This is the 5 speed we swapped into the old white van. Previous owner says it shifted fine when he took it out. It feels like it goes in 2nd but, as soon as you let up on the clutch (like the slightest bit), it jumps out. No grinding, it just comes out of gear. I'm not sure it even goes in at all. If you fiddle with the shifter enough, it will go in and stay (usually).
Sound more like a shifter problem or a problem with the tranny? Goes into every other gear just fine.
