Funny pictures thread
by JLTD. 09/24/18 08:40 PM
Redline 15w40: Low or Mid Saps?
by SavagePatch. 09/24/18 06:59 PM
What are these cables to?
by 99Eclipse. 09/24/18 06:44 PM
Help with parasitic draw?
by buck91. 09/24/18 05:57 PM
Costco Car Buying Program
by dkryan. 09/24/18 05:39 PM
Glass Scrub?
by buck91. 09/24/18 05:03 PM
Loosing coolant from somewhere
by NICAT. 09/24/18 03:47 PM
2010 or so Ford Fusion Sport thoughts?
by ZZman. 09/24/18 03:35 PM
My boss killed his jeep.
by Chris142. 09/24/18 02:40 PM
Moly question about walmart oils
by jayjr1105. 09/24/18 02:33 PM
Questions About 9011 Bulbs
by knerml. 09/24/18 02:23 PM
Lubricant Additives - A Practical Guide
by wemay. 09/24/18 01:39 PM
Fram Ultra--Any Real Competition?
by IndyFan. 09/24/18 12:59 PM
Used generator price.
by Eddie. 09/24/18 11:55 AM
fortim, albert001, LG_Electronics, TCam, OzFrog
66063 Registered Users
90 registered members (antonmnster, aquariuscsm, 1.8Tango, Astro14, 2004tdigls, AP9, 12 invisible), 1,159 guests, and 39 spiders.
Topics290,961
Posts4,853,390
Members66,063
Most Online3,590
Jan 24th, 2017
13mm 6 point wrench #4629367
01/09/18 03:46 PM
01/09/18 03:46 PM
Texas
WyrTwister Offline OP
Texas
We bought a 2006 Buick Lacrosse CX 3.8l with 37,000 - 38,000 miles , this last June . The dealer had the oil changed before we took delivery .
Does not appear to require Dexos oil . 3000 miles later , went to change the oil / filter , this last weekend . Took a while to locate the filter & how to get to it to remove & replace it . Then the drain plug came next .
Turns out it is 13mm . Took my 13mm 12 point combination wrench . VERY TIGHT ! Short version , ended up using my largest vice grips to loosen & remove the drain plug ( after which the hex head was pretty messed up ) .
Tried to find a 13mm 6 point wrench this last weekend . Found one , today , at Sears . Craftsman , made in China . Let us hope for the best .
Wyr
God bless
Re: 13mm 6 point wrench [Re: WyrTwister] #4629375
01/09/18 03:56 PM
01/09/18 03:56 PM
WI
HoosierJeeper Offline
WI
It'll probably work fine.
15 Jeep KL Limited V6: Formula Shell 5W20
07 LR3 SE V8: Maxlife 5W30
05 Jeep KJ Limited: PHM 5W30
96 Jeep XJ Country: STP HM 5W30 (winter)
Re: 13mm 6 point wrench [Re: WyrTwister] #4629384
01/09/18 04:05 PM
01/09/18 04:05 PM
Texas
Texas
Hope so . I replaced the messed up drain plug with a new one from O'Reilly . Will find out in 3000 miles .
Put Mobil dino oil in it . Bought a NAPA Silver filter which I will use next time .
Thanks , :-)
Wyr
God bless
Re: 13mm 6 point wrench [Re: WyrTwister] #4629393
01/09/18 04:11 PM
01/09/18 04:11 PM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
Easier to find a 13mm 6pt socket for your ratchet.
02 Wrangler durablend 10w40
87 F250 traveler 15w40
04 Tahoe super-s 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: 13mm 6 point wrench [Re: WyrTwister] #4629396
01/09/18 04:18 PM
01/09/18 04:18 PM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
I bet if you ground off the moved metal on the points the 12 pt would fit. If you rounded of the hex, then the plug was too tight. 1/4 turn past snug works with drain plugs, oil filters, and plugs
Thick oil is better grin2
Re: 13mm 6 point wrench [Re: WyrTwister] #4629428
01/09/18 04:54 PM
01/09/18 04:54 PM
South Florida
bubbatime Offline
bubbatime  Offline
South Florida
I'll give you a protip. NEVER, ever use a 12 point, unless there is a real compelling reason to do so. Amazingly, since I have done away with 12 points, I have never rounded off a nut in years. Like 10 plus years. Using a 6 point most of the time is the way to go.
Combination wrenches should not be near an oil change, in my opinion. I have used for years a 3/8 ratchet that extends to like 14 inches for extra leverage on those really tight plugs.
17 Chrysler Pacifica Mobil 1 5W30
13 Yamaha XT250 Valv MC 10W40
12 Suzuki S40 Rotella 15W40
10 Acura TSX 2.4 PZL Plat 5W30
06 GMC Sierra Nextgen 10W30
Re: 13mm 6 point wrench [Re: WyrTwister] #4629443
01/09/18 05:05 PM
01/09/18 05:05 PM
San Antonio, TX
das_peikko Offline
das_peikko  Offline
San Antonio, TX
I would have used my XBM1315A and it would have very easily removed that dealership tightened plug.
Re: 13mm 6 point wrench [Re: WyrTwister] #4629472
01/09/18 05:26 PM
01/09/18 05:26 PM
ME
eljefino Offline
eljefino  Offline
ME
Could always weld a socket to the (original) drain plug.
Re: 13mm 6 point wrench [Re: WyrTwister] #4631299
01/11/18 11:39 AM
01/11/18 11:39 AM
Connecticut, USA
bmwpowere36m3 Offline
Connecticut, USA
6-pt vs. 12-pt isn't the issue... what you want is off-corner engagement which goes by many names: Snap-On Flank Drive, Wright Grip, SK SureGrip, etc.
Most sockets, box-ends and some open-ends are manufactured this way nowadays. They'll seem a bit "loose" on the fastener and the idea is not to engage the corners of fasteners which leads to rounding/stripping.
Re: 13mm 6 point wrench [Re: bubbatime] #4632089
01/12/18 04:45 AM
01/12/18 04:45 AM
Indiana
dlundblad Offline
dlundblad  Offline
Indiana
I've never rounded a bolt with a 12 point and honestly I always used box ends during an oil change. If you have the wrench squarely seated on the drain plug, you will have no issues.
03 Jeep WJ 4.0 200k Castrol Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 177k M1 0w40 Mahle OX149D
97 Chevy Blazer 4.3 149k Rotella T5 10w30 Supertech ST3980
Re: 13mm 6 point wrench [Re: dlundblad] #4632187
01/12/18 08:58 AM
01/12/18 08:58 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
+1 Never had a problem with 12pt wrenches.
Re: 13mm 6 point wrench [Re: WyrTwister] #4632999
01/12/18 09:59 PM
01/12/18 09:59 PM
Golden Meadow, LA
mobilaltima Offline
mobilaltima  Offline
Golden Meadow, LA
when doing oil changes I always loosen the plug with a 3/8 ratchet and the proper size 6 point socket, I then snug the plug up with the ratchet socket/and then the plug gets torqued to spec...every time.....never had a problem
2006 2500 Dodge 5.9 Cummins Mobil Delvac 15W40, Fleetguard Stratapore 90k miles
Early '99 F250 ECLB 7.3 Stroker, 223k miles
Re: 13mm 6 point wrench [Re: Trav] #4633319
01/13/18 09:29 AM
01/13/18 09:29 AM
New Jersey
JHZR2 Offline
JHZR2  Offline
New Jersey
How many have you used on overtorqued or "seized" bolts?
You've seen more than many of us combined is why I ask.
It only takes one or two to say "never again" in DIY land. But I have to wonder if the success associated with your claim is due to being a pro and actually using the right tool for the job?
Re: 13mm 6 point wrench [Re: WyrTwister] #4633343
01/13/18 09:44 AM
01/13/18 09:44 AM
Indiana
dlundblad Offline
dlundblad  Offline
Indiana
I can see a poorly fitting wrench getting someone into trouble.
Re: 13mm 6 point wrench [Re: JHZR2] #4633448
01/13/18 11:06 AM
01/13/18 11:06 AM
Trav Offline
Trav  Offline
I wont even attempt using a 12pt on a bolt or nut that has a damaged or rusted slightly undersized head (very common on parts like exhaust manifolds in the salt belt).
I cant remember a time i had trouble with an over torqued fasteners, use good quality tools that fit properly and keep it square on the fastener head.
