?
by Redright9. 03/18/19 08:18 AM
4 oil changes Saturday.
by ls1mike. 03/18/19 08:08 AM
Careers.....Boomers vs Millennias
by ZZman. 03/18/19 08:05 AM
Need Expert TIG Welder, Toronto Area
by George7941. 03/18/19 01:44 AM
Cadillac CT5 Revealed
by E365. 03/18/19 01:36 AM
toplscuda, swrve, TomRx, Ozdave, Rod1701
67547 Registered Users
111 registered members (928, 2009Edge, 97f150, 2015_PSD, 12 invisible), 2,302 guests, and 61 spiders.
Topics286,014
Posts4,900,744
Members67,547
Most Online2,967
Mar 10th, 2019
Squeaky belts after extreme cold, salt, and a wash #4629735
01/09/18 08:56 PM
01/09/18 08:56 PM
Illinois
mrsilv04 Offline OP
mrsilv04  Offline OP
Illinois
We just emerged from two weeks in the deep freeze. Lots of salt on the roads.
I celebrated finally getting above freezing with a touchless car wash with an undercarriage spray.
Now... my belts squeak like heck. It started with the undercarriage wash.
I assume they got wet and were drenched with a salty blast. And now they squeak.
Do I wash them with hot water? Soapy water? What now?
The belts are only a few years old, and are GM OE replacements on a 2004 Silverado.
I suspect that it is likely the A/C belt, as it is low on the engine, just above the front axle.
2004 Silverado - on its 3rd Jasper engine in less than one year.
Re: Squeaky belts after extreme cold, salt, and a wash [Re: mrsilv04] #4629740
01/09/18 08:59 PM
01/09/18 08:59 PM
MTL, CANADA
Rolla07 Offline
Rolla07  Offline
MTL, CANADA
Leave it alone, the noise should go away on its own, unless you are in need of a new belt.
2007 Corolla Red Pearl 155k miles
PP 0w20 & ST 4967
Re: Squeaky belts after extreme cold, salt, and a wash [Re: mrsilv04] #4629816
01/09/18 10:16 PM
01/09/18 10:16 PM
NY
DdDd Offline
DdDd  Offline
NY
Hose down the engine bay. Might want to spray some mild cleaner on the belts directly, dish soap will cut any oils. Hose off and run the engine till everything is nice and dry.
You probably got oily residue from the wash water or your engine compartment.
Re: Squeaky belts after extreme cold, salt, and a wash [Re: mrsilv04] #4629917
01/10/18 12:50 AM
01/10/18 12:50 AM
WI
HoosierJeeper Offline
WI
x2. Clean it and then run it till it drys. Shouldn't chirp for more than a few seconds after washing it. My vehicles chirp for a second or two if the belt gets real soaked during a wash.
15 Jeep KL Limited V6: Formula Shell 5W20
07 LR3 SE V8: Maxlife 5W30
05 Jeep KJ Limited: PHM 5W30
96 Jeep XJ Country: STP HM 5W30 (winter)
Re: Squeaky belts after extreme cold, salt, and a wash [Re: mrsilv04] #4629980
01/10/18 06:22 AM
01/10/18 06:22 AM
Wisconsin
Black_Thunder Offline
Wisconsin
sometimes rust debris etc gets wedged in the ribs of the belt causing it to slip and make noise and if you are careful and i mean CAREFUL you can use a wire brush and scrape the ribs while the engine is running by just holding the brush against the inside of the belt while the engine rotates and it'll clean out in a few moments. but obviously do at your own risk, that is if there is room to do so.
I'd buy Callahan autoparts if I could.
Re: Squeaky belts after extreme cold, salt, and a wash [Re: mrsilv04] #4630064
01/10/18 08:55 AM
01/10/18 08:55 AM
Hudson, NH
LeakySeals Offline
LeakySeals  Offline
Hudson, NH
This may be seen as controversial, but I spray my belts with the same thing as my tires. Meguires tire shine. Start it, point, mist.. Squeaks gone in a second.
06 Escalade 6.0L LQ9 AWD 165k M1 0w40
03 Maxima 3.5L POS 162k ST HM 10w30
05 Malibu Classic 108k Unk
Re: Squeaky belts after extreme cold, salt, and a wash [Re: LeakySeals] #4630119
01/10/18 09:48 AM
01/10/18 09:48 AM
Florida
SilverSnake Offline
SilverSnake  Offline
Florida
Not sure why you or anyone else would use tire shine on your engine belts when there are a number of excellent commercial belt dressings available. Here is one of them:
http://www.antiseize.com/BELT-DRESSING
2016 Charger, 6.4L-485 HP (PUP 0W-40)
2017 BMW 330i, 2L-248 HP (BMW 0W-20)
2018 Jeep GC, 5.7L-360 HP (PUP 5W-20)
2008 20KW Generac (Amsoil 10W-30/30)
