My VW Service Experience
by Delta. 12/18/18 11:36 AM
Nissan high idle, P0507
by LeakySeals. 12/18/18 11:23 AM
Should i go for even thinner fluid ?
by NICAT. 12/18/18 11:06 AM
Viscosity question
by dbierman. 12/18/18 10:50 AM
48 hours and a used car
by Imp4. 12/18/18 09:32 AM
Test driving PHEV w no battery charge
by RichardS. 12/18/18 09:02 AM
2005 Ford PSD with hard shifts when cold?
by racin4ds. 12/18/18 08:08 AM
18% off Ravenol + EVERYTHING @ Blauparts.com
by CleverUserName. 12/18/18 07:48 AM
Mattress shopping .....
by dblshock. 12/18/18 04:57 AM
AmazonBasics Oil May Drive Prices Down
by knerml. 12/18/18 04:45 AM
Hemi MDS issues are how common?
by Gasbuggy. 12/18/18 03:21 AM
Why use Redline and Redline Clone oils...
by burla. 12/17/18 11:38 PM
Tire choice
by CincyReds. 12/17/18 11:14 PM
Transmission fluid leak
by dawgn86. 12/17/18 07:53 PM
QuickJack BL-5000SLX and my Optima...
by WhizkidTN. 12/17/18 07:23 PM
Champion Air Filter Opinions?
by JerryBob. 12/17/18 06:18 PM
Tundra transfer case plug torque (Borg Warner)
by Idlewild294. 12/17/18 06:03 PM
MuhThugga, wxo, dbierman, keyblade, leeal
66716 Registered Users
100 registered members (28oz, anndel, 66Monza, 69Torino, 2K2AcuraTL, 9 invisible), 1,987 guests, and 41 spiders.
Topics295,218
Posts4,930,216
Members66,716
Most Online2,553
Oct 27th, 2018
2006 buick lacrosse 3.8l #4629499
01/09/18 04:50 PM
01/09/18 04:50 PM
Washington
Dylan1303 Offline OP
Washington
Grandparents buick just hit 75k. Im the one that maintenances the car. What should i do for the 75k? Plugs, wires, belt inspection, tranny drain fill, anything else? Has oem plugs and wires. I already did a comple tranny fluid flush/ change at 50k at work. Anything im missing for 75k. Just did new douglas all seasons in december with a alignment.
12 cruze rs 1.4t 6spd pp 5w30 tuned on 22psi
13 equinox 2.4 awd pp 5w30
Re: 2006 buick lacrosse 3.8l [Re: Dylan1303] #4629506
01/09/18 04:56 PM
01/09/18 04:56 PM
Pittsburgh PA USA
Milkman Offline
Milkman  Offline
Pittsburgh PA USA
Unless there is a problem, the plugs should be good to 100K. Check the belt carefully. The hoses should be good indefinatly. GM used quality hoses.
2018 Dodge Charger R/T 5.7 Hemi (Mine)
2010 Chevrolet Malibu LT (Hers)
Good cars...
Re: 2006 buick lacrosse 3.8l [Re: Dylan1303] #4629507
01/09/18 04:57 PM
01/09/18 04:57 PM
AZ
FFFEMT Offline
FFFEMT  Offline
AZ
Brake fluid change, and timing belt and related items.
Re: 2006 buick lacrosse 3.8l [Re: Dylan1303] #4629514
01/09/18 05:02 PM
01/09/18 05:02 PM
Michigan
ZZman Offline
ZZman  Offline
Michigan
Serpentine belt, struts, ps full, brake flush
2003 Mercury Grand Marquis. PP HM 5w-30 and Fram Ultra
2008 Sebring Hardtop convertible. PP HM 5w-30 and Fram Ultra
2006 Kawasaki Vulcan 900 LT. Motul 7100 10w-40 and K&N
Re: 2006 buick lacrosse 3.8l [Re: FFFEMT] #4629518
01/09/18 05:04 PM
01/09/18 05:04 PM
OH
SatinSilver Offline
SatinSilver  Offline
OH
Brake fluid, coolant drain and fill, ATF d&f, PS fluid, clean and lube battery terminals, clean and lube brake calipers, wipers
New air and cabin filters
Re: 2006 buick lacrosse 3.8l [Re: Dylan1303] #4629570
01/09/18 06:01 PM
01/09/18 06:01 PM
Phoenix, AZ
Nick1994 Offline
Nick1994  Offline
Phoenix, AZ
Do the coolant with new Dexcool.
Have the intake manifold gaskets been done yet?
2015 Hyundai Sonata 2.4L 89k Motorcraft Synthetic Blend 5w30 & OEM
2000 Toyota Camry 2.2L 231k Valvoline 5w30 & Fram Ultra
1996 Jeep Cherokee 4.0L 147k Mobil 1 HM 10w40 & Fram Ultra
Re: 2006 buick lacrosse 3.8l [Re: Dylan1303] #4629582
01/09/18 06:12 PM
01/09/18 06:12 PM
Virginia
Hemispheres Offline
Hemispheres  Offline
Virginia
Coolant flush. Do it at the dealer or you'll never get all the old stuff out. Intake gaskets don't need to be changed on the newer 3.8's. Aluminum upper intake manifold along with the steel crush gaskets on the lower intake.
Honestly if it's only got 75k on it I'd go ahead an run CRC 5 minute engine flush to remove any sludge. Make sure the engine is operating temp before adding it, lowers the chance of dislodging a giant glob of sludge. Other than that the trans is decent, I'd drop it anyways to replace the filter, replaced with 7.2 qts of Dex VI and call it done.
Plugs and wires should be good. Changed mine at 98k just because of manufacturer recommendations and didn'd notice any increase in mileage, engine ran just the same too.
2009 Buick LaCrosse (3800 Series III) - 137,000 miles.
PZ Plat HM/Mobil 1 HM
Bosch/Purolator/Mobil filters
Re: 2006 buick lacrosse 3.8l [Re: Dylan1303] #4629590
01/09/18 06:18 PM
01/09/18 06:18 PM
Washington
Washington
Sounds like just brake, ps, and coolant. Will check the cabin air also. Air filter was done about 2 oil changes ago so its fine. I have them do quaker state con with ac delco oil filter at walmart. Every 3-4k they live 30 miles from town so it doesnt really get short tripped.
Re: 2006 buick lacrosse 3.8l [Re: Dylan1303] #4629642
01/09/18 06:53 PM
01/09/18 06:53 PM
Minnesota
bmod305 Offline
bmod305  Offline
Minnesota
Coolant elbows!!! PCV
Re: 2006 buick lacrosse 3.8l [Re: Dylan1303] #4629709
01/09/18 07:34 PM
01/09/18 07:34 PM
Campbellsville, KY
Alex_V Offline
Alex_V  Offline
Campbellsville, KY
Coolant flush if it looks like it could use it. Bleed the brakes and flush out the old fluid. Maybe check/clean the throttle body. Inspect belts and hoses but they do last quite a while so no need to shotgun all that, or the ignition stuff. (FYI when the time - 100K - comes for plugs, I've burned up a set of Delco coppers in ~1000 miles but Delco iridiums run very well.) Don't worry about the transmission until 100K, either. PS flush is optional but not a bad idea.
To quote a friend, "Synthetics, man."
'85 GMC C3500, 454, 132K
'82 Mercedes 300CD, OM617 turbo, 173K (totaled 2018, in rehab)
'85 Mercedes 300TD, OM617 turbo, 217K (wife's)
'67 Suburban, 350, 331K
Re: 2006 buick lacrosse 3.8l [Re: Alex_V] #4629725
01/09/18 07:43 PM
01/09/18 07:43 PM
North Carolina
Egg_Head Offline
Egg_Head  Offline
North Carolina
Cabin filter. When you replace the plugs buy new wires b/c you'll screw them up getting them off the OE plugs.
1979 Garelli Rally Sport
2009 Cub Cadet LT1042
2002 BMW 540 M Sport (totaled)
2011 MB E350 4Matic wagon
1979 CJ-7
Re: 2006 buick lacrosse 3.8l [Re: Dylan1303] #4629792
01/09/18 08:44 PM
01/09/18 08:44 PM
Pittsburgh,PA U.S.A.
JimPghPA Offline
JimPghPA  Offline
The main drive pulley for the serpentine belt is a combination pulley and harmonic balancer. They go bad around 75K to 85K miles. There is a black rubber piece between the inner pulley and the outer drive pulley. That black rubber breaks down with age and the outer pulley becomes un-aligned and that causes the serpentine belt to fall off of the drive pulley. When that happens the vehicle looses power-steering, alternator, and water-pump. Even if the person driving it has the mussel to man-handle the steering-wheel without the assist of the power, the engine will quickly over-heat without the water-pump working. And if someone does put a new serpentine belt on it will quickly fall off, until a new balancer/pulley is put on.
Note, to access the balance/pulley remove the front wheel and the wheel-well.
Also to flush the power-steering fluid with new fluid, get some type of siphon and two large bottles of power-steering fluid, and a container to put used fluid into.
Siphon out the power-steering fluid, replace with new fluid, start the engine and turn the steering wheel all the way to one side, and then all the way to the other side and then back to center, shut off the engine, and repeat until you use up all of the two big bottles of fluid.
Boy will I be happy when ALL vehicles on public roads are autonomous.
JimPghPa
Re: 2006 buick lacrosse 3.8l [Re: JimPghPA] #4629920
01/10/18 12:03 AM
01/10/18 12:03 AM
Virginia
Hemispheres Offline
Hemispheres  Offline
Virginia
Yeah mine went bad at around 100k miles. They actually have a plastic access panel to get to the balancer, you don't have to pull the wheel well as you can swivel the access panel out of the way. Given the pain in the [censored] it is to get everything lined up and pull the balancer without damaging the CPS sensor (don't screw the puller bolts all the way in or the magnetic pull will screw up the sensor and cause a no start condition)I'd wait until it went bad to replace. My 3800 saw a lot of high RPM operation between 75k and the failure of the balancer which most likely contributed to it falling apart. I still drove it 60 miles back home without it damaging anything. Made a god awful racket tho. I remember sitting at a drive thru and hearing the bang bang bang of the balancer and thinking that couldn't be me. Moved the gear selector around and I was like oh [censored] my car is DONE!
Re: 2006 buick lacrosse 3.8l [Re: Dylan1303] #4629978
01/10/18 05:18 AM
01/10/18 05:18 AM
SLC, UT
GON Offline
GON  Offline
SLC, UT
The GM 3.8L is a awesome engine. Very good on fuel economy, super reliable, can easy go 300k with just oil changes, spark plugs, and plug wires. A coil may go occasionally but super easy to replace.
Only issue(s) with the engine are intake manifold gaskets and coolant elbows.
Re: 2006 buick lacrosse 3.8l [Re: Dylan1303] #4630093
01/10/18 08:18 AM
01/10/18 08:18 AM
USA
mk378 Offline
mk378  Offline
USA
The series III engine has a metal upper intake and upgraded gaskets that are generally trouble free. You should pre-emptively replace the elbows when changing the coolant though.
